Old 11-30-2014, 04:25 PM   #301
67ChevyRedneck
67ChevyRedneck's Avatar
Re: My Big Fat Renovation
My awesome tiny wife helped me drill eight 3' deep holes for the posts with a rented 2 man post hole digger. I won't lie, it was a work out just for me, so it was amazing how well she did.
I laid everything out with string, a square, a level, and tape measure.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-30-2014, 04:27 PM   #302
67ChevyRedneck
Not an easy feat by yourself, but I got it done.
Jesse James
Project "On a Dime"
Old 11-30-2014, 04:28 PM   #303
67ChevyRedneck
Concrete day sucked. I got rained on halfway through it.
None of the boards you see are permanent. They're all temporarily screwed in to keep the posts square.
Jesse James
Project "On a Dime"
Old 11-30-2014, 04:33 PM   #304
67ChevyRedneck
These are the good boards installed. I notched the posts along the outside for added strength.
I also don't do this often... but can you spot my mistake?
Jesse James
Project "On a Dime"
Old 11-30-2014, 04:35 PM   #305
67ChevyRedneck
Hopefully it's obvious now... cost me a couple hours time.
I also sloped the land away from the house and to the right and laid some thick plastic down. It's rained quite a few times since I installed this and it works quite well. I did have to slit a few low spots so the water will drain under in those spots, but works well.
Jesse James
Project "On a Dime"
Old 11-30-2014, 04:37 PM   #306
67ChevyRedneck
I learned my lesson on the front porch and didn't want to spend a day or two crawling under the deck to install the lattice, so I stained the areas around lattice and cut/installed the lattice.
Jesse James
Project "On a Dime"
Old 11-30-2014, 04:46 PM   #307
67ChevyRedneck
This thing was the devil. I wanted a slight elevation so a lot of water didn't run over/sit against and rot out my steps (what happened on last deck), but by the time I ran it level over to the other side I was quite a bit above grade. I went 4" below ground... there was a crap load of hand mixed concrete in that step...
Jesse James
Project "On a Dime"
Old 11-30-2014, 04:49 PM   #308
67ChevyRedneck
2x8x16 foot joists. I finished the bracing not seen in the 2nd to last pic. I had run of out boards for the day.
Jesse James
Project "On a Dime"
Old 11-30-2014, 04:52 PM   #309
67ChevyRedneck
Flooring going down:
Jesse James
Project "On a Dime"
Old 11-30-2014, 04:56 PM   #310
67ChevyRedneck
Rather than try to cut boards one at a time...
Jesse James
Project "On a Dime"
Old 11-30-2014, 04:57 PM   #311
67ChevyRedneck
With a couple measurements, chalk line, cut, and a quick sanding it looks pretty good.
Jesse James
Project "On a Dime"
Old 11-30-2014, 05:00 PM   #312
67ChevyRedneck
...and I'm pretty proud of this! Going from left to right it does drop about 3/8" over 24', but that couldn't be helped... I had to follow the existing door/old ledger/siding. That's pretty dang close for a deck.
Jesse James
Project "On a Dime"
Old 11-30-2014, 05:02 PM   #313
67ChevyRedneck
Got started on the stairs.
Jesse James
Project "On a Dime"
Old 11-30-2014, 05:21 PM   #314
67ChevyRedneck
Then daylight savings hit...
So I had to do things screwy, like only pressure wash half and stain half the deck.
Jesse James
Project "On a Dime"
Old 11-30-2014, 05:23 PM   #315
67ChevyRedneck
There was a lot of red clay on it... and it doesn't like to come off easily... and the back side of the deck only has sun for a few hours, so I pressure washed one Friday night after work so I could stain it the next morning so it could dry.
Jesse James
Project "On a Dime"
Old 11-30-2014, 05:27 PM   #316
67ChevyRedneck
Started the railing. Installed it the same as the front deck, except this time I wasn't limited by the existing posts, so I could do it the way I wanted to.
Jesse James
Project "On a Dime"
Old 11-30-2014, 05:29 PM   #317
67ChevyRedneck
Painted the rusty old door under the deck to blend in with the brick better.
Jesse James
Project "On a Dime"
Old 11-30-2014, 05:36 PM   #318
67ChevyRedneck
Other side:
Jesse James
Project "On a Dime"
Old 11-30-2014, 05:38 PM   #319
67ChevyRedneck
Top side finished!
Check out that awesome gate! I had to "kit bash" for that. Trex doesn't make a gate kit, so I had to find someone that does. I found a gate kit at home depot that matched close enough. I made it work. We have indoor dogs, so we like to keep them somewhat clean. What's funny is they prefer to be inside 95% of the time, but the little one likes to sun herself every once in a while (yes, it's weird, she seeks the sun, not shade) so now we can leave them on the deck and not have to worry about them rolling in red clay and digging holes!
Jesse James
Project "On a Dime"
Old 11-30-2014, 05:43 PM   #320
67ChevyRedneck
I'm not completely done, but pretty damn close.
There's obviously a lot of clean up to do. A little landscaping and mulching, but it's usable now. I do still have to build an access door in the lattice for the crawlspace.
Jesse James
Project "On a Dime"
Old 11-30-2014, 05:48 PM   #321
67ChevyRedneck
Comparison pics. I started the tear down on October 3rd and I finished up the stair railing yesterday, November 29th.
Before:
12' long by 14' wide old deck:
After:
New 16' wide by 24' long new deck!
Jesse James
Project "On a Dime"
Old 12-02-2014, 03:27 PM   #322
esoxman308
esoxman308's Avatar
Looks great!! another fine job done....
esoxman308 is offline   Reply With Quote
Old 12-03-2014, 09:28 AM   #323
67ChevyRedneck
Thanks man!
It's been a long time coming! All I have left inside is a hallway (although its a long one, and it's L shaped... and I added wainscoting...) and I need to finish the trim and build a closet in one more bedroom (used as an office) and the inside is done!
The wife thinks I'm going to "redo" the bathrooms... but I really don't want to. I added trim to both, and they need paint and some new lights, but what I really don't want to do is the tile. The downstairs laundry room and bathroom had nice, well done tile. The tile upstairs are the 12"x12" ones and some are cracked, either from bad installation or unlevel floor (likely both) and I just don't want to do tile... and I don't want to pay anyone either...
I also discovered there isn't any kind of a wrap on our house, just plywood and siding, AND there's A LOT of damaged areas I can't repair. There's a huge melt hole from a grille where the deck is (was like that when we got it), and where the fences are on both sides there's a couple feet of stain overspray on each side... and it's 16 years old... and the wife doesn't like the color....
My goal is to finish the bedroom and hallway this winter and next spring to reside the house with tyvex wrap and the siding with the insulation on the backside, if I use that stuff I can deduct the siding cost from my taxes as well. I may actually be able to start working on cars again next year?!?!
Jesse James
Project "On a Dime"
Old 12-03-2014, 11:55 AM   #324
motornut
78K & 79C Jimmys
motornut's Avatar
Thats a great looking deck,gotta love a big deck for entertaining.
I'm doin one up ,out back next spring
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-15-2014, 11:50 AM   #325
67ChevyRedneck
I think we're gonna have a "deck party" this spring!
The neighbor next door loves the railing. He wants to redo his now
This may be *almost* a first for me. I started a massive project and kept at it until it was completely finished. I have a BAD habbit of getting something 80, 90, even 98% done and moving on to something else, then not finish that up for weeks, months, even years. My shed is a good example... it's all done except for filling nail holes and painting it... that was 2.5-3 years ago? (the primer is holding up so well! )
Anyway, here she is with the siding back on (although temporary as this will be redone as well) and the "grading" done. I plan on adding some sort of paver or stone in front of the steps and I will mulch around the deck as I did the house, but that can be done this spring.
Jesse James
Project "On a Dime"
