Old 05-26-2013, 07:31 PM   #326
Bubba54
Re: 58 TRUK intro
Awesome truck OGRE. Attention to detail is incredible.
Bubba54 is offline   Reply With Quote
Old 05-26-2013, 09:26 PM   #327
DransportGarage
DransportGarage's Avatar
Re: 58 TRUK intro
It's a shame to see fiberglassforms.com go away. I too learned a lot over there (mostly from Ogre's posts). So much for the paperless society...
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 05-27-2013, 09:36 AM   #328
andsonsvd
andsonsvd's Avatar
Re: 58 TRUK intro
Yes its a shame FGF are gone I would have loved to see Ogre's build thread.
Ogre you did a fantastic job!!
Shane
Australian GM/Holden Dealer
1937 Chev Rod - LS1/4L60E
1949 Chevy 4400 Dually - 235ci/4L60E
1958 Chevy Apache Fleetside SBC/T400
andsonsvd is offline   Reply With Quote
Old 05-27-2013, 09:45 AM   #329
DransportGarage
Re: 58 TRUK intro
Shane
It's OK. Ogre will rebuild the thread here! IIRC he already had to do it once before when it got trashed on FGF! (U can thank me later, Ogre.)
Bob
Old 05-27-2013, 12:46 PM   #330
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
thanks for the kudos guys
fiberglass is fun, cheap and fairly basic once you figure out how to form it.
i need to photoshop a brake pedal in that pic. every time i post it some wise guy comments on it
dransport, that WAS my feeble attempt at a thread rebuild. 6 yrs of build pics and comments in that thread
did you ever do do anything with you new fg skills?
shop air compressor timer
Old 05-27-2013, 09:49 PM   #331
andsonsvd
andsonsvd's Avatar
Re: 58 TRUK intro
Take the Kudos as motivation to recreate the build thread I want to see/read it!!
Thanks Shane
Old 05-27-2013, 10:13 PM   #332
DransportGarage
Re: 58 TRUK intro
Originally Posted by _Ogre View Post
<snip>
Yeah, my back panel is done, the console and dash skirts are half done and the speaker pods are started. Unfortunately, the wife has me building a new deck and she wants the house trim painted, etc. No work on the truck this year so far, but I'm hoping to start up again late June.
Bob
Old 05-28-2013, 11:10 PM   #333
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
you told the wife "It won't take long and it won't cost much."
didn't you
Old 05-28-2013, 11:12 PM   #334
DransportGarage
Re: 58 TRUK intro
didn't you
Well, it IS the epitath that's going on my tombstone!
Bob
Old 09-01-2013, 02:11 AM   #335
wwillmon
Re: 58 TRUK intro
Hey ogre, know its been awhile since the thread has been posted in but im the one that had the questions.
When your making things such as the radiator cover, wiper cowl, steering column cover, etc. Are you just shaping it out with cardboard, then taping the cardboard into place, then fiberglassing over the cardboard, and once dried, peeling it apart from the fiberglass and strengthening it?
Im sure not sure on how to get some certain shapes that your making, such as the steering column cover, how its so round and everything. Im really interested in glassing and pretty disappointed i never got to check out the fiberglass forum, so let me know if its anything you could help explain.
wwillmon is offline   Reply With Quote
Old 09-01-2013, 01:13 PM   #336
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
i wish the link for fiberglassforums.com still worked, i had detailed pics of the forms i used in my interior build thread.
i used a mixture of cardboard, plywood, plastic, mdf frames, staples, hot glue, fabric, masking tape and paste wax to make each form.
nothing is molded in the sense of making a mold, fiberglassing and popping the finished product out of a mold.
many of the forms are left in place, some are removed if it's possible and some forms are partially removed.
the radiator cover is mostly cardboard and masking tape
first i taped cardboard on the radiator to give some space to keep heat off and allow for air circulation
then i formed up the shape i wanted with more cardboard
once i get the shape i wanted, i covered everything in masking tape and waxed the surface with paste wax.
you can see the angle brackets that bolt to the upper radiator bolts here.
fg makes a mess. cover everything in news paper and start glassing
this is the rough form glassed with paper removed
then i pulled the form off and added more glass to the underside
since i waxed the tape over the cardboard form, all of the form came out of this piece.
i had to use wax and grease remover and then rough up the inside with 36 grit to apply more glass.
after some reshaping i started finishing it. basic body work. filler and block sanding
fiberglass is full of pin holes, everything needs to be covered in filler.
the filler needs to be primed enough to hide all the pin holes and blemishes.
then add some paint.
Old 09-01-2013, 01:35 PM   #337
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
the steering column cover is made out of cardboard mailing tube, plywood and a mdf piece i made to go finish fit the steering column.
the dark areas are cardboard mailing tube, i pie cut the tube to make the curve to follow the dash.
hot glue, staples and super glue temporarily hold everything together until you glass it.
then glassed over everything, i glassed most parts in place so that they held their form.
you can see tape over my finished dash, i waxed the dash but not wax anything on the form as i wanted the glass to hold to that part.
there are hidden bolts embedded in the wood to fasten everything in place once your done.
most of the form is still in place on this piece, i pulled out some cardboard, but most of the wood is still there.
here you can see some of the brackets i welded to the dash to hold everything in place
this is the finished shape painted. it changed shape a couple times to cover the hi beam switch and neutral safety switch and associated wires.
Old 09-01-2013, 01:45 PM   #338
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
this is the right side of the dash fascia.
made of a piece of plywood with fasteners in it and then cardboard mailing tube for the curved portions.
i did not wax anything here, most of the form is still in place.
cardboard impregnated with resin is pretty much permanent and structural
again, i built and glassed this in place, bolted to the dash so it would hold it's shape.
waxed tape protected the finished dash.
Old 09-01-2013, 02:01 PM   #339
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
part of the challenge of doing any fiberglass work is securing it in place and making it removable.
some of my fasteners are obvious and in sight, most are hidden built into the item being fiberglassed.
but all the parts have to be able to unbolt for working on stuff under the dash.
most of my parts have captive bolts glassed in, so that a couple of nuts are all that is required to secure them in place.
there are 2 exposed fasteners in my whole dash/console, 2 big bolts into the steering column.
i figured out later they were not required due to all the other fasteners i had in the column cover.
i used a lot of T-nuts and bolts for the console and armrest.
Old 09-01-2013, 02:08 PM   #340
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
i hope i answered all your questions.
if not ask here and i'll do my best to answer.
fiberglassing can be a little intimidating when you start out.
use mdf frames for openings like the radio, ac vents, speakers and end pieces.
free form shapes require a little thought and a glance around the shop to see what is on hand
once you figure out that any shape can be made and glassed, the world is your oyster...
Old 09-01-2013, 08:37 PM   #341
arturo7
arturo7's Avatar
Re: 58 TRUK intro
Mickey's Big Mouth?
I remember that stuff, sorta...
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 09-01-2013, 08:40 PM   #342
OrrieG
OrrieG's Avatar
Re: 58 TRUK intro
I once got 24 bottles of Mickeys free. Girlfriends mom wanted the bottles for spices.... never drank another after that.
OrrieG is offline   Reply With Quote
Old 09-01-2013, 08:54 PM   #343
arturo7
arturo7's Avatar
Re: 58 TRUK intro
Went to a Halloween party back in the day. Stopped at a liquor store and bought a last minute costume; a 40 of Mickey's in a paper bag.
ever forward
Old 09-01-2013, 10:48 PM   #344
fluffyfreak
Re: 58 TRUK intro
That Mickeys is some rough stuff, reason they use a bee as their logo! Ogre, any pics on the formation of your tonneau cover? Id love one like that for my dime, and my nissan.
fluffyfreak is offline   Reply With Quote
Old 09-02-2013, 12:22 PM   #345
lowrodderchev
lowrodderchev's Avatar
Re: 58 TRUK intro
Looks like its beer-30 already lol
lowrodderchev is offline   Reply With Quote
Old 09-02-2013, 10:57 PM   #346
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
mickey big mouth has made more than one visit to my shop
i have a mickeys beer sign in the shop too
Old 09-02-2013, 11:10 PM   #347
fluffyfreak
Re: 58 TRUK intro
Mines littered with PBR and coors light lol
Old 09-02-2013, 11:18 PM   #348
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
i cut curved 2x4s to match the shape of my trunk and attached plywood to it
i taped foil on the plywood. bad idea, i should have primed the plywood and then waxed it to release the fiberglass.
the foil made the glass wavy, i've used foil before on smaller parts with good results.
this took a lot of work to get it smooth
after rough cutting the shape, i added ribs for comfort... i meant for strength
added glass on top of the ribs to make them homogeneous
and added steel plates to attach the hinges
body finished the top, 5 coats of primer, endless hrs of block sanding and add paint
Old 09-02-2013, 11:25 PM   #349
fluffyfreak
Re: 58 TRUK intro
Awesome, thanks!how many layers of mat did you use?
Old 09-02-2013, 11:26 PM   #350
arturo7
arturo7's Avatar
Re: 58 TRUK intro
yowsa
ever forward
