Old 05-11-2013, 11:24 AM   #326
Vernski
Re: Tricked-out Chevy six cylinder engines
Originally Posted by sixtyeightchevykid View Post
what headers is everyone running for performance, and best quality, long tube or short tubes?
68chevykid it depends on what you want to do with your truck, if you lower your truck long tubes will drag on the ground. Short tubes won't depending on how you route your pipes, and most exhaust shops can do that for you if you don't have a pipe bender. Here is a link to 6=8 and some headers, there are other places out there. https://www.cliffordperformance.net/ Or Tom Langdon's stovebolt I opted for Tom's cast iron headers because they don't leak and make ticking noises. I included a pic of the headers and Clifford intake. Good luck with your choice...Vernski
Vernski is offline   Reply With Quote
Old 05-11-2013, 11:52 AM   #327
Vernski
Originally Posted by T.J. MCCAULEY View Post
Hi verski,
What did your offenhauser valve cover run you? Looks cool!
Hi T.J. it's been about 6-7 years since I bought that seems like it was $160-$170 at Jegs, it may be a bit higher now though thanks...Vernski
Old 05-11-2013, 10:04 PM   #328
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Its probably 500 dollors now!
TJ's Chevy is offline   Reply With Quote
Old 05-12-2013, 03:17 AM   #329
Vernski
Looks like it's still under $200...Vernski
http://www.jegs.com/i/Offenhauser/750/5417/10002/-1
Old 05-12-2013, 10:16 PM   #330
slepysal
slepysal's Avatar
tj were did you get your shorty headers?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 05-13-2013, 08:15 AM   #331
sixtyeightchevykid
sixtyeightchevykid's Avatar
what headers will work with a stock 4speed?
i read somewhere that langdons will get inthe way of the offenhauser intake i have now ?
1968 chevy c10 lwb, 250 inline6, 4 speed,
sixtyeightchevykid is offline   Reply With Quote
Old 05-13-2013, 02:45 PM   #332
Vernski
68chevykid most headers long or short will fit, just quiz the seller about fitment they should know what fits what. Just be cautious I bought some long tubes from Summit, they fit after I made them fit. I had to move the clutch rod to one side to clear the long tubes, and Summit said they would bolt on. If you are going to lower your truck I would consider the short tubes because the long tubes will interfere with ground clearance even at stock height unless your building a Gasser or have a 4+4.
Do you have a link to that Langdon's will get in the way of the offerhauser intake? I would like to read that if you have it at hand thanx...Vernski
Old 05-13-2013, 03:25 PM   #333
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Slepysal,
Got them from clifford. Cool thing was that I paid the guy a visit while I was in california, so if you have any questions on what he sells( you name it I saw it in my hands) I can give you an answer. He is a nice guy, just dont get scammed by him.
Old 05-13-2013, 07:09 PM   #334
Riverside Racer
Here's my '65 C10 with a Six!
Started out with a 292 with Camaro 5 speed.
Just swapping over to this GM Six. Twin Cam, 24 Valves, VVT, and Fuel Injected. A little more modern. Expecting 300Hp before mods.
Riverside Racer is offline   Reply With Quote
Old 05-13-2013, 07:41 PM   #335
jayoldschool
Moderator
Very cool. Please do a build thread!
jayoldschool is offline   Reply With Quote
Old 05-13-2013, 11:27 PM   #336
Captainfab
60-66 Nut
X2......I would like to see and hear more about your build.
Old 05-14-2013, 08:33 AM   #337
sixtyeightchevykid
ok my truck is lowered and at some point will be lower than it is now,
i dont have the link but it was on this site that i read that. but they said that the flanges where it bolts to the head were too big, if that makes sense. so they say just trim the flanges down length wise. anyone hear that or is it true?
Old 05-14-2013, 08:38 AM   #338
65chev
Yes. You are correct. Alittle grinding around the edges. No big deal.
M
65chev is offline   Reply With Quote
Old 05-14-2013, 09:13 AM   #339
sixtyeightchevykid
how much are we talkin?
Old 05-14-2013, 10:12 AM   #340
65chev
Its more the top surfaces matching. The surfaces are not the same thickness and the washer gets cocked.
Old 05-14-2013, 10:16 AM   #341
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I definately agree with you. My clifford intake has a slightly bigger flange than my clifford headers. You have to out quite a kink in those washer I'll say!
Old 05-14-2013, 10:19 AM   #342
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Since you are lowering your truck you will definately want short tube headers, like the ones from clifford or the ones from Tom Langdon @ stovebolt.
Old 05-14-2013, 10:21 AM   #343
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
sixtyeightchevykid,
The offenhauser intake will not get in the way of Lagndon's cast iron headers. Nor will the clifford intake( which is way bigger).
Old 05-14-2013, 12:57 PM   #344
Riverside Racer
Glad it sparked your interest. It's not for anyone with a weak heart!
I stumbled upon this engine while combing ebay for chevy 6 cylinder parts. A twin cam 4 valve per cylinder popped up. I thought that's a mistake!
It wasn't. for the price of a 292 intake and carb, I purchased the whole 2005 engine off of craigslist. Complete with accessories and wiring. (2006-2009 appear to be the best years.)
I've been gathering parts and information for over a year. We just started fabrication a couple of months ago. We've placed the engine and 5 speed trans in the truck to make up the front motor mounts and sized up the trans mount location. And that was the easy part!
The oil pan needs to be converted to rear sump. We've had the radiator inlet and outlet swapped side for side. (the water intake is through the thermostat on the drivers side of the block) Since no one makes a header we're going to make our own. There are quite a few transmission options available even though the bell housing pattern is different that the 60's stuff. I've gone with a manual 5 speed from a Colorado pick up.
Almost everything you'll want to know is happening on the Vortec 4200 forum, http://vortec4200.com/forum1/index.php
A few turbo applications and a few stock engine swaps are in the project section.
I've received help and guidance in reprogramming engine control unit and wiring, purchased a flywheel and manifold flanges, learned about converting the oil pan, etc. A few guys are making up parts to sell and help move things forward.
Take a look. It's like the V8 guys moving up to the LS series motors.
Here's a shot of my truck, one with the 292 and another of the 4.2L.
Old 05-14-2013, 01:23 PM   #345
K98AL
K98AL's Avatar
That is WAAAAY cool!
K98AL is offline   Reply With Quote
Old 05-14-2013, 06:05 PM   #346
65chev
does this help.
Old 05-14-2013, 06:15 PM   #347
65chev
Having trouble downloading picture. M
Old 05-14-2013, 06:18 PM   #348
65chev
I had to grind the big washer to fit both sides. M
Old 05-14-2013, 06:27 PM   #349
65chev
One more. M
Old 05-14-2013, 10:57 PM   #350
Captainfab
60-66 Nut
Thanks for the reply Riverside Racer
There was someone else talking about a 4200 I6 a while back. I can't remember who it was though.
