Old 09-02-2010, 07:02 PM   #326
smokedat
smokedat's Avatar
Re: LS1 into a 73 cheyenne
Thanks for the valuable info. can you send me a link of that ebay auction.
Originally Posted by 68 TT View Post
With 5 on 4-3/4 bolt pattern you can run Vette or Camaro brakes. 98-2002 F-body rear disc is really popular and are 12" diameter with an internal drum in hat parking brake. They even came on the 6-cylinder cars of that era so they are pretty easy to find. I got a complete set with e-brake cables and the brake hard lines for under $100 on ebay. Since you are having the housing narrowed you can just have them put on the Strange small GM housing ends while they are at it so stock Chevy car brakes will bolt right on and you still get the press-on bearings & retainer plates.
You could turn a stock rotor into a bearing hub, drill it for 5 on 4-3/4 and use Vette or Camaro slip on rotors up front. Many size options from 12x1.25" on up. You could fab up a caliper mount bracket to use the matching PBR calipers up front or run the Wilwood D52 calipers at all four corners.
smokedat is offline   Reply With Quote
Old 09-02-2010, 07:18 PM   #327
68 TT
Still plays with trucks
68 TT's Avatar
I got mine a while ago but here is another one as an example.
http://cgi.ebay.com/ebaymotors/1998-...item3cb070e88b
His ad is wrong. They are 12" diameter x 1" thick rear rotors not 11".
You could always get this instead
http://cgi.ebay.com/ebaymotors/04-Po...item53e22ba9a5
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-02-2010, 07:21 PM   #328
68 TT
68 TT's Avatar
Here is another one for only $125
http://cgi.ebay.com/ebaymotors/1998-...item1e5e112f79
He will even knock $20 off if you don't want the old rotors. Pick up some nice cross drilled ones to use instead.
Old 09-02-2010, 07:27 PM   #329
smokedat
smokedat's Avatar
What will it take to install these as far as fabin a braket or modifying an existing braket, maybe a weld on braket . there off a 09 Chevrolet Corvette ZR1 Brake Caliper SET OEM
Old 09-02-2010, 08:12 PM   #330
smokedat
smokedat's Avatar
98-02 Camaro to Corvette C5 brake conversion brackets wonder if this will work on a c6
Old 09-02-2010, 11:41 PM   #331
68 short step
where did you find those brake conversion brackets?
68 short step is offline   Reply With Quote
Old 09-02-2010, 11:43 PM   #332
3r!c84
Badass
3r!c84's Avatar
all out!!!! nice
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-02-2010, 11:52 PM   #333
smokedat
smokedat's Avatar
i found them on ebay heres a link http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
i askd him if they would work on C6 calipers and this was his reply
quote - C6 cal. will bolt to these. The c6 rear cal. will bolt
to the stock Fbody abutment. You dont need a sp. brk.b Dale
Old 09-03-2010, 12:02 AM   #334
smokedat
smokedat's Avatar
found some more pictures of these conversion brakets
Old 09-03-2010, 09:44 AM   #335
nlped
nlped's Avatar
I was thinking about maybe upgrading my McGaughy F & R kits by using the 2010 SS Camaro/Brembo calipers. There 4 piston and I think I could build a bracket to work properly.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-03-2010, 12:11 PM   #336
smokedat
smokedat's Avatar
those brembos look sweet bet they break ewaven sweeter
Old 09-03-2010, 01:50 PM   #337
68 TT
68 TT's Avatar
The fixed mount calipers should be easier to fab up brackets than the floating mount D52 style calipers would be.
A little quality time with a spare spindle & rotor and a mill / lathe is all you need.
The third gen F-body guys cut off the stock caliper brackets and use the dust shield mounting bolt points as caliper mount points. You may be able to do the same or even use the old caliper mount bolt holes to hold the caliper bracket for the 09 Vette parts.
Old 09-04-2010, 09:28 AM   #338
N2TRUX
Happy to be here
N2TRUX's Avatar
The difference being is those kits us stock rotors. The McGaughy kit is the only "reasonable" priced kit on the market that runs 13" rotors F&R.
Niped- Have you read this post? "Just bought some calipers, any ideas if I can make them fit?"
Originally Posted by way2lo2 View Post
Getting the calipers to fit is easy....finding wheels that aren't from a 2010 Camaro to clear the calipers is going to be your bigger problem. The Camaro brakes need nearly as much caliper clearance as the Z06. Your best bet will be to try a 13" C4 96 Grandsport front rotor.....
Have you been able to determine what the OEM application is for the front caliper? I know it's late model GM, just don't know what. If you can find the intended application, it's possible that one of the aftermarket suppliers offers a larger caliper as a direct replacement.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-04-2010, 02:17 PM   #339
nlped
nlped's Avatar
Ken, I hadn't read that one. I have plenty of room to clear the caliper, just would have to fab the caliper mount, which wouldn't be to tough to do since the McGaughy spindle is already machined to accept a fabbed bracket. I just need to find out how large the diameter of the SS rotor is, and decide if it's something I want to pursue.
Carter
Old 09-05-2010, 06:23 PM   #340
smokedat
smokedat's Avatar
i got the tires in on saturday these things are massive still waiting on the wheels here are a few pics
Old 09-05-2010, 08:13 PM   #341
nlped
nlped's Avatar
SEXY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Carter
Old 09-05-2010, 08:18 PM   #342
kvn1011
Kvn1011
kvn1011's Avatar
DAAAAAAAAAAAAYUM!!!!!!!
kvn1011 is offline   Reply With Quote
Old 09-05-2010, 08:38 PM   #343
v502
v502's Avatar
WOW very nice build I just love it great work man.
v502 is offline   Reply With Quote
Old 09-07-2010, 12:37 AM   #344
82chevy350
82chevy350's Avatar
This truck is gonna be amazing
Drive It Like Ya Stole It
'82 Primer White c10 2wd LWB 350 sbc t350
(Hot Rod)
'90 2wd LWB Silverado 350 tbi 700R4
(Daily Driver)
'53 m38a1 Willys Jeep
(Toy)
82chevy350 is offline   Reply With Quote
Old 09-07-2010, 01:01 AM   #345
nbpro
awesome build
nbpro is offline   Reply With Quote
Old 09-07-2010, 08:20 PM   #346
smokedat
smokedat's Avatar
the rear is off
Old 09-07-2010, 08:25 PM   #347
smokedat
smokedat's Avatar
also finishd muding andspraying the interior of the cab. I shaved all of the ulphostery trim holes, sun visors and upper seat belt holes. It will all be painted and left exposed
Old 09-07-2010, 08:29 PM   #348
smokedat
smokedat's Avatar
also finished the radiator support, upper holes and bettery tray holes and ac heater holes were shaved. The extruding lip around the radiator was cut. I slaped on sum POR 15 on the bottom face
Old 09-07-2010, 08:37 PM   #349
smokedat
smokedat's Avatar
To shave the cab seam i used sum 3M 3M 8115 PANEL BONDING ADHESIVE then i used a die grinder to sand it flat, this method is by far the fastest and its just as strong as a weld. The only problem is that this panel glue absorbs paint to prevent this i over sanded then i will apply a thin layer of either body filler or glaze.
Old 09-07-2010, 08:43 PM   #350
smokedat
smokedat's Avatar
as far as mudding goes the roof is the last of it. First layer shown here, still needs more work
73c10, c10, cheyenne, ls1, swap
