#326 |
Re: 1958 Saab story
I pulled it out of the shop and let it air up and measured at the rocker behind the front fender and in front of the rear wheel. It's 7 1/2 inches up front and 8 1/4 at the rear. It looks level enough for me not to mess with it, and it's not sagging in the rear.
-Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R |
#327 |
Re: 1958 Saab story
Well the exhaust issue is fixed, which was a huge relief. While driving around, I was trying to pay attention to the headlight coverage and cut off to make sure I'm not blinding oncoming traffic with 4 low beams. My driveway to the shop is a bit of an uphill, so I think it gives a pretty good example of the low and high beam outputs.
-Josh
#328 |
Re: 1958 Saab story
stance looks bang on to me, quite level instead of a big rake angle. lights are really bright too. do you get guys flashing their high beams from oncoming traffic?
#329 |
Re: 1958 Saab story
Surprisingly not. I thought for sure every other car would be flashing me, but I think maybe twice so far. A lot of people around the Atlanta area run their high beams, so I get to see their faces (literally) when I let them know with my high beams.
-Josh
#330 |
Re: 1958 Saab story
Rear shocks came in, so I replaced those.
-Josh
#331 |
Re: 1958 Saab story
I mounted and wired up a reverse camera. Has to pull the driver's seat and center console to run the cable, but everything works, so it was worth the effort.
-Josh
#332 | |
![]() Join Date: Nov 2018
Re: 1958 Saab story
That’s funny. I always wanted to add one since it had the right radio already.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
#333 |
Re: 1958 Saab story
Madkidd wanted to know what the truck weighed since the body swap. It was his Saab that I used as a donor and he said it felt lighter and more responsive when he drove it, so we weighed it at his dad's house with racing scales.
-Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R Last edited by Rickysnickers; 03-27-2022 at 10:10 AM. |
#334 |
Re: 1958 Saab story
Since the ignition switch is in the center console, I wanted to hide it and make it look like a cup holder.
-Josh
#335 |
Re: 1958 Saab story
I bought a "stash can" online, drilled out a slot on the bottom and secured the ignition key with epoxy. The only key I have to carry is the door lock key.
-Josh
#336 |
Re: 1958 Saab story
Madkidd told me my rear turn signals weren't very bright, so I replaced the top tail lights with another set. They're definitely brighter.
And I wired in a wiper switch, since the wiper setup I'm using is controlled with all power outputs instead of completing ground circuits like the factory setup. -Josh
#337 |
Re: 1958 Saab story
#338 |
Re: 1958 Saab story
that's absurd! i love it!
#339 | ||
![]() Join Date: May 2007
Re: 1958 Saab story
![]() ![]() ![]() ![]() ![]() might want to pop the top though, someone way less likely to steal a stale mt dew. ![]() ![]() ![]() ![]()
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#340 |
Re: 1958 Saab story
I took the day off work and spent my dad's birthday at the summit racing car show.
-Josh
#341 |
![]() Join Date: Aug 2010
Re: 1958 Saab story
Now that’s a great pair !
Father and son , oh and the trucks . Oh and Happy Birthday dad .
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
#342 |
Re: 1958 Saab story
I removed the old cardboard (probably asbestos) sounds deadening material and found a few surprises. Some really old matches and a mouse's nest
-Josh
#343 |
Re: 1958 Saab story
This is the same stuff I used on the roof of the Jeep. It kept oil canning at high speeds, and it fixed the issue, along with extra roof braces. It's called mat66.
After I finished putting everything back together, dad and I took it for a drive. It was loud and tinny before and conversations were muffled. Now I can have a normal conversation without shouting. -Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R Last edited by gottattooz; 04-23-2022 at 07:35 PM. |
#344 |
Re: 1958 Saab story
very nice
#345 |
Re: 1958 Saab story
Well the compressor went out for the rear suspension, and I had to save up because I bought another project. So $385.00 later, she's up and running. It was looking pretty pathetic in the garage with the rear wheels stuck in the fender wells, but I took her for a test drive to run through the gears and shake it down and everything's working correctly.
-Josh
#346 |
Re: 1958 Saab story
hopefully it was easy to get to with the new body on there
#347 |
Re: 1958 Saab story
The last one of those I changed was near the $1000 mark, CAD. you can also swap out to the coils, they are a direct drop in. All you need is the coils and rubber pads from a wreck ( or new ones)
#348 |
Re: 1958 Saab story
He is fully awAre. There is a reason why he left the air ride system.
#349 |
Re: 1958 Saab story
yeah, I figured he knew that, pretty sharp guy. just posted it for the lurkers in case somebody else is doing something with a trailblazer/envoy.
cool looking unit. |
#350 |
Re: 1958 Saab story
This is exactly the reason I made the floor panels removable. Putting the bolts in blind was fun, but I'm a diesel mechanic so I'm used to changing parts by feel instead of sight.
-Josh
