Old 03-01-2019, 09:02 PM   #351
nds1968
nds1968's Avatar
Re: Project Blue Goose
Underside of hood will be body color. I purchased a cowl at the Auto Fair in NC last year, no more ugly antenna.
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 03-03-2019, 04:55 PM   #352
jkeating1
jkeating1's Avatar
Back in post 120 you showed your frame dimpled for the power steering box. I searched the general information threads for a step-by-step, or helpful hints, on doing this with no luck. It appears you did the "cut out the flat part and weld in a pipe" method. Is that right? That method seems pretty straightforward.
If I do the "heat it up and hammer it in" method, is there any reason to worry about the area around the bolt holes moving? Do you think it's necessary to bolt up a plate inside the frame temporarily to hold that part flat?
EDIT: Now that I've looked at that pic again--it appears you slit the top and bent the side in (in other words, did not weld in a curved piece). Is there no need to slit frame where the bottom of the "dimple" is?
jkeating1 is offline   Reply With Quote
Old 03-03-2019, 05:37 PM   #353
nds1968
nds1968's Avatar
I heated it up cherry red and used a big hammer. I didn't heat up the top and bottom flange so I think it will be fine. If it cracks I'll weld it up and reinforce it then, I doubt that it will crack... If your worried about it just go ahead and plate it.
Nate
Old 03-03-2019, 10:11 PM   #354
tristan
Looking good Nate! Following.
tristan is offline   Reply With Quote
Old 03-17-2019, 04:21 PM   #355
nds1968
nds1968's Avatar
The shop is moving along at a good pace.
White parts and interior are painted. They painted everything high gloss, not excited about that but it does look good.
I had a glove box door painted to match, I still have the original one.
Nate
Old 03-17-2019, 04:25 PM   #356
nds1968
nds1968's Avatar
I'll have to see if the front bumper fit goods, if it does it still needs work. It has dents and rust pitting. Hope the high gloss don't make it look cheap.
Nate
Old 03-18-2019, 09:20 PM   #357
67_C-30
I have a radical idea!
67_C-30's Avatar
I love this build!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 03-18-2019, 09:25 PM   #358
nds1968
nds1968's Avatar
Originally Posted by 67_C-30 View Post
I love this build!
Thanks its been a long one for sure. I'm back on it, I had to sell stuff to fund the body shop payments. It wasn't an easy decision for as I hardly ever pay people to do stuff for me.
It won't be on the road anytime soon but I would like to have all the sheet metal bolted on and lined up before this fall.
Nate
Old 03-18-2019, 10:05 PM   #359
67_C-30
67_C-30's Avatar
Are you doing light blue exterior, with the metallic blue interior? If so, that’s how my ‘67 C-30 came.
My trucks
Old 03-18-2019, 10:17 PM   #360
nds1968
nds1968's Avatar
Yes that's how it came from the factory. Body shop said that's weird, Lol.
Nate
Old 03-18-2019, 10:26 PM   #361
67_C-30
67_C-30's Avatar
The 67’s were unique like that. I added up all the up small differences that 67’s had one time, but I don’t remember the number. I know the key switch, vent wing window latches, window cranks, floor vent pulls, the ashtray, the rear view mirror, textured glove box door, and of course the side markers not being there were all differences on 67’s only.
My trucks
Old 03-19-2019, 02:11 PM   #362
nds1968
nds1968's Avatar
Door handles and even the tailgate in which I didn't know about until a years or so ago http://67-72chevytrucks.com/vboard/s...=1967+tailgate
Nate
Old 03-21-2019, 06:40 PM   #363
nds1968
nds1968's Avatar
They sprayed some blue today...
Nate
Old 03-21-2019, 07:53 PM   #364
tristan
How's my cab looking? :-)
Old 03-22-2019, 07:38 PM   #365
nds1968
nds1968's Avatar
I didn't check it out, honestly I get a little over whelmed looking at the progress on my truck. It's a lot to take in and check out. They sure are moving along at a good pace. They sent me this picture this afternoon...
Nate
Old 03-22-2019, 08:14 PM   #366
tristan
Danny the Painter really knows his stuff, that looks beautiful. My replacement driver's side door sucks, I need to hunt down another one.
Old 04-11-2020, 01:34 PM   #367
tristan
How's it going Nate? Any progress on your truck?
Old 04-19-2020, 08:26 PM   #368
68bowtie
68bowtie's Avatar
wow what a great build.
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 04-26-2020, 05:33 PM   #369
nds1968
nds1968's Avatar
I just started working on it again last month. Took some pieces to get PC, trying to get the back end all together so I can set the bed back on.
Thanks, been a long one for sure. Takes time to get it the way I envision.
Nate
Old 04-29-2020, 09:41 PM   #370
nds1968
nds1968's Avatar
Driver door edge lacks paint and looks like bare metal in spots. The other door and fenders lack paint where they back taped. Also unfinished body work, spots on the cab corner and that spot on the firewall. I have a heater delete I was going to use but you'll see the unfinished body work on the firewall...
Nate
Old 04-29-2020, 09:45 PM   #371
nds1968
nds1968's Avatar
I bent the cab corners back, they could use some hammer and dolly work.
Nate
Old 04-29-2020, 09:54 PM   #372
nds1968
nds1968's Avatar
On a positive note, I've been working on the rear sway bar and brake lines. I have mostly new parts for the rear brakes.
Nate
