Old 11-26-2022, 01:25 PM   #326
joedoh
joedoh's Avatar
Re: Francis the Tow Pig - 1949 GMC 250 Dually
woooop that looks pretty great!
PS - Thanks Russ for the info on cutting the bottom of the spring!
I noticed you had to go 3/5ths instead of the 1/4 I said, but did you taper the end?
looks great man!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 11-26-2022, 01:42 PM   #327
OutlawDrifter
looks great man!
Thanks, Russ! I didn't taper the end, trying to keep the heat down on the coil. I figured with my 600+ lbs over an ECSB V6 rig, the 1/4 wasn't going to be enough.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 11-26-2022, 02:16 PM   #328
joedoh
joedoh's Avatar
haha the taper adds the extra! the original coil is flattened on the end but when you cut off the 1/4 it is at like a 60 degree angle to the pocket, tapering lowers it that little bit and in my opinion helps it fit the pocket.
so potato potatto, same diff!
more than one way to skin an apple.
Old 11-28-2022, 10:16 AM   #329
OutlawDrifter
When I first built the truck back in 2017, I had to remove the carrier bearing cross member when I went to a 1-piece driveshaft. Decided it was time to replace it with something to help tie the frame together a little better, and at the same time reduce some flex.
Started with some angle for the frame brackets:
Tubing cut to length and ready to be tacked in place:
Melting it all together:
Painted up and installed:
With it being mounted below the frame, it clears the exhaust and driveshaft with plenty of room to spare. With the 1" height, it also remains above the lowest point on the pickup.
1991 Z/28, 6.0L/T56
Old 11-29-2022, 09:15 AM   #330
joedoh
joedoh's Avatar
nice work, very strong!
Old 11-29-2022, 09:50 AM   #331
OutlawDrifter
Thanks Russ! 3/16" angle and 11 gauge 1x2" tubing should be plenty.
1991 Z/28, 6.0L/T56
Old 12-02-2022, 07:46 PM   #332
joedoh
joedoh's Avatar
you can jack it up on that!
