Old 07-05-2014, 12:15 AM   #301
WATSON403
Re: 60-66 Tire/Wheel Pics
http://67-72chevytrucks.com/vboard/a...1&d=1404533640 this is how I have my wheels on my 66 c20 16" 8 lug steel rims I'm going to be putting wide whites on soon
WATSON403 is offline   Reply With Quote
Old 07-09-2014, 12:16 AM   #302
72bigblockw/air
72bigblockw/air's Avatar
17"x8" front with a 255/50/17
17"x9.5" rear with 275/50/17
72bigblockw/air is offline   Reply With Quote
Old 07-09-2014, 12:19 AM   #303
72bigblockw/air
Or the new set
15"x6" all the way around with 225/75/15
Old 07-09-2014, 01:23 PM   #304
kenwkirk
kenwkirk's Avatar
I have a 1966 c-10 Fleetside I am currently running 15x8 truck rallys with minimum clearance -- fender wells have been barely trimmed --- I am wanting 2 go with the BOSS 338 ---17x8 front & 18x9.5 rear --- truck has been lowered 4" front & 6" rear,, but it is on a 1972 frame --- will these wheels fit with the correct back-space ? if not does anyone have any suggestions/opinions on what will fit ? THANKS IN ADVANCE
kenwkirk is offline   Reply With Quote
Old 07-09-2014, 02:04 PM   #305
kenwkirk
kenwkirk's Avatar
OOPS meant 2 add this THANKS
Old 07-10-2014, 11:55 PM   #306
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Im sure the 17X8 will fit as well as a 18X8 without any problem other than cleaning the snout up on the brake rotor .... very common issue with 1.25'' brake rotors that a 1972 is going to have. Im guessing the 18X9.5 on the rear maybe to much. They do have 5.25'' backspacing and no other options. the 17X8 and 18X8 have 4.5'' backspacing. You could get a 20X8.5 with 4.75'' backspace , might get a little closer to fitting. they do offer a 20X8.5'', 5.25'' backspace wheel as well which Im positive would fit in the rear. I dont have a ton of experience working on the 66 and older trucks tho.
Im sure someone will chime in here.
Dont forget if you have a 1972 frame you should have the wider rear axle if nothing has been chahged there.
ksbrktracer is offline   Reply With Quote
Old 07-11-2014, 07:19 AM   #307
SteveMiller
SteveMiller's Avatar
18x8 235/60 & 18x9.5 275/55 on American Racing VN805's.
4.8 LS
4wheel disk on 84square suspension swap.
Oh yeah. 5" drop coils in rear, and cut one front coil w/drop spindles front.
SteveMiller is offline   Reply With Quote
Old 07-11-2014, 09:49 AM   #308
ChrisDollins
ChrisDollins's Avatar
Originally Posted by 72bigblockw/air View Post
Attachment 1275771
I personally like the torque thrusts. Awesome looking pickup either way!
Chris
ChrisDollins is offline   Reply With Quote
Old 07-11-2014, 10:38 AM   #309
boonedogs72
boonedogs72's Avatar
Attachment 1275773
Or the new set
love the new look
boonedogs72 is offline   Reply With Quote
Old 08-05-2014, 10:12 PM   #310
Blue Ox
Lots of awesome stuff here. I love all the different style approaches. Seems like there's no way to go wrong with the wheel & tire combos. Everything here looks Great!
Here's mine...
I was going for the skinny tire old school look.
Pacer 310W 16" x 6" wheel with Goodyear Wrangler Duratrac 215-85-R16 tires.
Blue Ox is offline   Reply With Quote
Old 08-06-2014, 01:58 AM   #311
Kenfuzed
Kenfuzed's Avatar
Attachment 1275771
I really like this look. Do you know what the backspacing is on the rear 9.5's?
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 09-12-2014, 12:47 AM   #312
IHutch5R
Originally Posted by markeb01 View Post
Here’s a few I’ve had on mine over the years:
15x8 stock steel wheel (zero offset) with 235/70-15 Radial T/A
15x8 Weld wheels (zero offset) with 235/70-15 Radial T/A
Rear-15x6 1950's Buick wheel with 255/70-15 Radial T/A, front-15x6 Dragmaster 1968 era wheel with 215/70-15 Radial T/A
15x8 Rally wheel (zero offset) with 235/70-15 Radial T/A
15x5 American Racing TTO with 215/70-15 Radial T/A (not sure about the offset, they're listed in mm)
15x7 American Racing TTO with 255/70-15 Firestone Indy 500
And on the truck
I gotta know what that black on your step side is called. Looks like a satin black?
IHutch5R is offline   Reply With Quote
Old 09-12-2014, 07:34 PM   #313
RANDY COX
RANDY COX's Avatar
Here's mine...
I like those tires...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 09-23-2014, 01:40 PM   #314
Hugh in NC
Hugh in NC's Avatar
My new-to-me 1963 C10. 350/350, a/c, ps, pb, cruise.
Hugh in NC is offline   Reply With Quote
Old 11-24-2014, 09:52 PM   #315
schpeen
schpeen's Avatar
here is my 65'
schpeen is offline   Reply With Quote
Old 11-24-2014, 09:56 PM   #316
schpeen
schpeen's Avatar
Originally Posted by schpeen View Post
here is my 65'
here it is with my old wheels and tires
Old 11-24-2014, 09:58 PM   #317
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I like both looks.
66 C20 Service Truck:
Old 11-24-2014, 10:04 PM   #318
schpeen
schpeen's Avatar
Originally Posted by LostMy65 View Post
I like both looks.
thanks me too but i believe i really like the wide whites on my truck a whole lot better. it seems closer to being "done" in my mind maybe.
Old 11-24-2014, 10:59 PM   #319
REDNOSE65
REDNOSE65's Avatar
Mine with and without hubcaps. I think I like it more without.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
The making of a Red Nose...
http://www.67-72chevytrucks.com/vboa...d.php?t=396518
REDNOSE65 is offline   Reply With Quote
Old 11-25-2014, 01:10 AM   #320
Kenfuzed
Kenfuzed's Avatar
I like the without hubcap look.
Enjoying the ride!
Old 11-26-2014, 09:00 AM   #321
aspiringthomas
aspiringthomas's Avatar
Those are some good looking wheels!
aspiringthomas is offline   Reply With Quote
Old 11-26-2014, 03:31 PM   #322
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
I agree. Looks awesome without!
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 11-29-2014, 11:19 AM   #323
REDNOSE65
REDNOSE65's Avatar
Thanks fellas... I roll it without!
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 12-26-2014, 09:51 AM   #324
USA69Z
USA69Z's Avatar
running 20 x 8 & 20 x 11..
USA69Z is offline   Reply With Quote
Old 12-26-2014, 05:34 PM   #325
markeb01
Senior Enthusiast
markeb01's Avatar
Here's mine with 15x7" trim rings on 15x6 & 15x7 rally wheels. These are my snow tire wheels. And for the Hutch question back in September I didn't see until today, the paint on my truck is John Deere Blitz Black enamel:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
