Old 06-22-2009, 12:16 AM   #326
56chevy1300
56chevy1300's Avatar
Re: My Project 56Chevy1300
First show...not quite sure about that spare tire...might have to get a matching wheel.
56chevy1300 is offline   Reply With Quote
Old 06-22-2009, 08:50 AM   #327
Bigblue29
Thanks 'til you're better paid
Bigblue29's Avatar
You may consider a tire/wheel cover with your logo on it until you get a matching rim and tire. Just a thought... Looks great otherwise!
-Luke
1950 Chevy AD 3100 pickup
2000 GMC Sierra
1970 Jeepster Commando
Bigblue29 is offline   Reply With Quote
Old 06-22-2009, 08:56 AM   #328
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Here's some info from the Tri-Five guys. Have a look at the RCD link.
http://www.trifive.com/forums/showth...ghlight=shocks
ChuckDriver is offline   Reply With Quote
Old 06-22-2009, 10:54 AM   #329
watahyahknow
watahyahknow's Avatar
Thanks, I'll give it a try.
should be eazy enough add some big shims between the cups and the bags and use longer bolts to try it before going in there with a hacksaw and a welder , it sounds like a good idea
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 06-22-2009, 12:14 PM   #330
56chevy1300
Originally Posted by CAL 58 GMC View Post
I'm running 100 psi in the front and 32 psi in the rear. Any less up front and my cross member will scrape the road.
Dave, how is your ride quality?
Old 06-22-2009, 12:53 PM   #331
56chevy1300
I'm trying to find an 80's "Alberta" cover but have been unsuccessful so far!
Old 06-22-2009, 01:11 PM   #332
ezekiel
Now that brings back memories.
My Dad had one on his van spare on the back door.
I think I remember wheel covers using both of these logos.
Which one were you thinking of?
ezekiel is offline   Reply With Quote
Old 06-22-2009, 01:34 PM   #333
ezekiel
Now I know my memory is going.
This picture is the cover that my Dad had on his van.
Old 06-23-2009, 01:07 AM   #334
56chevy1300
The right
Old 06-23-2009, 09:50 AM   #335
1-ton of fun
polishing a turd
1-ton of fun's Avatar
i really like your paint; it is a very interesting color.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 07-14-2009, 09:08 PM   #336
dfrost
Great finely someone using a gm front end on a Chevy.
Thanks help me out great pictures.
dfrost is offline   Reply With Quote
Old 07-15-2009, 12:12 AM   #337
pro1955
pro1955's Avatar
WOW, just went through all the pics, nice job truck looks great. Lots of work, you should be proud.
Truck's just for the fun of it.
pro1955 is offline   Reply With Quote
Old 11-17-2009, 09:06 PM   #338
smbrouss70
smbrouss70's Avatar
Did you ever get the harsh ride problem figured out?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 05-28-2010, 04:27 PM   #339
56chevy1300
Yah, too much air. I think what I'll do is buy larger diameter tires and let a little air out of the bags.
Old 06-18-2010, 05:25 PM   #340
56chevy1300
Its time for some larger diameter rubber...thought about running 255/60 front and 285/60 in the rear. I have 7" rims front and 8" rear. Any thoughts on fitment?
Old 08-20-2010, 07:52 PM   #341
Tanman
Tanman's Avatar
How much clearance do you have between the rear tire to the fender? Would you be able to run a 10inch wide rim?
Tanman is offline   Reply With Quote
Old 08-21-2010, 09:37 AM   #342
ChuckDriver
I'm running 285/60x16 on 10in rims on the back of mine and I had to cut the bedsides. Plan on using some early 70's suburban wheel tubs to cover the opening. Have a look at my build thread for pics!
Old 08-21-2010, 11:00 AM   #343
Tanman
Tanman's Avatar
Thanks for the info chuck.
Old 01-08-2011, 10:05 PM   #344
71'tahoe
71'tahoe's Avatar
Im bringing this back to the top...
What did you do as far as the suspension? You go with the Slam Specialtise RE 8"s in the front?
In all the air ride installes Ive done for myself as well as customers..around85-100 psi is normal in the front. the rear depends on bag placement as well as the bag size. I have seen several articles on using those rolling sleeve bags you have in the rear..They claim less air/more lift/better ride with that style bag.
What did you do about tire size?
And I have to ask.....Did you get the cruise control working? If so how do you set it and adjust it? I may have missed it but do you have a steering column that has the cruise switch on it?
Greg "GT" Tholen
71'tahoe is offline   Reply With Quote
Old 09-29-2011, 09:53 PM   #345
ZR2RICK
ZR2RICK's Avatar
So I am very interested in what you have decided to do about the ride stiffness of your truck.
Learn to deal with reality, or reality will deal with you.
ZR2RICK is offline   Reply With Quote
Old 10-01-2011, 10:38 AM   #346
Coupeguy2001
Coupeguy2001's Avatar
BTW, I have never seen a "1300" fender spear, all I have ever seen is a "3100".
I think those fender spears are pretty cool.
I have a 57, so not interested in them, your dog doesn't have to sleep in your garage at night.......LOL
Personally, I think that if you ever got a flat, your spare tire would be nice if it actually bolts onto your axles.
Go to tire rack.com, and look up the tire you are wanting to put on the truck, and view the tire. THen click on "specs" on the bottom of the listing, and all the sizes in that tire made by that manufacturer will be displayed if you scroll down.
Then you can pick the diameter, width, tread width, and revolutions per mile (if you had a computerized car with ABS and fuel injection) to be able to make a tire selection that was informed.
Coupeguy2001 is offline   Reply With Quote
Old 10-03-2011, 07:12 PM   #347
57 Jimmy
No disrespect but ditch the spare tire fender and carry a can of fixaflat.
That truck looks sooo nice the spare takes away its cool lnes IMO
57 Jimmy is offline   Reply With Quote
Old 10-26-2011, 10:26 PM   #348
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
I've been back and forth for several years now trying to figure out whether to use my '78 camaro's sub frame as a donor for the '57. Tonite, the wife and I discussed it and decided to scrap the camaro project and move on to the '57. This is an awesome thread and a great build! Mine is in my sig and the project starts now... very nice job!! /Ken
87Lowrider is offline   Reply With Quote
Old 10-27-2011, 12:26 AM   #349
watahyahknow
nice , you can get a ton of stuff from the camaro donor before selling of a ton of camarospecific parts : subframe , engine , automatic , driveshaft , rearaxle including springs , powerbrakecilinder , wheels , steeringcolumb , would the camaro seats and gastank fit the 57?
if i would have to choose between two projects in simulair shape and one of them is a 57 i wouldnt had to think verry long , the 57 chevy pickup is one of my favorite trucks , the only exeption would be a 67 to 69 camaro
Old 12-04-2011, 09:00 PM   #350
ashtray455
hey bud, getn ready to put a subframe on my 57 pickup any tips ?
ashtray455 is offline   Reply With Quote
