#301 |
![]() Join Date: Apr 2010
Re: Orson the 49 GMC ~ Chris C.
Even though Saturday is supposed to be my day to work on my projects, I had Wyatt make patches for the areas we relived in the firewall.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
#302 |
Lots of progress today! Welded up the holes in the cowl
Installed the gas pedal And painted the cab and boards (minus the roof). Still need to wetsand tomorrow.
#303 |
Went to the City today and dropped a small fortune on reproduction Parts
The parking lights and glovebox door cost me $195. The parking lights are used, but they are mint.
#304 |
![]() Join Date: May 2007
man thats a steal on gmc park lamps!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#305 |
Good to know
#306 |
we got the Front clip wet sanded and started the drivers door.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 04-08-2021 at 10:03 AM. |
#307 |
we got a lot done today. But I think I got ripped off on the Wiring harness. There is a bundle of 8 wires that go to an external connection. I’ve identified 4 of them. The TCC, speedo, tach, and fan. Those are the only 4 that the pinout says there should be! There’s no instructions and the wires aren’t labeled. I bought it through messenger and since my account was hacked, I had to start a new one. So now I can’t contact the seller! If we don’t figure it out soon I’m going to have to buy another harness! We took the front clip apart. Body worked the roof. Welded in the hacked up radio hole
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 04-10-2021 at 09:02 AM. |
#308 |
We finished wet sanding the drivers side. Cowl is ready for paint, roof still needs one more fill. Engine turns, but for some reason the fuel pump isn’t getting power. We are diagnosing now. I’ll stick Wyatt on it tomorrow.
#309 |
looking great!
did you have the pcm software modified? you probably did, but in case you didnt gotta take out the passlock at the very least, it will keep the fuel pump from running.
#310 |
I had the PCM cut by LT1swap
We got the bed and rear fenders on and drilled the new gas filter
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 04-16-2021 at 10:38 AM. |
#311 |
We started painting the bed, but ran out of color. Will pick some up tonight.
Pulled the column for paint and to paint the interior.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 04-16-2021 at 10:39 AM. |
#312 |
We ran out of color, but picked up 2 more cans tonight and ordered 3 more.
#313 |
We spent pretty much all day getting the door rubber off, it was like it was petrified! Then we stripped the remaining items out of the cab, in preparation for paint.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 04-20-2021 at 09:44 AM. |
#314 |
I am not satisfied with the patch on the radio hole, so Wyatt will be re-doing it on Wednesday. We started by painting the back wall of the cab, all the areas that are grey primer will be blue like the exterior and blended in with the black.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 04-20-2021 at 09:45 AM. |
#315 |
Today we got the bedsides painted and tailgate primed. We also got the inside of the cab primed.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 04-22-2021 at 09:58 AM. |
#316 |
i'm super interested to see the final product on the paint theme when it all comes together.
#317 |
Thank you
#318 |
The left bedside needs another coat
Right bedside is finished Doors are off for jamb paint and new rubber Back wall of cab in paint, but needs another coat
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 04-22-2021 at 10:56 PM. |
#319 |
We got the left door wetsanded and in interior paint
#320 |
Today we created templates for full door panels, tomorrow I’ll run them to my plas cutter and have them cut from 22ga. To include with the Truck
Chloe wet Sanded and painted the inside of the right door And masked the rockers and jambs
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 04-25-2021 at 10:55 AM. |
#321 |
Today we got the drivers door jamb in paint and prepped the passenger side
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 04-27-2021 at 09:48 AM. |
#322 |
The radio hole is smoothed and looking good
The inside of the bed is finished That left bedside to finally shaping up And the tailgate is coming along nicely
#323 |
We got the right doorjamb painted
And the left splashguard bodyworked
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 04-28-2021 at 09:57 AM. |
#324 |
Here’s the tailgate before and after wetsanding
This is the drivers side splashguard before color
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 04-29-2021 at 09:38 AM. |
#325 |
we got the rubber on both doors today.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 04-30-2021 at 09:42 AM. |
