#326 |
Re: Mike's 50
KansasT
I used this information from the manual that came with connect and cruise "Mass Air Flow (MAF) Sensor NOTE: It is critical that the MAF sensor is mounted per the instructions below. Vehicle performance and/or driveability may be affected if it is not mounted as recommended. The Mass Air Flow Sensor must be installed in the induction system using the supplied MAF sensor mounting boss. The induction system should be 4 inches in diameter and have a minimum straight section 6 inches in length. Mount the MAF sensor in the middle of the straight induction section, ensuring that the middle of the mounting boss is at least 10 inches from the throttle body. The MAF sensor must be oriented correctly in the induction Be sure to weld the mounting boss correctly – the sensor will only mount one way in the boss (see diagram). Weld the boss in place before installing the sensor. When installed in the vehicle, the MAF sensor should be mounted with the connector end pointing between horizontal and fully upright – do not mount with the connector oriented downward."
1950 3100 5 window Last edited by MIKESAD50; 07-20-2017 at 10:00 AM. |
#327 |
Re: Mike's 50
Mike, I'm a little late to the game. I think you've got some great responses in regards to the issue at hand. 80psi is definitely way to high for a stock LS3, that's close to 5.5 bar, way over the 4 bar (58psi) needed for the LS style fueling. No matter what, however, it's going to be smelly without cats, I see you're in CA but didn't see any in the last picture posted. That pump is huge for a stock engine and will flow more volume than it will ever need, but the regulator should be doing its job. Might just be a bad one.
You've put together quite a ride, very nice work! Lots of attention to detail.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
#328 |
Re: Mike's 50
OutlawDrifter,
I know I went over board on the pump but did it with intention in the future of adding power, supercharger, etc. My first thought was bad Wix filter, replaced with AC Delco, and this is the 2nd of the AC Delco. I know with out cats it will "stink" but this is eye watering. Thank you for the compliment.
1950 3100 5 window |
#329 |
Post Whore
![]() ![]() Join Date: May 2015
Re: Mike's 50
On the maf issue I measured my factory ls3 intake tube...the maf is 22" from the throttle
#330 | |
Re: Mike's 50
I'm a big proponent of Wix filters, and generally use them over AC Delco. Might just need the better regulator set up as suggested.
#331 | |
Re: Mike's 50
#332 |
Post Whore
Re: Mike's 50
Mike,, I think I remember a few weeks ago someone on here on the ls swap side was having issues with the 340 pump pressure and aeromotive told them he needed to use their regulator...can't remember who it was
#333 |
Re: Mike's 50
Outlaw, I didn't mean any disrespect either and none taken. I'm taking all this advise and going use it and respect all you guys.
I've been a strictly Volvo tech for 28 years with a little experience with other makes and none with the LS. Kansas, I will look into moving ANN. I figure 1 step at a time, get Fuel PSI to specs first then if still a problem I will see what I need Next. I have UP Tuners on my list of purchases soon. I see that there are gains with some tuning, and I would really like to learn it.
1950 3100 5 window Last edited by MIKESAD50; 07-20-2017 at 10:00 PM. |
#334 |
Re: Mike's 50
Mongocanfly,
I was told by Aeromotive that the corvette filter a 340 killer. Not sure exactly that meant but figured they wanted nothing their components used together
#335 |
Re: Mike's 50
New Holley fuel filter/Regulator assemblies arrived today. Its designed for LS transplants. Fully rebuildable, filter replaceable, It's big also.
10 micron filter, and set to 59.5 psi and flows plenty according to specs. Hope to get in this weekend. I'm going to get it weighed tomorrow morning to finish title and registration process, then on to Insurance. What are you all dong for insurance? agreed value, companies?
#336 |
Re: Mike's 50
forgot pictures.
About 7 inches long and 3.5 with no fittings
#337 |
Re: Mike's 50
If the connect and cruise stuff uses a tune like the factory LS3, there is a lot of improvement to be had in the fuel and spark tables.
When I had the 6.0l in my 2500HD tuned, it amazed me how much was left on the table. It feels like it it has the advertised 380hp now.
#338 |
Re: Mike's 50
Weight certificate in hand, 1 step closer to being legal.
3200lbs with full tank of gas, bed wood, strips, running boards, etc in it.
#339 |
Re: Mike's 50
Well I haven't updated in a little bit. I got my plates in the mail last night. The last couple weeks I have been doing little things and not much worthy of update or pictures.
I have been playing with the tune using HPT tuners to try an get it better, work in progress. I will be making my first trip home today in the truck. I have put nearly 20 miles on it around the shop area.
#340 |
Re: Mike's 50
Let her RIP !!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#341 | |
Re: Mike's 50
Thanks!
Scott ______________ my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979 |
#342 |
Re: Mike's 50
Scott the number from Summit was Der-15850.
I've just started driving and using data from TCM it is showing temps in the 200-215 or so range so far. I haven't been in high heat but slower traffic in the 80's. I also have not mounted the right side running board so could be getting extra air. I plan on talking to my transmission guy about temps, the GM program shows red in the 240* range
#343 | |
Re: Mike's 50
#344 | |
Re: Mike's 50
On the cooler - I see there is at least one larger size as well - any reason you picked this one - maybe fit? Your tranny does seem to be running hot - I doubt it's the cooler sizing but I also did not see how you routed the lines. Did you loop through the radiator and the cooler both? Also another question - from your post 218 - your brake pedal looks a bit high and you were going to adjust for clearance to the column. Where did you end up with it on height from the floor? Mine is currently at about 8" and feels too high. I am thinking about scavenging a pedal arm from the u-pick yard and lowering it a couple of inches. Thoughts on this? Thanks again - great build and love to see it running!
#345 |
Re: Mike's 50
Scott, Thanks. I did not run cooler thru radiator.
I haven't changed brake pedal. I don't feel it is to high, not enough clearance between gas and brake pedal. I was planning on moving pedal pad over to the left for clearance.
#346 |
Re: Mike's 50
Haven't post in a little bit.
I have been driving the truck and for the most part problem free so far. I got 750 miles on it, still knocking things off the list. Have a lot to do still. Took it to a local free show Saturday. didn't really take many pictures. It was HOT! alot left early and I heard alot didnt even come because of the heat.
#347 |
Re: Mike's 50
Hell yeah Mike. Congrats.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
#348 |
![]() Join Date: Mar 2011
Re: Mike's 50
Driving them is what it's all about...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#349 | |
Re: Mike's 50
#350 |
Re: Mike's 50
Scott2
It still runs up to 190-200ish depending on how I drive and also most of the driving I do is stop and go commute traffic. I figure it would be the same aprox. as coolant temp if run thru the radiator cooler since coolant temp runs in the 200-205 range while in traffic. Not sure if I will move it yet or not. I think if I wrap the exhaust that might help some also. over 1325 miles and only issue so far was running out of gas once, and also had a failure of throttle system yesterday and had no pedal response, cleared throttle position sensor code and running fine again so far. Settling on the right alittle more than right side so I will swap shocks left to right
