11-26-2022, 07:43 PM | #3476 |
Re: What did you do to your truck today.The 3rd chapter
Well I started reassemling my passenger door. Got the DIY electric winder assembly in and working. Just need to finish it up tomorrow.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
11-26-2022, 08:00 PM | #3477 |
Looks good
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
11-27-2022, 11:04 AM | #3478 |
Redoing the bedwood on my stepper . Something got on it in the barn over last winter and discolored it . So I replaned it and sanded till it was acceptable . This time I’m using a marine waterborne spar urethane. So far it’s looking good reason I’m trying it is I need to do this in the basement so fumes wood stove and gas water heater don’t mix all that well .
11-27-2022, 11:27 AM | #3479 |
Looks real good
12-02-2022, 04:38 PM | #3480 |
The black real leather showed up today for my 67 custom interior build , Now I have to cut up a set of 67 folding bench seats to build a set of buckets .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
12-02-2022, 05:04 PM | #3481 |
That's one way to get bucket seats, I can't wait to see the results .........
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
12-02-2022, 05:21 PM | #3482 |
12-02-2022, 05:24 PM | #3483 |
i removed my steering wheel in order to change out the turn signal switch. i took the opportunity to clean and polish the steering wheel. plan to really polish up the column as well before i put it back together. i did find out that my steering wheel is worth $500 bucks which is neat. i bought it about 15 years ago for about $200. i was thinking about removing it for an original wheel. nice to know if i decide to do that i will be able to sell it for a little $$. i also pulled the bed off for better access. i prepping for undercoating. im probably going to have to use a combo of roll on and aerosol. anyone have good luck with specific brands?
12-02-2022, 05:45 PM | #3484 | |
I started to put the wood back in today . Amazing how dirty a frame gets just sitting the little black dots are worm holes I filled with epoxy prior to the polyurethane.
12-02-2022, 05:51 PM | #3485 |
The leather must have set you back a little . I buy vegetable tanned leather for knife sheaths stuff has gone way up last two years .
12-02-2022, 07:29 PM | #3486 |
Spent the day redoing all the battery and chassis/body grounds on the truck. Tomorrow is under dash wiring cleanup and install new ignition switch.
12-02-2022, 07:37 PM | #3487 |
Drivers side fender is on as well as the paint divider molding on back of cab
12-02-2022, 10:06 PM | #3488 |
Got her back from body and paint work. She’s perfect now!
12-02-2022, 10:25 PM | #3489 | |
That truck reminds me of an almost identicle truck a guy named Joe Mines from your area owned in the 1970's he owned Joe Mines Blasting and it had a set of aluminum slots on it . One of the best looking trucks on the road in North Jersey at the time . Very Nice !
12-03-2022, 08:30 AM | #3490 |
I very interested to see how those turn out
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
12-03-2022, 09:01 AM | #3491 |
12-03-2022, 09:04 AM | #3492 |
12-03-2022, 02:26 PM | #3493 |
[QUOTE=72c20customcamper;9150819]Pictures of the steering wheel would be nice
Its just a Grant Mahogony banjo wheel like this one. i bought it new with my ididt it column in about 98. |
12-03-2022, 05:17 PM | #3494 |
[quote=evilokc;9151097]Nice looking wheel . Looks similar to the one that was in my Avanti II not my picture but the same wheel
12-12-2022, 05:36 PM | #3495 |
Got board so to speak . Cut and buffed one of the bed boards 2500 then some med cut compound. Worked best by hand then three coats of wax . Guess I won’t be putting firewood in this truck
12-12-2022, 07:14 PM | #3496 |
That wood is gunna look real nice. Definitely not haulin anything in there now.
12-12-2022, 07:52 PM | #3497 |
12-13-2022, 11:53 AM | #3498 |
Promised her that she would get out the next dry weekend.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
12-16-2022, 04:40 PM | #3499 |
Snowed again . Tried something different on the bed wood used a buffer attachment for doing headlamps . Worked out real well ,I have two more to do but don’t feel like crawling under the truck to loosen the bolts . And it’s like 95 degrees in the basement love sweating in shorts .
12-16-2022, 11:12 PM | #3500 |
Took the ole guy out for some driving today. Nice winter (50s for us) weather here. Took in some of the local coast attractions. Sure is nice to have it mobile again.
