#3601 | |
Re: What did you do today not on your truck...
#3602 | |
Who Changed This?
![]() Join Date: Jan 2013
#3603 |
good guess, but no, just did the ball joints last yr.
cv started acting up last month, so i ordered a new one from amazon. was driving the truck real easy till the new one came in. first it was supposed to be here dec 28-30, then got an email stating jan 3 and then another email saying jan 5. was heading into work last monday and the cv broke into 2, most of it in the diff, and a couple inches in the hub. some truth to customcamper's post, i had some electrical wire to hold up the diff side of the cv and was taking it real easy trying to get back home. second corner was it, without the hub nut and cv, the bearing just came right apart. just the caliper was holding the wheel on, and only one caliper bolt.... should have been a quick cheap job, cv was $140, but because amazon can't hit a frikkin delivery date, it turned into a fiasco. $100.58 tow home $95 new hub $75 brake pads, $25 caliper slider bolts $300 to put 3 months insurance on the crew cab so i can still get to work plus the orig $140 for the cv...and of course when i got the truck back home, there was the new friggin' cv on my step (jan 9)......not too happy with amazon right now.. you can see the only thing holding the wheel on is the caliper the upper caliper bolt bent, then broke. surprisingly as i was drilling it for an easy out, the drill spun the bolt out enuff to grab it with some vice grips. mind you, i just put the calipers, pads and rotors in last yr when i was doing the ball joints. prob why it came out so nice. them hub bolts on the other hand...33 yrs old.... caliper sliders, was tough getting the bent one to come out. i think the broken one was easier.. ![]() nicely chewed up $100 new brake pads... at least my new rotor came thru with flying colors, still completely flat, no warpage at all. same with my new caliper, didn't crack or bend...got lucky i guess.. whats left of part of the hub...and my new cv sitting behind it....orig cv couldn't have lasted one more trip to work and home...or amazon's pee poor delivery schedule...smh |
#3604 |
A truck of mine threw a timing chain once waiting on a backordered double roller set. I was babying it along but my boss borrowed the truck, came walking back. Bent valves.
Those original bolts up there can get tough. On a K3500 I had to get a junk yard steering knuckle because the four bolts on back were froze up tight. Two broken impact sockets, second one after heat, tight.
#3605 |
Picked up a late 70s Better-n-Bens coal/wood stove . Been sitting outside a few years but I got the doors to open in a few minutes . Need a couple of steel plates to support the fire brick . The ones in it rusted but they are removable anyway . Rest of the stove is in good shape and it was free
#3606 |
My Dad used to call it "licking your calf over". Re-installed the eng/trans in the camaro. All because whilst the 350 sat on the engine stand for the better part of 6 months, I failed to remove the pipe plug for the temp sending unit. It was SS and painted over and siezed. So.....I heated..I beeswaxed...I hoped and prayed.. But no dice. The A arm was in the way and I couldn't jack it up to clear so I pulled it. Drilled it and managed to get it out without stripping the threads. It's all good, just put me behind a few days.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
#3607 | |
![]() Join Date: Dec 2009
Glad you had Good luck. ![]()
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#3608 |
Who Changed This?
Went over to the rental house to meet a gardener, who failed to show. Took along a GFCI outlet/light switch combo for one of the bathrooms. If you want that in a duplex outlet box- one outlet and one switch, it's $32.
#3609 |
Thanks. Believe me, I had visions of stripped threads and a ruined head the whole time..
#3610 | |
been dreading my hub bolts all week. last monday i got one out, the other 2 started rounding off. so i been spraying them all week and looking for anything else to do other than hub bolts. even started checking wrecking yards for a spindle (non-existent around here) figuring the stock spindle was gunna get destroyed getting them bolts out. finally went at them today, after liberal amounts of heat with the torch, got another one out, last one was too stripped to get a socket to hold it, so after tons of heat i hammered a smaller impact socket on it and with my son's 30" breaker bar, she finally came out. am breathing a lot easier now, once the new parts show up just a matter of bolting it all back together |
#3611 | |
R.I.P. E.S.L.L.
![]() ![]() Join Date: Aug 2005
![]() I waited for the firewood guy today. I'm out. Down to burning the wet stuff in the yard. The furniture is next if this guy doesn't show up soon. He says his truck is stuck in the mud. Funny the guy in Vegas delivered my new to me Jaguar today and this guy can't drive a mile. I love the Jag. The crate motor sounds great but I couldn't mess with it too much because it was pouring rain and my Jeeps battery finally gave up. It wont take a charge and its blocking the garage. So the Jag is in the yard for the moment and it's still raining like crazy. Oh well, hopefully it'll get some much needed water in the lake.
1971 Custom C/20 ![]() 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. Last edited by FleetsidePaul; 01-15-2023 at 07:21 AM. |
#3612 | ||
The brake hose and line came apart easily. In fact, I had ordered in advance that section of brake line from Inline Tube that I left in the box. Original line is still fine. Quote:
#3613 |
laying low
![]() Join Date: Mar 2001
“Every twenty minute repair is just one broken bolt away from a three day ordeal”. Truth!
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#3614 |
![]() Join Date: Nov 2018
#3615 | |
Who Changed This?
#3616 |
I have tried going into simple projects expecting a big ordeal so they would turn out quick and easy but even that didn't work!
#3617 |
"Tail Gate Best Seat In House"
![]() Join Date: Oct 2007
Ahh. I know what you mean ,,sometimes after opening walls and floors up ,,you get a surprise that you didn.t expect ..
When you learn a thing a day you store up smart. |
#3618 | |
I got my little barn move project completed, so I've been working on filling the building back up. I moved things out in phases. I've been looking at moving things back as a trivial task for rainy days or using idle timeslots. Not a thing to "waste" a whole good day on. I'll go out in the morning with my coffee and next thing I know it's after lunchtime, and finish out the day moving. Now I realize it's days of work worthy of whatever time I invest. I'm getting there
I had to build this canopy to store things, as well as fill my screen house, and stick some things in the garage. I built the canopy to be able to dismantle and erect elsewhere later Quote:
With auto mechanics I expect mechanical results, as if taking something apart that had just been put together. Yeah we know how rust can affect that, but we don't know how bad till we try. I can only speak for myself, and I figure for those who do it for a living it's like me with houses. Very little throws them for a loop.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-16-2023 at 11:41 AM. |
#3619 |
R.I.P. E.S.L.L.
I like the Coors license plate Tim. Hard to believe that they got it past the DMV here in nanny land.
Steven, I knew that house would go fast. It's in a really good neighborhood and nobody really sells there too often. I wanted too sell it when we moved but my wife wanted to keep it so we rented it out. Never again although the price of houses did go up considerably in the time it was rented. So it's a win I think. I did come down a little on the price. Not much. The housing market is weak right now. Prices are going down which is a drag if you're just selling. But I'm selling and buying so I'll make it up on the other end. The house I'm buying is 200K less than what they were asking a year ago. Now it's just all the escrow BS. It's supposed to close by the end of the month. Fingers crossed.
1971 Custom C/20 ![]() 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
#3620 | |
Who Changed This?
#3621 |
Looking great Tim
#3622 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#3623 | |
It's a funny story how I came up with that Thanks. There will be a lot less floor showing before I'm done. I still have the woodworking equipment to move, then the Harley. The canopy just has a few things left in the attic. I think I'll hold off dismantling it for now. Time to focus on my cellar project. Yesterday I sold the stack of cherry slabs I had stored on the back of my '67 project. No sooner had I built it a shelter and it got a load to haul (sitting still). Feels good to get that gone. I had all my transmissions and transfer cases stashed under it, now moved back to the lean-to side of the barn. I'm going from cluttered outbuildings back to normal, a barn full of junk ![]()
#3624 |
Who Changed This?
Much to my chagrin, I had to call an electrician to put a GFCI outlet in one of the bathrooms in the rental house. I bought one, but can't figure out how it should be installed. It's a two-gang, along with a light switch for the bathroom light. Don't anyone tell me how to do it, I'm already embarrassed enough. Or, just MAYBE, I'm sick and tired of working on that place, and just want it gone, with other people doing the work for $100. Yeah, I'm pretty sure that's the reason.
#3625 | |
![]() ![]() Join Date: Oct 2014
