#3251 |
Re: What did you do to your truck today.The 3rd chapter
Painted the bumper brackets yesterday now to coat the inside of the bumper . And made a mental note to not put wet por15 parts on cardboard ripped up big chunks of cardboard . Guess I should have put some plastic down
#3252 |
![]() Join Date: Dec 2012
That is how I handled my cross sills - worked out pretty well!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#3253 |
I’ve always used plastic just wasn’t thinking . Inside of the bumper done just need to get some bumper bolts . Started late on it so I brought it in as it’s suppose to dip into the 40s tonight didn’t want to leave it out .
#3254 |
![]() Join Date: Jun 2021
Painted my doors and fenders today.
#3255 |
Looks great .
#3256 |
Who Changed This?
![]() Join Date: Jan 2013
I've always liked that combo! Nicely done.
#3257 |
Cut up some bedsides and got started on putting them back together.
Posted via Mobile Device |
#3258 |
Ended up making my own shiny bumper bolts . I thought I had ordered them but I went through my last 3 invoices not on any of them . Tail lights all work only had to play with one backup . Basically just back off the nuts and retighten.
Bumper does have a slight twist to it . It was real bad but I my 12k winch to pull it to where it is now. If it becomes a problem looking at it I’ll buy two chrome bumpers .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 09-27-2022 at 05:54 PM. |
#3259 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
The truck is looking good. You're doing great.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#3260 | |
#3261 |
Looking good . You do great work , I need to get a new welder it never had the feel I like for thin sheetmetal . I have a Hobart 210 and it doesn't handle 24 wire that well
#3262 | |
#3263 |
![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#3264 |
Tied up some loose ends and installed a bench seat today. Of course the bench is temporary. It takes a long while to receive correct upholstery these days, ordered three months ago, they say as late as December. But I want to get this running, so a practice run on the bench I guess.
More than that I'm declaring a milestone. Long time coming, it's a battery and steering wheel away to roll for exhaust then start-up. Course the exhaust is pending, same with the battery, special is slow these days. Still needs glass, seems that should occur, any day now ![]() I've owned this 33 years, never saw it with a stove pipe until today. Always looked forward to it.
#3265 |
![]() Join Date: Dec 1999
Looking terrific!!! Put some lotion on your cheeks so the don’t crack. From the big grin you’ll have on your face when you take it out the first few times.
Smitty '71 Short Fleetside Spring Valley, Ca. |
#3266 |
![]() Join Date: Aug 2011
Looks great!! Hope to see it in person.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
#3267 |
Wife and I took ole rusty on a dinner trip up to Boog's stomping grounds. We've only been driving it locally making sure everything is sorted well and this trip was about 40 miles round trip. Truck did great but I realized the shorty cherry bomb exhaust has got to go. I have another muffler already and have ordered some pre bent pipe to rework it.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#3268 |
Right front fender was worse than I expected . Found some rot in the cup and rear after working out the dents . All in all it’s better than 90% of the ones I looked at . No prior bodywork which is a plus .
Filling and lead are all but a lost art . I’m not leading it but I did work several hours messaging the metal . Guess if you tried on a new car you would tear the metal apart. ![]()
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 09-29-2022 at 12:34 PM. |
#3269 |
![]() ![]() Join Date: Jan 2005
I've pulled the governor out of my 700R4 eight times so far over the last two evenings in an attempt to raise the WOT 1-2 shift point to somewhere in the 5000-5500RPM range using a TCI kit. The two heaviest weights in the kit with the two heaviest springs were still above 5500RPM, and the 2-3 shift at part throttle was happening way too early, so I resorted to grinding down the original weights. Now I've got it shifting at around 5300RPM, and the part throttle shifts are spaced apart nicely. My wife snapped this picture as she was coming home from work yesterday evening.
#3270 | |
Well I decided to cut and weld out the damaged area around the front half of the wheel well because I wasn’t happy with the lip area and I was going to do the cup anyway. If I was going to use moldings it would have been fine. So I cut up an aftermarket fender . Took a lot of fitting to get the cuts good enough to butt weld . Transplant was successful. ![]()
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 09-30-2022 at 09:45 PM. |
#3271 |
Great progress, guys. Always impressed with the bodywork I see here.
Here's me finding out a clutch job turned into a trans + transfercase rebuild. Might as well refresh the engine while i'm here ![]() |
#3272 | |
![]() Join Date: Feb 2002
How come you have Blue plates, rather than the Black/Gold ones? Old 919 used to sport Black/Gold plates when I bought it. The military made me register my truck and get a driver's license in the state that was my Home of Record. My parents had moved to Arizona, so that was the new ''Home.'' I had to turn in my Calif. [10 566 A] and get an AZ plate [2JY150] at the MVD [not DMV].
#3273 | |
#3274 | |
![]() Join Date: Mar 2021
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual Last edited by Jiggers72-GMC; 10-01-2022 at 11:18 AM. |
#3275 | |
