Old 05-04-2020, 11:16 AM   #301
MDPotter
MDPotter's Avatar
Re: 1968 GMC - Ol' Blue
Got quite a bit done Saturday.
Mirrors - I have now bought two new mirrors and both were a fail. The smaller one is from Brothers and was advertised for GMC, but it should look like the longer one. I was okay with it, but where it attaches to the mirror bracket it's not quite thick enough so the screw through it will not tighten up and it just falls. Even with the weird washer in it. So I ordered one from LMC (long one) that actually matches my factory mirror pretty close, but the knob for daytime/nighttime was busted. You would think this wouldn't matter, but apparently that knob puts tension on the mirror because with it broken off it just shakes all over the place. So I put the original mirror on and moved on.
Bed Floor - Done. Raptor Liner has cured out nice and hard and very even. I installed the fuel filler door too. It's a little small, but it will work. I might weld on a little tab on the cap someday to make it easier to loosen and tighten. But it came out pretty clean.
Painting - Tailgate, front panel, inner door panels, bedside braces, tailgate handle, and tubs are painted and came out pretty slick.
EDP/Epoxy:
Sealer:
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 05-04-2020, 11:17 AM   #302
MDPotter
MDPotter's Avatar
Base:
Clear:
Old 05-04-2020, 11:20 AM   #303
Camaroguy
Camaroguy's Avatar
Killing it!
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD)
Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712
Camaroguy is offline   Reply With Quote
Old 05-04-2020, 08:59 PM   #304
cornerstone
cornerstone's Avatar
Looks incredible!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 05-07-2020, 09:15 AM   #305
MDPotter
MDPotter's Avatar
Last night I sanded all the filler on my bedsides and reapplied epoxy over those spots. There were a bunch of ugly spot welds on the inner bed rails, I shaved the stake pockets, and fixing the shipping damage.
Painting the bedsides this weekend!
Old 05-07-2020, 09:19 AM   #306
Putzer
I had the same issue with my rear view mirror from GMCPauls but really cranked down on the screw and it seemed to tighten up and doesn’t fall down anymore.
Putzer is offline   Reply With Quote
Old 05-07-2020, 09:20 AM   #307
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Great work as always! You are getting yours done fast.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 05-07-2020, 09:22 AM   #308
MDPotter
MDPotter's Avatar
I'm very self-motivated. I want it done so I can drive it!
Old 05-08-2020, 01:28 PM   #309
cornerstone
You may have mentioned this earlier and I didn’t notice, but I gotta ask the question... how is it that you have so much time in a legit spray booth?
Brian
Old 05-08-2020, 01:37 PM   #310
MDPotter
MDPotter's Avatar
Well I appreciate the compliment on the spray booth! Haha but it is by no means legit. It's just a wood framed room with lots of light, intake filters, and exhaust to the exterior. But it is nice to have a room dedicated to spraying. I probably spent about $1500 on it. But we had lights, ceiling joists, and an old swamp cooler from a building we dismantled. So I bought the 2x material, OSB, paint, and furnace filters and it works pretty well. I need more CFM though, it gets cloudy quick if you're spraying much clear.
Old 05-08-2020, 04:30 PM   #311
TA_C10
TA_C10's Avatar
Nice work Potter! Been a while since I checked in. I have same extra LMC mirror I'm not using if you want it.
When you shaved your bed stakes did you also remove the boxes underneath as well?
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 05-08-2020, 06:40 PM   #312
MDPotter
MDPotter's Avatar
Appreciate the offer, I'll let you know if I get tired of staring at my stock mirror.
And no, I didn't go that far. Just filled the hole in the bedrail.
Old 05-09-2020, 11:17 AM   #313
cornerstone
Wow. in some of the pics it looks quite large, what are the dimensions inside the spray room? What all can you fit in there to spray at once? I'm working on building a 40x40 right now and would like to incorporate the same thing, maybe a couple of retractable walls?
Brian
Old 05-11-2020, 09:28 AM   #314
MDPotter
MDPotter's Avatar
I think it's 15Wx25Lx12H. I can fit a full size truck put together or 4 big panels spread out. Actually sprayed two good size tractors in it (with just an inch to spare on top of the cab).
The ceiling joists are just big enough to support some storage on top which is nice.
Old 05-11-2020, 09:31 AM   #315
MDPotter
MDPotter's Avatar
The bed is now 100% painted. Looking forward to putting it together next weekend!
Old 05-11-2020, 10:23 AM   #316
Camaroguy
Camaroguy's Avatar
Bed looks really good. Good job!
Old 05-11-2020, 11:53 AM   #317
1971Stepside
Almost Satisfied
Looks like you had a more productive weekend than I did. Can't wait to see the bed on it.
Old 05-18-2020, 11:47 AM   #318
MDPotter
MDPotter's Avatar
This thing is really coming down the home stretch. We had such a fun day yesterday putting the bed together, installing the lighting, and the bumper. Also got a few small interior parts done. This has been a lot of fun, but I'm looking forward to having it done so I can drive it and also work on a couple home projects before starting on the next vehicle.
At this point, it needs a hood, Vintage Air, alignment, and a few small items and it'll be done.
Old 05-18-2020, 11:57 AM   #319
1971Stepside
Almost Satisfied
Looks absolutely amazing! Has to feel good. I'm laughing that you mentioned your next project. I'm starting to wonder what mine will be. After doing this for 2-3 years I don't know what I am going to do with my free time when it is done. I need to start looking for another project, but I'm afraid I'll find one I've always wanted a 69 Camaro or a 66-67 Nova....hmmmmm
Old 05-18-2020, 12:23 PM   #320
MDPotter
MDPotter's Avatar
Thanks. It felt good knowing that all the time we spent mocking things up, test fitting, cutting, welding, etc. paid off. All of a sudden, a complete bed.
I'd like to have a 71 or so Camaro, I really like that body style before the taillights changed. But I think a car would cost even more than a truck so we'll just stick to C10's for now. The next one definitely won't be as fast. Working hard on it every Saturday for over a year can be pretty exhausting. I need to build a bed frame for our bedroom, redo the lawn, get my dad's Vintage Air fixed, and then we can start on the next one.
Old 05-18-2020, 12:39 PM   #321
1971Stepside
Almost Satisfied
Understand. I could be talked into a square body short bed 4x4 with a 4 speed. My dad had several growing up and I would love to have about a 79 or so.
Old 05-19-2020, 08:40 AM   #322
clay68c10
clay68c10's Avatar
It’s looking sweet! I can’t wait to be at that stage.
The stance is nice, what are your wheel/tire sizes?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 05-19-2020, 09:12 AM   #323
MDPotter
MDPotter's Avatar
Thanks, it's awesome seeing a big change in a day.
Tires are 245/50/17's. They're smaller than I would like, so I'll be getting new wheels and tires later this year. I'd like to have 18's or 20's with taller/wider tires in the back and slightly taller in the front.
Old 05-19-2020, 10:09 AM   #324
cornerstone
Hard work paying off in huge smiles. Beautiful job well done!
What are your plans for trim? Tailgate lettering?
Brian
Old 05-19-2020, 10:25 AM   #325
MDPotter
MDPotter's Avatar
Thanks!
The only trim I have for it is the leading edge of the hood and fenders. I'm going for the smooth, "dipped" look. Maybe someday I'll put stickers over the tailgate letters, but I wasn't wild about the idea of painting the recessed around the letters black. If it were the GMC tailgate with the smaller recessed area and letters, then maybe. But this one has the big letters and recess and I thought it would be too much black. I want the focus to be on the blue.
