Old 02-22-2011, 12:22 PM   #326
es67chevy
es67chevy's Avatar
Re: Project Where'd The Money Go
Originally Posted by 67cheby View Post
shouldnt you be working also ??
Um, err, uh...CRAP. Back at it I guess.
Eric
1967 C10 SWB
383 Stroker/TH400
Brother's One Piece Power Windows
Shaved Doors, Markers, and Bumpers
4/6 Early Classic Drop
Rear Fuel Tank (49-52 Chevy Car Tank)
Surf Blue Paint
Bella Vista, AR (Arkansas for those that get the 'A' states mixed up)
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869
es67chevy is offline   Reply With Quote
Old 02-22-2011, 12:27 PM   #327
es67chevy
es67chevy's Avatar
Hmm, I just thought of something. I wonder how we tell what wheel adapter will work now? We don't know what year the van column is. Argh!@#@#@!
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 02-22-2011, 12:42 PM   #328
67cheby
67cheby
67cheby's Avatar
i think the adapter is the same for either one 60-80's year models
67cheby is offline   Reply With Quote
Old 02-22-2011, 12:55 PM   #329
c10/72
c10/72's Avatar
I'm running a TPI set-up in mine using a painless harness, and didn't have any issues...with the stock harness I just jumped the neutrel safety plug and on the painless harness I connected two of the wires togather...I will check tonight and let you know what wires they were.
c10/72 is offline   Reply With Quote
Old 02-22-2011, 03:08 PM   #330
es67chevy
es67chevy's Avatar
Cool. I appreciate it! Hopefully, we can make the damages as minimal as possible. Still not 100% sure of what the Neutral Safety switch does, but I definitely want backup lights. I know the Lokar part can do that for me. Just not 100% sure I don't need the Neutral part of it. I think it just keeps truck from being started in anything but neutral. If that's the case, I can probably handle not doing that. It may have been something else though. Just don't quite have that clear in my head.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 02-22-2011, 03:22 PM   #331
es67chevy
es67chevy's Avatar
You may be right. What keeps baffling me is the ones on Ebay that specify Chevrolet/GMC pick-ups 1974-94.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 02-28-2011, 04:01 PM   #332
es67chevy
es67chevy's Avatar
Decided to relocate the neutral safety switch this weekend. Wasn't too bad. At least, the first part wasn't. Seeing if it works in a few weeks is another thing entirely..
Kinda forgot to take pics until we were halfway through. Here's some pics of the process:
Even the wife likes to get in there and help!
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 02-28-2011, 04:06 PM   #333
c10/72
c10/72's Avatar
Did you just cut a new slot lower on the column and that was it, or did you have to do some other stuff to the column? I pulled my column out this weekend, but haven't got around to seeing what I had to do to make it work...what kind of measurements did you have to make?
Eric.
Old 02-28-2011, 04:07 PM   #334
es67chevy
es67chevy's Avatar
Also played a round of 'identify that part' with the board... I think we have this narrowed down to a horn relay or a heat/ac high speed fan relay. If it is the horn relay, we just need to know how to hook it up. We have a Painless Wiring Kit, and I can't find any mention of how to hook up the horn.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 02-28-2011, 04:08 PM   #335
es67chevy
es67chevy's Avatar
Also in the process of wiring up the a/c controls to our Surefit Vintage Air system. If you've already been through this process and have detailed pics of the wiring, please let me know and point us in the right direction.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 02-28-2011, 04:16 PM   #336
es67chevy
es67chevy's Avatar
Eric.
Basically, that was it. I just eyeballed where I wanted it to end up under the dash and then made a mark. Then we found the centerline of the column and marked that. Then we duplicated the size of the opening off the centerline and checked it against what the FAQ says the hole should be. We have a truck neutral safety switch instead of a van switch, so we didn't have to cut into the inner steering column tube like the FAQ shows (http://67-72chevytrucks.com/vboard/s...d.php?t=147927). Instead, I just manufactured a little tab to screw in to the inner column. The moving part of the switch just sits right in that metal tab I made. You can see the tab in the pic with the green tape. I used a small cutoff wheel to make the bigger cuts and finished the small cuts and ends with a Dremel. Took about two hours total I would say and that included removing the column from the truck and putting it back in.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 02-28-2011, 04:28 PM   #337
c10/72
c10/72's Avatar
Thanks man, that just made my life a lot easier...I will definately get this done this week.
Thanks again Eric.
Eric.
Old 02-28-2011, 04:34 PM   #338
es67chevy
es67chevy's Avatar
Thanks again Eric.
Eric.
No problem! Was scared to death I was gonna mess something up at first but once I started, it wasn't bad! Contact me if you need any help.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-01-2011, 08:40 PM   #339
es67chevy
es67chevy's Avatar
OK, so running into a problem installing my A/C controls. I'm wondering if I'm missing a part or if something else is wrong. I can't get the A/C controls to line up with the mounting holes in the dash. Can someone tell me what I'm doing wrong or missing? Hopefully these pics will help. Basically, the mounting points on the dash are further apart than the points on the a/c controls. Also, when the controls are flush in their slot, the mounting points are about 3/4" - 1" away from the mounting point on the dash.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-01-2011, 10:50 PM   #340
oilyrag80
oilyrag80's Avatar
I ran in to that once ended up being a setup out of a car impala i think
oilyrag80 is offline   Reply With Quote
Old 03-01-2011, 11:45 PM   #341
es67chevy
es67chevy's Avatar
Ugh. I hope not. I think ours looks like the ones I've seen on other threads, but never found anything else to indicate if there is more to it.
I posted this same request for info in the main message board and someone said it looks like we are missing a bracket. Here is a link to that thread:
http://67-72chevytrucks.com/vboard/s...=1#post4523757
He included a picture of one as well. If anyone knows what it is called, let me know.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-02-2011, 11:01 AM   #342
67cheby
67cheby
67cheby's Avatar
you are missing a bracket you can borrow mine if you need it and get me another one....it might be a while before i need mine !!
Old 03-02-2011, 01:13 PM   #343
es67chevy
es67chevy's Avatar
Hahaha! Nah, you're catching up with me, but I appreciate it! You'll need it before you know it. If I knew the official name, I'd just post a WTB. Guess I'll go for description and a picture of it.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-03-2011, 11:53 AM   #344
my67chevytruck
Under Construction
my67chevytruck's Avatar
Nice progress Eric. you should'nt need the horn relay since your installing a new wiring harness.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-03-2011, 01:29 PM   #345
es67chevy
es67chevy's Avatar
Thanks for confirming that for me, Heath. I was hoping that was the case, but hadn't been able to confirm it. I know the Painless kit had said nothing about it so was hoping it wasn't just omitted.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-10-2011, 12:06 AM   #346
es67chevy
es67chevy's Avatar
Getting close to installing motor (we think). From past experience, is it very difficult to install the inner fenders AFTER the motor is in? We'd rather do the inner fenders after to give us more room and keep us from messing em up, but when we did some test fitting a while back, it seems like we used some of the space where the engine would normally be sitting.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-10-2011, 10:35 AM   #347
67cheby
67cheby
67cheby's Avatar
its not any harder with the engine in or out in my opinion !! so i would just wait and put them in last
Old 03-10-2011, 10:38 AM   #348
es67chevy
es67chevy's Avatar
Thanks, Mike! BTW, I'm jealous of your freebie speakers. I love Kicker products! I used to live in Stillwater so had access to discounted stuff, but never FREE!!!! Argh! Good score.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-10-2011, 10:54 AM   #349
67cheby
67cheby
67cheby's Avatar
there is not a whole lot of perqs with my job .....but this is one !!
Old 03-10-2011, 01:13 PM   #350
my67chevytruck
Under Construction
we put the inners in after the motor was installed as well. remove tire, drape blanket over rotor and aframes, tape up fenders etc, then install....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
