Old 06-14-2014, 07:21 PM   #301
Jerbou71
Jerbou71's Avatar
Re: What did you do yo your truck today??
I painted the inside of my bed today.
94grounddweller
My build thread.
http://www.gmt400.com/forum/showthre...ild-on-22-quot
Jerbou71 is offline   Reply With Quote
Old 06-15-2014, 06:46 PM   #302
Red88
Red88's Avatar
Last weekend I updated my "moonie" to the "needle" instrument panel. Donor truck was a '93 suburban for both the panel and the drac. Used the mod instructions listed plus instrument panel wiring diagrams for both my '88 and the donor '93 plus the ecm diagram for my '88. More soldering than I've done since high school electronics class but it turned out great!
http://www.fullsizechevy.com/forum/g...es-w-tach.html
'88 K1500 Scottsdale
5.7 TBI, 5spd MG5
Red88 is offline   Reply With Quote
Old 06-15-2014, 06:57 PM   #303
Jerbou71
Jerbou71's Avatar
Well I got the rear frame painted and done today.
94grounddweller
My build thread.
Old 06-16-2014, 09:30 PM   #304
Black 'n' Blue
Black 'n' Blue's Avatar
Put my 4" Diamond Eye exhaust on my 95 today. With a little bit of modification to fit my style...
-Justin.
The past cannot be edited, or erased. Only accepted.
Loud, proud and country by the grace of god!
Bradley Anderson 1997-2011
Black 'n' Blue is offline   Reply With Quote
Old 06-20-2014, 03:47 PM   #305
Dustinmk4
Plugs, Wires, Cap, Rotor, Intake gasket (upper), all tie rod ends, Idler arm and Idler arm assy, and Pitman arm. So glad to have all that done. Runs like a champ and after the alignment it drives true and straight.
1996 K3500 CCLB. 7.4L auto. 140K. Small lift and exhaust with more to come.
Dustinmk4 is offline   Reply With Quote
Old 06-25-2014, 10:27 AM   #306
MaritimeDragRacing
MaritimeDragRacing's Avatar
Swapped out my mangled and torn up original seats for a real good set of salvage yard seats from a 1998 Silverado. I figure they must have been hiding under seat covers from new since there isn't even any sun faded sections. Had both of the old seats out back in May when I was repairing the body mounts so swapping in the new ones only took a half an hour - 15 minutes of which was spent trying to remember how to put that center seat belt back together after I took it apart to get it through the small access hole in the seat LOL.
http://www.maritimedragracing.com
Atlantic Canada’s #1 source for Drag Racing News, Race Results, Schedules and Track Information.
MaritimeDragRacing is offline   Reply With Quote
Old 07-24-2014, 02:00 PM   #307
treman03
treman03's Avatar
Finally got a cowl hood for the '88 and gears changed to 3.73.
1999 Chevrolet Silverado
treman03 is offline   Reply With Quote
Old 07-24-2014, 02:35 PM   #308
flashed
That is a great looking truck.
flashed is offline   Reply With Quote
Old 07-26-2014, 01:39 PM   #309
Drewkimble48
I did some brake work this morning for my dad by replacing both wheel cylinders and a brake drum on his 97 chevy 2-door tahoe. Sadly though I bled the back 2 brakes after my dad lost a bunch of brake fluid from the leaky wheel cylinder and the brake pedal still goes all the way to the floor. I'm leaning towards a master cylinder needing to be replaced at this point. Oh a plus side though, I ordered my 5/7 drop from Belltech for my 93 gmc extended cab truck. It probably won't get shipped out until August 11th though. No big deal though, I still need to order some wheels for it anyways before I drop it.
Drewkimble48 is offline   Reply With Quote
Old 07-26-2014, 01:43 PM   #310
Drewkimble48
Hey Jerbou, did you buy a kit to do all that frame work or did you fabricate all of that? I haven't seen a set up around like that before with the pan hard bars and all.
Old 07-26-2014, 03:38 PM   #311
Jake1971
Jake1971's Avatar
Searched for "How to change a tire" and found this:
Name:  Stand Back I Got This.jpg
1971 Bone Stock C10 project "Jake"
1997 Sierra SLT factory short bed "Silver Bullet"
Jake1971 is offline   Reply With Quote
Old 08-01-2014, 06:18 AM   #312
ss454lemy
new wheels
ss454lemy is offline   Reply With Quote
Old 08-03-2014, 10:47 PM   #313
mrmontebuilder
Swapped out my rear slider with the leaky plexiglass center section for a factory tinted fixed glass. No more raining in the truck !!! Next up is fix holes in floor caused by the broken slider, looks like 2 about 4" diameter each.
Tim- Bensalem PA
mrmontebuilder is offline   Reply With Quote
Old 08-15-2014, 04:07 PM   #314
Drewkimble48
After 315k miles, the upper radiator hose finally blew out a small hole which forced me to replace it lol. Glad it didn't happen on my quick rode trip to OKC for the Buick vs. Ford shootout.
Old 08-16-2014, 01:58 PM   #315
Turbo1dr
Turbo1dr's Avatar
My buddy, along with his son, is installing a body lift on his sons truck.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored
1978 Turbo Malibu - Owned since 1986
1987 Grand National Aerocoupe -1 of 1
1988 LeSabre T-Type - Supercharged
Turbo1dr is offline   Reply With Quote
Old 08-31-2014, 12:03 PM   #316
54 jimmy
54 jimmy's Avatar
changed my trans filter, fluid, and pan. put a 99 factory deep pan on my 97.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 09-05-2014, 11:42 AM   #317
Dustinmk4
New radiator, all aluminum. New rad. hoses. New belt and new thermostat. Next up front brakes, pads and rotors.
Old 09-05-2014, 03:49 PM   #318
gunrunner95
In the last 2 months on my 89 I've reupholstered my bench seat with vinyl. Installed new upper and lower control arms, front shocks. New master cylinder (NBS) new brake booster. New headlights/ parklights and wiring harness to go with it. 3 color LED taillight bar. Had to put on a new starter. I also replaced the seal and oil in the rear end. I have new door weather seals i need to put on sometime soon and wheel arch trim.
1972 Chevy C-10 1/2 ton longbed project
1989 Chevy 1/2 ton shortbed
"If a man does his best, what else is there?"
"A pint of sweat saves a gallon of blood"-George Patton
gunrunner95 is offline   Reply With Quote
Old 09-19-2014, 03:40 PM   #319
gunrunner95
Cleaned the TBI on my 89. Replaced the IAC sensor, O2 sensor and throttle kickdown cable.
Old 09-21-2014, 06:35 PM   #320
54 jimmy
54 jimmy's Avatar
replaced my starter on my dd 97. went with a gear reduction instead of a direct drive. much better now.
Old 10-22-2014, 06:27 PM   #321
Cape Codder
Cape Codder's Avatar
I replaced all the brake lines to the rear. I had some 1/4 stainless lying around the shop to go from ABS to rear hose and used coated 3/16 for the rear axle lines. I was backing down a boat ramp when the line let go. That got my attention. I did manage to retrieve the boat with the front brakes working and a low pedal.
Cape Codder is offline   Reply With Quote
Old 10-23-2014, 10:24 AM   #322
91short
Originally Posted by Cape Codder View Post
To adjust a door with welded hinges instead of jacking the door and possibly denting or bending it the other option is to open the door and put a block of wood in the open part of the hinge where the pin is and GENTLY close the door until the hinge hits the block. Then apply some pressure and check. Go easy it is easy to go to far. By binding the hinge it will bend it back and raise the rear of the door. The idea is to have an even gap at the rear or the door and the body lines at the rear aligned. The fender to door gap is aligned with the fender. If the whole door seems low before doing anything loosen the door to hinge bolts and see if the whole door will come up a little.
Doors should be aligned with the striker removed and should fit without the striker influencing it.
Will you please post a picture of what you're describing? I would like to see exactly where to put the block of wood.
91short is offline   Reply With Quote
Old 10-24-2014, 06:39 AM   #323
Cape Codder
I will try to get a Pic up tonight.
Bob
Old 11-23-2014, 04:06 PM   #324
Marty68
painted my new grille
Marty68 is offline   Reply With Quote
Old 11-24-2014, 08:06 AM   #325
Cape Codder
Looks like the small Iwata paint gun,I have the same gun and love it. Parts look good ,post an installed pic when done.
