10-28-2012, 09:30 PM | #326 |
GMC's n H.D.'s too!
Re: '60 GMC 4x4 Long Fenderside
Thanks Tony!
10-28-2012, 09:32 PM | #327 |
GMC's n H.D.'s too!
Thanks Kro, I'll keep that in mind! LOL
10-28-2012, 10:30 PM | #328 |
Chevy Enthusiast
Sure thing Jason.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
10-28-2012, 10:43 PM | #329 |
10-28-2012, 10:46 PM | #330 |
GMC's n H.D.'s too!
Thanks for the heads up! I will try to be careful and not get any on it. Is there a better one available, or are we stuck with this one?
10-28-2012, 11:04 PM | #331 |
Steele Rubber products has one, their part number 70-1942-41.... $30
10-28-2012, 11:07 PM | #332 |
GMC's n H.D.'s too!
Thanks bhc41051!
11-03-2012, 09:24 PM | #333 |
Full read on this thread and your daughters thread. Life sucks during the big "D", been there myself. Had to steal back my gray '67Camaro too.
Making great progress on the truck. Got me watchin' Subscribed. |
11-03-2012, 09:55 PM | #334 |
GMC's n H.D.'s too!
Thanks Bomp!
I have been following your thread. My son and I both love the idea of stretching the cab like that! We didn't get much done today. We went and got some more parts from 63 Spud this morning. This afternoon we put in the choke cable, finished painting the differential covers, cleaned up and straightened up the garage a bit, and plotted and planned our next step. Almost forgot the kick-butt pulled pork we made today too! YUMMM! Going to work on a friends car tomorrow morning, then hopefully get back to playing in my garage tomorrow afternoon. |
11-25-2012, 10:59 PM | #335 |
GMC's n H.D.'s too!
Actually got to spend some time on the truck this weekend.
Took apart the front hubs, cleaned everything up, repacked the bearings, and put it all back together. Here is my son working on his side. He watched me do the first side, and pretty much did his side on his own. We put the differential covers back on, and filled them. We drained the transmission and he transfer case. The fluid in the transmission came out a little dirty, but not too bad. The fluid in the transfer case came out sparkly and full of glitter. So either it is some old fashioned fancy gear oil, or I have a problem! We also had gotten a new transmission hump from 63Spud. Mine was rusted pretty bad. His had an odd hole cut in it. We cut a patch panel out of my original one, and have it ready to weld in next weekend. |
11-25-2012, 11:47 PM | #336 |
Hey, that is awesome that you and your son got to work on it together! Also, your patch for the trans hump is nicely done. Keep up the progress whenever you can and cherish those times working with your son.....
C@rnut001 (Owen) Alaskan Members Check In http://67-72chevytrucks.com/vboard/s...22#post5094422 http://67-72chevytrucks.com/vboard/s...18#post6778618 |
11-26-2012, 02:22 AM | #337 |
looking good man! heads up when you do the breaks i been finding all the 4x4 parts are only listed under 1960 chevy.
Car & Truck Projects Google Community. https://plus.google.com/communities/...80679980403145 Youtube channel. http://www.youtube.com/channel/UC2HB...view_as=public 1964 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=419525 |
11-26-2012, 08:47 AM | #338 |
The hole in the trans cover looks like it was for a hand lever emergency brake.
Work on your truck & spend time with your son , life is good.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
11-26-2012, 11:01 AM | #339 | ||
GMC's n H.D.'s too!
Life is definitely good Dually! |
11-26-2012, 03:15 PM | #340 |
not really got some stuff back together and started tearing into the breaks witch has been a head ace so far but i think i about got everything tracked down and figured out now trying to get it road worthy before the snow hits again but we will see cash flow is not very good right now!
12-21-2012, 07:35 PM | #341 |
Just finished reading both your build threads Jason.
Inspiring. Thanks for posting up with many photos. |
12-30-2012, 02:23 PM | #342 |
GMC's n H.D.'s too!
Ok, I have been slacking on the updates! We haven't gotten a whole lot more done recently, but here is what we have accomplished.
We have found that every seal on the drivetrain is leaking... all over the floor. So much for putting in new fluid. LOL My son (Chevyman10) came up with a cool custom idea for the glovebox. It had an old wooden cabinet knob under the latch. His idea was that since there was already a hole there, why not take one of the extra gray knobs I had, we used a windshield washer one, cut it down to look right, fill it with epoxy, and make the knob match the rest of the dash. Here is the finished result. We also welded in the patch panel on the trans hump. There are still some pinholes I need to fill, and some low areas, but it is much better than the original one! |
12-30-2012, 02:27 PM | #343 |
tell your son i have officially stolen the glove box knob idea looks sweet!
12-30-2012, 02:40 PM | #344 |
GMC's n H.D.'s too!
This weekend we were working on the blinker switch. There is a little top hat looking piece of plastic that rides under the metal plate, and against the, squiggly, yes, I think that is the actual technical term for it, piece of metal on the right for the detentes, that is broken. The switch works physically now without it, but I don't have power to it, to see if it actually works.
Also we tore apart the heater controls, to see if we could make one good one using a spare I got from a board member. Turns out that I will still need an additional lever for in side the controls. One of the levers I needed, has a stress crack in it already. Oh well. Anyone have one lying around?? |
12-30-2012, 05:42 PM | #345 |
GMC's n H.D.'s too!
I'll let him know Kro!
12-31-2012, 03:01 AM | #346 |
If all else fails, LMC does list those levers....
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
02-24-2013, 04:02 PM | #347 |
GMC's n H.D.'s too!
Here is my son's new to him truck!
http://67-72chevytrucks.com/vboard/s...d.php?t=567768 More to do now!! |
03-01-2013, 12:04 PM | #348 |
GMC's n H.D.'s too!
Got a new Master Cylinder for my truck. I'll just go into parts accumulation mode for a bit, while we work on my son's truck. His is further along, and spending his money for parts is fine by me!
03-05-2013, 09:39 PM | #349 |
i have a real 60 chev 4x4 out of cal and my transfer is on the right also and its never been touched also one on e bay right now and its also on the right ken
03-05-2013, 11:22 PM | #350 |
GMC's n H.D.'s too!
Thanks Ken!
Tags |
1960, 4x4, 60-66, gmc, k1000 |
