Old 09-30-2018, 10:22 PM   #326
Joe Pass
Joe Pass's Avatar
Re: Brother's keeper - '58 Stepside build
Great job congrats......
Joe Pass is offline   Reply With Quote
Old 10-14-2018, 01:06 PM   #327
Black_Sheep
Black_Sheep's Avatar
I have managed to put about 100 miles on the truck in the past couple of weeks, so far the issues have been pretty minor.
Anyway, I drove it to the Twin Cities Roadster swap this morning and it began to snow. Driving it in bad weather was bound to happen sooner or later, now I have that out of the way...
https://www.facebook.com/mark.wells....2851068085699/
Black_Sheep is offline   Reply With Quote
Old 10-14-2018, 01:29 PM   #328
Indian113
Indian113's Avatar
How do you like the Heater you put in? That would have been a good test I think. Glad you got that beauty home safe and sound.
Indian113 is offline   Reply With Quote
Old 10-14-2018, 01:36 PM   #329
Black_Sheep
The heater and defrosters worked great, which is always a good thing in Minnesota...
Old 10-21-2018, 01:26 PM   #330
Black_Sheep
Getting some windshield time and sorting things out...
Old 10-21-2018, 11:06 PM   #331
oldman3
oldman3's Avatar
That's the best way, take care of little things as they pop up...Jim
oldman3 is offline   Reply With Quote
Old 10-22-2018, 02:55 AM   #332
joedoh
joedoh's Avatar
gorgeous and well executed build. very very nice work.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 10-22-2018, 10:27 AM   #333
Dan in Pasadena
Dan in Pasadena's Avatar
Yup. Just a very pretty, well designed build. Kudos!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 10-27-2018, 05:05 PM   #334
Black_Sheep
I fixed a few things and found a couple more. The passenger side valve cover is leaking pretty good, but the more I drive it the better it runs...
Old 10-27-2018, 08:04 PM   #335
Indian113
Indian113's Avatar
Sure Looks Nice, I really like that color Combo Good Job
Old 11-04-2018, 08:58 PM   #336
Black_Sheep
On Saturday I replaced the rubber valve cover gaskets with cork composite gaskets and got in a 40 mile cruise, just because I could. A couple more minor issues revealed themselves so I took care of them too. I'm still not 100% happy with the brakes, they will get sorted out this winter...
Pics from Saturday
Old 11-05-2018, 12:27 AM   #337
oldman3
oldman3's Avatar
Mark, what's with the brakes...Jim
Old 11-05-2018, 01:34 AM   #338
Dan in Pasadena
Hey Mark,
With 1000 miles on her now I assume you’ve driven it on a variety of highways and suburban streets. How much or how little road rash has it picked up on the front from ordinary driving?
It’s going to happen to my fresh paint but I’m just wondering if it has happened yet to yours?
Old 11-05-2018, 06:37 PM   #339
Black_Sheep
The pedal is hard but I think the truck should stop better. Vacuum is good and when I pull the line off the booster with the engine shut off there is vacuum at the booster. That tells me the check valve is good and the booster isn’t leaking. I’m thinking the pedal ratio is not what it should be. Maybe the Baer pads I used are not right for my application. I don’t know...
Old 11-05-2018, 06:40 PM   #340
Black_Sheep
Originally Posted by Dan in Pasadena View Post
Hey Mark,
I’ve logged a little more than 250 miles so far Dan, no road rash yet.
Old 11-05-2018, 09:02 PM   #341
oldman3
oldman3's Avatar
Mark, what master cylinder, and calipers are you running? Is mc a 1" or 1-1/8" bore. Sometimes it's a combination of things...Jim
Old 11-05-2018, 10:59 PM   #342
Black_Sheep
Jim I'm using GM D52 calipers (75 Nova) and a 70's GM power disc brake master cylinder 1.125 bore. The booster is a dual diaphragm 7", manufacturer unknown. Rear brakes are Mopar 10" drums. The pedal is rock hard but it requires more effort than I'd like.
Old 11-05-2018, 11:10 PM   #343
Black_Sheep
I used Baer "Sport" pads on the fronts
Old 11-05-2018, 11:25 PM   #344
Black_Sheep
According to this tech article the pedal ratio for power brakes should be 5:1, I'm going to have to take some measurements to calculate if it's correct or not.
https://techtalk.mpbrakes.com/how-to...ng-pedal-ratio
Old 11-06-2018, 12:41 AM   #345
oldman3
oldman3's Avatar
Mark, sounds like you got all the right stuff. Sport pads should be OK. Another way to check the booster is: With engine off, put foot on the pedal and push down, then start the engine, if booster is working the pedal should drop down about 1/2". I'll see if I can come up with anything else...Jim
Old 11-08-2018, 09:26 PM   #346
Black_Sheep
With the brake applied it drops about 1/2" when I start it. It's snowing again so I won't be driving the truck for a while, there's time to pull all of the wheels off and really look things over.
For the last 15 years I've driven modern trucks with big 4 wheel disc brakes, maybe I'm expecting too much.
Old 11-08-2018, 11:56 PM   #347
oldman3
oldman3's Avatar
Yes cars and trucks today have great brakes. I notice when I drive my car and then the next day drive the 50, it stops, but not the same. I'm thinking maybe this winter to switch to Wilwood D52 calipers. You go from a single 2.75 sq in piston to 2 - 2 sq in pistons (4 sq in total). This should make a difference. If I do I'll post it...Jim
Old 11-09-2018, 08:59 AM   #348
Black_Sheep
I’ve been looking at them too, I will probably do a rear disc swap first though.
Old 11-18-2018, 01:47 PM   #349
Black_Sheep
I threw the cover on the truck to see how it fits. There's still a couple things in need of attention, I'll get on them after Thanksgiving...
Old 02-02-2019, 06:04 PM   #350
Black_Sheep
Just detailing under the hood and waiting for spring...
