12-11-2021, 08:53 PM | #1 |
Post Whore
Re: My Dusty 71 GMCe Electruck
seems like all we have to do is remove 864 torx screws
12-11-2021, 08:54 PM | #2 |
Post Whore
for safety reasons you can't just hook up a Multimeter to a high voltage battery pack, you essentially need a car battery to turn on this battery
12-11-2021, 08:57 PM | #3 |
Post Whore
that's why we remove the lid and bypass the Pre Charge Circuit which contains contactors that otherwise have to be powered up, but this being a German product it ain't all that easy without fandangling with the BMS first I think, so forget that
not bad, that's 346 out of 351 vultures |
12-11-2021, 08:59 PM | #4 |
Post Whore
I did the same to only one of the six cell modules that are inside that battery pack
57.7 out of 58.5 that's pretty darn good |
12-11-2021, 09:01 PM | #5 |
Post Whore
I also took the opportunity to weigh one of them, and it came in at 27.7 pounds
so six of them only weigh 166 lbs, so if I double that it will be 332 pounds anybody know what a fully dressed Small Block Chevy weighs for a stare and compare? |
12-11-2021, 09:51 PM | #6 |
I’m seeing weights from 530-575 pounds.
12-12-2021, 04:05 AM | #7 |
Post Whore
thanks so that covers three of these packs which adds up to 498 pounds.
I am thinking we could add another 100 pound allowance for a full 16 gallon fuel tank full of gasoline (16 gallons x 6 lbs = 96 pounds) plus 10 lbs for 6 quarts of oil, plus the weight of the exhaust system and I think we are breaking even, even with four battery packs at 665 pounds. |
12-12-2021, 04:37 AM | #8 |
Think it is cool what you are doing. Electric performance and torque is real.
None the less I would never own an electric or do a conversion myself except for a local driver. Curious if you know what the motor/trans weighs. My aluminum block LSA 6.2 with 6l90 is in 700lb range. The 31 gallon tank I am installing full is around 200lbs. 31 gallons should allow over 400 miles range as long as I keep my foot out of it. What is the range you are expecting?
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
12-12-2021, 11:10 AM | #9 |
Post Whore
in this video we take a peak inside the BMW 530e plug in hybrid, high voltage battery pack
BMW 530e Plug In Hybrid HV Battery Pack |
12-12-2021, 12:54 PM | #10 |
Nice video. I did not realize the batteries were in series but I suppose that makes sense to get the higher potential. What is the voltage and variance that the motors are rated for?
12-12-2021, 01:02 PM | #11 | |
Post Whore
the pack I am using is from a different plug in hybrid car a BMW 530e which had a 350 volt battery pack. Based on the world's #1 best selling electric car, the Tesla Model 3 and the world's #2 best selling electric car the Nissan Leaf that's all we need as they both run 350 volt packs. It's what I call a full voltage pack. Of course they have a much larger fuel tank capacity if you will than my little 9.1 kWh one. hope that answers your question Last edited by Gregski; 12-12-2021 at 01:18 PM. |
12-12-2021, 01:23 PM | #12 |
12-12-2021, 01:29 PM | #13 | |
Post Whore
of course you are talking about power and I am focusing on capacity, I get that but the thought of doubling the voltage to over 700 volts did enter my mind if for nothing else a shot down a drag strip [Note To Self: upgrade front drum brakes to disc, lol] |
12-12-2021, 02:32 PM | #14 |
What range will you get with 4 packs?
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
12-12-2021, 02:53 PM | #15 |
Post Whore
12-21-2021, 02:46 PM | #16 |
Post Whore
thought you guys might enjoy this video of Jerry installing the same electric Tesla brake booster I am about to use in my EV Conversion in his 1995 electric Hummer
We stole the Brakes from a Tesla! - Totally Silent Electric Hummer? |
12-29-2021, 12:43 PM | #17 |
Post Whore
I got a chance to completely disassembly my BMW 530e high voltage battery pack and would like to share a video with you
BMW 530e HV Battery Pack Teardown Last edited by Gregski; 12-30-2021 at 11:47 AM. |
12-30-2021, 11:48 AM | #18 |
Post Whore
those pics are on top of a 2 foot by 4 foot piece of plywood for a size reference, looks like I can fit 9 batteries in that space
01-01-2022, 11:41 AM | #19 |
Post Whore
it was nice of these plastic pliers to show up right after I shot the last battery video, cause you know, safety third
01-03-2022, 12:53 PM | #20 |
Post Whore
yeah, it's winter and I am procrastinating, but when these brand new German (pronounced: "Expensive") BMW high voltage battery cables showed up, I decided to treat 'em right
01-03-2022, 12:55 PM | #21 |
Post Whore
they got these god forsaken never seen before dingle dangle proprietary connectors on 'em that are made from unobtanium
so they had to be liberated |
01-03-2022, 12:58 PM | #22 |
Post Whore
Why you ask? well we are trying to connect this German BMW 530e high voltage battery pack to a United Statesian Tesla Model S battery charger so that we can charge it and it's like fitting a square peg in a hole that's round
01-03-2022, 01:01 PM | #23 |
Post Whore
so over at our Organic Out Doors Precision High Voltage Battery Cable Modification Facility commonly referred to as the OODPHVBCMF
01-03-2022, 01:04 PM | #24 |
Post Whore
now we can provision a much more civilized connector such as this handsome Anderson SB120 in crimson red
01-03-2022, 01:12 PM | #25 |
Post Whore
and here is a super fun rant (not by me) on how not to treat an Anderson connector
WATCH THIS BEFORE BUYING ANDERSON CONNECTORS!!! SBX350 |
