Old 04-28-2012, 11:28 AM   #351
VWNate1
VWNate1's Avatar
Post Re : 1969 C/10 250TH Pix
I still can't figure out how you guys put text between the pictures , I'd really appreciate a primer here .
Anyway , here it is , for the person asking about the TH350 T.V. Cable , look at pic # 3 , the bell crank on the intake manifold , the T.V. Cable is attached at the bottom of it , the throttle linkage is barely visible behind the Anti-Diesel Solenoid , just in front of the rockerbox , I hope this helps .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 04-28-2012, 11:34 AM   #352
Dano69c10
Dano69c10's Avatar
Re: Post Your Straight Six Pics!
Hey Nate, I see you have an offset air cleaner. If you ever want to convert to power brakes, I have some booster brackets...
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 04-28-2012, 12:01 PM   #353
50bomb
50bomb's Avatar
COOL THANKS NATE. GOOD looing SIX THERE
50bomb is offline   Reply With Quote
Old 04-28-2012, 12:04 PM   #354
VWNate1
VWNate1's Avatar
Post Re: Post Your Straight Six Pics!
THANX Dano ! I do indeed and have already purchased the vacuum booster....
I'm looking for the intake manifold fitting too .
-Nate
Geezer
Old 04-28-2012, 02:22 PM   #355
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I picked up an intake mani fitting at Advance.I had to look thru the boxes of fittings.I used a 90* one because it made routing my hose cleaner.I used to port on the base of the mani under the carb.The one just in front of your bellcrank arangement or the TV.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-28-2012, 11:54 PM   #356
VWNate1
VWNate1's Avatar
THANX ! when I worked in an outlying Heavy Duty Truck Shop , we had all manner of hardware , fittings , stuff to make up custom battery cables , on and on.... more Weatherhead fittings and hose ends than would fill a 40' Semi ~now that's all gone & in the L.A.P.D. Central Garage , it's amazing how they get anything done , all Ford dealer parts I guess .
I'll go give the local FLAPS a look . few seem to stock any Weatherhead these days .
-Nate
Geezer
Old 05-13-2012, 02:34 PM   #357
50bomb
50bomb's Avatar
Well got the 250 in the 67. Still trying to locate the brackets for the kickdown/tv cable for my th350 setup.
Stovebolt-It is painted
Old 05-13-2012, 10:38 PM   #358
Hubscrub
Cruzin
Hubscrub's Avatar
looking great guys
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 05-15-2012, 09:31 AM   #359
VWNate1
VWNate1's Avatar
Thumbs up Re: Post Your Straight Six Pics!
Nice to see the engine is in place .
You'd best change that tin fuel filter for a NAPA / WIX clear one before you get stranded by diry gas .
3/8" hose size IIRC .
-Nate
Geezer
Old 05-15-2012, 10:23 AM   #360
50bomb
50bomb's Avatar
Okay sounds good Nate. What do you think about the rubber fuel line that it has right now? All tips and ideas are welcome. I didn't paint it because I had only a day to borrow my neighbors engine hoist because he needed it for a job. Still seeing what i need to replace. I may even buy a new exhaust/manifold gasket kit. But might wait till I fire it up to see how it is first. ALSO I do not know if you can see but where the between the two last spark plug cables hangin there is a orange piece cross type thingy. What is the purpose is it a breather? I can take a better picture when I get home tomorrow.
P.S I am no mechanic but sure want to learn as much as I can before I do start driving this everyday for the rest of my life and get stuck in the middle of nowhere :-P
Old 05-15-2012, 02:09 PM   #361
VWNate1
VWNate1's Avatar
Thumbs up Re : 250 & TH350 IN !
I don't see anything between # 5 & 6 plugs or wires...
Unless the rubber fuekl hose is new by you , it should be replaced .
In fact , ther clear fuel filter is supposed to go just before the carby , not on the suction side of the fuel pump like it is now .
Folks who don't understand how these things work will errornusly tell you the filter over the manifold is bad , it isn't .
Keep plugging away ! you're doing great ~ I just don't like unpainted engines .
-Nate
Geezer
Old 05-15-2012, 03:47 PM   #362
sharpmark
if you are talking about the fitting on the block that you can see next to the white tape on no6 lead -it is an oil pressure fitting.it needs to be blocked off or go to an oil pressure gauge.
cheers mark
1969 stepside-305/4spd/12 bolt posi
http://67-72chevytrucks.com/vboard/s...d.php?t=477157
1968 pontiac lemans convertible-350/pwrglde/10 bolt
1934 oldsmobile sedan-350/350/12 bolt posi
1930 model a pickup-350/350/jag ind
1928 model a roadster-283/350/9"
sharpmark is offline   Reply With Quote
Old 05-15-2012, 04:11 PM   #363
50bomb
50bomb's Avatar
Cool thanks for the help Fellas.
Old 05-15-2012, 05:24 PM   #364
ole dollor
ole dollor's Avatar
mine is a 1970 c-10 292 six with a four speed at this time , going with power steering and automatic later, p/s is first on the list. here are some pics.
ole dollor is offline   Reply With Quote
Old 05-15-2012, 11:31 PM   #365
longbed67
longbed67's Avatar
Looks like you got your cake and ate it too! A/C and an in coil HEI!!!
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 05-16-2012, 12:22 PM   #366
50bomb
50bomb's Avatar
Ole dollor that is a nice setup in there. Love the 292.
Note:I ended up getting a new clear fuel filter and am replacing the old rubber part of the fuel lines with 5/16 because thats what it had but you noted that I should have got 3/8? is this okay what I got? I just want to try and do it right the first time around but I know I will fail hahaa. I mean this will be my daily driver for the rest of my life so I am trying to avoid cheap way out.
Old 05-16-2012, 12:46 PM   #367
ole dollor
ole dollor's Avatar
longbed67, yes the hei was my first up grade, man it made a big difference, and the a/c is a must for old fat guys in texas...it does not look like much, but almost everything form brakes and suspension are done, power steering is next, then cab mounts, and auto. trans. looks like everyone is still running their 4 blade fan, i put a clutch fan on mine, i change from the 373 rear end gear to a 276 gear. that has given me over 18 mpg.
Old 05-16-2012, 12:49 PM   #368
ole dollor
ole dollor's Avatar
50bomb, thanks for looking, it will be a while before its finished,but i enjoy working on ole dollar almost every day, i installed a inside rear view mirror with map lights yesterday, looks good.....
Old 05-16-2012, 01:04 PM   #369
70STOVEBOLT
70STOVEBOLT's Avatar
2.76 is pretty fast, does it seem to have enough power on take off or is it really slow now? I have 3.73's and a 250 with a TH400 auto and I have been contemplating a gear change. In fact, I have not seen anything faster than a 3.07 for the 12 bolt diff. Where did you get the gears?
Thanks,
Mark
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
Old 05-16-2012, 02:58 PM   #370
RichardJ
That's quite an AC pump bracket. I used an external coil and mounted the pump a lot lower. The dist cap comes off very easily.
I would trim a lot of meat off your bracket, but first mount the PS pump and get the belts figured out.
What's wrong with a four blade fan? Works well on my truck, but I did put an electric fan out front.
I have 3.54 gears and a truck 4spd. I don't think it would like 2.76 at all. Maybe CA isn't as flat as TX.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 05-16-2012, 03:58 PM   #371
VWNate1
VWNate1's Avatar
Sanden AC compressors ! SWEET .
If 5/16" hose fits O.K. use it .
Always try to match the hose to the pipe .
NAPA/WIX makes those clear fuel filters in all sizes .
Cali. is mostly as flat as TEXAS but we have crappy " Motor Fuel " that's SO bad , by law they're not allowed to call it ' Gasoline ' because it ain't .
Please keep those pictures coming ! .
-Nate
Geezer
Old 05-16-2012, 08:35 PM   #372
longbed67
longbed67's Avatar
On my trip back from Seattle washington to wisconsin I averaged 18mpg with a 3ott and a 3.73 rear. I have switched out to a 3.07 with an eaton posi with 600lb springs and moser axles and am curious to see what I will get! I almost put in the 2.76 gears but opted for the 3.07's but still have them in the box if I change my mind!
Adam
(608) 214-8706
Old 05-19-2012, 10:49 PM   #373
ole dollor
ole dollor's Avatar
richardj :yes i will cut the a/c bracket later,make it look a little better, vwnate1 i put the fuel filter before the pump because ole dollar had been on butane for years and the seat tank was full of really bad gas, i drained the tank and put new gas in, that was to catch anything that might have been in the tank, as far as a 4 blade fan goes they are noise and will cost you more in fuel having to pull a straight drive fan.
i got the power steering all put on ole dollar and changed out all the cab mounts, just my luck the old used power steering pump is leaking real bad, but it drives like a new one now, the cab mounts made a big difference in the ride,
now when the new pump comes in i will change it out and be happy,happy.
i went with the 276 gears on mine , thought about the 308, i think either one would work good, ole dollar will never be use as a tow vehicle, so i am after fuel mileage,i am at around 18.2 mpg right now at 2000 rpm , and 67 mph.
it takes off good in first or second. and i have no idea what the top end would be...
70stovebolt i got my gears from a place in lubbock texas, the name of the place is american differential . great people to do business with...
Old 05-26-2012, 08:11 PM   #374
50bomb
50bomb's Avatar
Need help. I still can not figure what this orange piece is for.
Old 05-26-2012, 08:24 PM   #375
Jimbabwe
Jimbabwe's Avatar
Does anyone know where I could get a nice new fan guard like the ones I'm seeing on a few truck in the 2 straight six threads? I've looked online, and in the various catalogs I have, but--unless I'm calling it by the wrong name--no dice.
Thanks.
Jimbabwe is offline   Reply With Quote
