#351 |
One day...
Re: Project: Bad Bagged '68.5
Yeah, i like the Auto Meter Ultra lights but havent seen them to match them
#352 |
Well I haven't updated this thread with my dropmember purchase, so here goes. Back in December I got the bright idea to sell my sectioned crossmember and get a dropmember. So I had to pull the engine and trans to do so. While the trans was out, I sold that too! The money is going towards a Tremec TKO 600. I said to myself I'm building a hot rod, so why the hell do I have an automatic in here! It all felt like two steps backward, but I think the end result will be well worth it.
I got a flaming river power rack from Summit. All the dropmember pieces except the actual crossmember I powdercoated myself with an Eastwoods gun. That thing is awesome! So much better than dealing with paint that doesn't have he durability. I also went ahead and got a swaybar from Nate. The only thing that sucked about the whole deal was welding in the rack notches in an already powdercoated from. I took pictures of that but can find them. I felt like I was performing surgery! A couple other notes for the record, I had to cut 1.25 inches off the ends of the rack. I also had to mill down one side of the AirRide upper control arms shafts because they were dished for the factory washer spacer thingys. ![]() ![]() ![]() ![]() In this picture you can see the notch surgery. ![]() ![]() Factory 73-87 brake calipers ![]() Last edited by jlaird; 05-04-2010 at 10:23 PM. |
#353 |
Here are some pictures of the stainless hard lines for the air and brakes.
![]() ![]() ![]() ![]() And the tools of the trade. ![]() Last edited by jlaird; 05-04-2010 at 10:29 PM. |
#354 |
Here a couple pics of the cab repair that I found which I never posted.
#355 |
insane work! I want a swaybar too now!! How was that to install?
#356 |
OK, back to the steering column. I wanted to make a reinforcement panel on the firewall where the column passes through. I gave me an excuse to use my REINFORCED harbor freight bead roller which is now a beast!
![]() ![]() ![]() Here is the Flaming River Stainless tilt column and the Ididit mount. ![]() ![]() ![]() Upper column mount is also from Flaming River. ![]() |
#357 |
VA72C10
![]() Join Date: Mar 2008
Looking really good!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#358 |
TNT-MOTORSPORTS
Hey Jlaird.....The clamps you are using for your brake lines and air line.....made 4 you brand ???? How rough a time did you have bending up the lines, did you make patterns out of steel before you did the stainless ? Any problems flaring the stainless other than having to have a 37 degree flare tool ? Sorry if you have answered the questions elsewhere. Tryin to decide what to do with mine.....really like the way you have yours layed out, gonna steel some of your Ideas.
#359 |
Here is the bead roller. I still want to add a steering wheel to it.
![]() This is the back where I added the square tubing. ![]() |
#360 |
Some more holes filled on the firewall tunnel area.
![]() ![]() Here is a pic of some ads I bought off ebay for the garage. ![]() |
#361 |
TNT-MOTORSPORTS
One other question, your power brake booster...who's is it, what brand....I really like it too.
#362 |
OK, time to smooth out the dash where the dash pad used to go.
I cut these out of a piece of steel exhaust pipe because they had the same curve as the dash. ![]() Tacked in place. ![]() ![]() ![]() Ground smooth. Yes, I'm a Jr. fan. LOL ![]() ![]() |
#363 | ||
The booster is a 7" diaphram from CPP as is the Master. |
#364 |
Got a part number on those shocks?
#365 |
One day...
Looks good! I like what you did with the dash!
#366 |
67cheby
![]() Join Date: Sep 2008
why dont you build some of those lines and sell them.... i would buy the first set !!
#367 |
#368 |
On the fast track to nowhere..
Looks good! I culled my sectioned crossmember as well along with my Zed frame. Started on the Dropmember tonight!
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
#369 |
Junior Member
Damn nice man! Lookin' real good!
Cory |
#370 |
Squarebody guy
#371 |
Damage Inc
looks like a good project
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold 01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame 04 RCSB-joe gibbs clone,22in billets 68 stepper build http://67-72chevytrucks.com/vboard/s...d.php?t=332337 |
#372 |
dazed and confused
looks good!!
members met: redbaron69, billsbowtie,nc67 |
#373 |
Wouldn't all that work to slick out where the column protrudes through the firewall hole appear better w/the nuts on the interior side of the firewall vs. the engine compartment side?
#374 |
67cheby
that is a clean looking setup
#375 |
![]() Join Date: Sep 2007
Very nice job man. Can't wait to see her finished.
Keep it up! |
