Old 01-23-2014, 09:46 PM   #351
Ta2Don
Ta2Don's Avatar
Re: my build thread
Very Nice!!!
Serious Skillz!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 01-24-2014, 12:44 AM   #352
sams60gmc
sams60gmc's Avatar
Re: my build thread
got my lowers drawn, ill work more on the jigs tomorrow... the dimensions in them are modified to fit my application. The ball joints are moved an extra 3/4 of an inch forward to compensate for the fact that my cross member cross shafts are parallel and the factory frames are tapered, this will also keep my knuckes kicked back just a hair, ill also be able to play with that with the placement of my upper mounts. still working on the upsweep and ball joint angles...
just waiting on tubing to bend... going to order it from the same place in a smaller cut length from the same company to try and get it quicker, as the steel shop in town is waiting on a 20 footer.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
Old 02-06-2014, 12:28 AM   #353
sams60gmc
sams60gmc's Avatar
Re: my build thread
little news on the build, still waiting on back ordered tubing, i stuck the rear end together and did some metal finishing on the corners, thats about it, But I did pick up a new toy to aid in the build.I should be tooled up enough with this and the tig to be able to do whatever I need to at home from now on, lets blaze
Old 02-06-2014, 12:57 AM   #354
dr69burb
dr69burb's Avatar
Re: my build thread
Sweet looks good and nice new toy
Baggin 64 lwb project
http://67-72chevytrucks.com/vboard/s...d.php?t=537406
dr69burb is offline   Reply With Quote
Old 02-06-2014, 08:32 AM   #355
Bomp
Bomp's Avatar
Re: my build thread
Nice finish work. Can't get any finer than that. Smooooooth.
Them 211's are great.
Bomp is offline   Reply With Quote
Old 02-06-2014, 11:49 AM   #356
CMFT
CMFT's Avatar
Re: my build thread
Smooth as silk! Beautiful job!
'58 Apache
CMFT is offline   Reply With Quote
Old 02-06-2014, 12:23 PM   #357
1963c-10
1963c-10's Avatar
Re: my build thread
Very nice fab work.....great build.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 02-06-2014, 02:12 PM   #358
timmytimm3
Re: my build thread
Sweet welder! I just got the same one.
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 02-06-2014, 07:03 PM   #359
coulter
coulter's Avatar
Re: my build thread
killin it man!!!! i really dig your work
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 02-06-2014, 10:14 PM   #360
Jeff La
Re: my build thread
Love the new toy and the work is great also
Jeff La is offline   Reply With Quote
Old 02-08-2014, 10:25 PM   #361
sams60gmc
sams60gmc's Avatar
Re: my build thread
no new info on the build but i worked on a welding cart today for the tower of power... Im still in a 1 car garage so space is at a minimum.
Old 03-01-2014, 03:23 PM   #362
sams60gmc
sams60gmc's Avatar
Re: my build thread
not a whole lot of new news on the truck, got my new mounts in from Energy. Also figured out how to mount the uppers, now ive been working on the tabs to hold them and also make them fully adjustable and also good looking. Steel came in for the lowers and ive got my buddies hydraulic bender in the shop to start on them.
also finished this cart finally
Old 03-09-2014, 05:12 PM   #363
sams60gmc
sams60gmc's Avatar
Re: my build thread
Decided to build some new control arms that fit the application better. Built out of 1 1/4 .180 wall DOM and fully tig welded. Hopefully ill be making more progress soon, have a few irons in the fire as of now to take care of
Old 07-05-2014, 12:08 PM   #364
Bomp
Bomp's Avatar
Re: my build thread
Diggin that A arm.
Old 07-18-2014, 11:14 AM   #365
sams60gmc
sams60gmc's Avatar
Re: my build thread
Thanks Bomp. Been getting a ton of work done on the truck finally, just not enough time to post, so ill catch everyone up with this one.
Got my passenger side rocker replaced, the drivers will be here this week, I ordered them from Brothers and they fit great.
Decided to take out all my body work around the drip rail because it was failing due to poor prep work on my part. Spent a lot of time re welding it all and getting it smooth. I hired a guy to come start smoothing the whole cab out. He has the drip rail, fiber glassed, bondo'd, and spot puttied, and is almost all smoothed out.
Also ive got the bottom of the cab coated in chassis saver.
As for the fab work, the front of the truck is done. Did a bunch of figuring with the lowers, then machined my ball joint sleeves, and made the jig. The joint sits on a 13* angle, and both arms are built on the same jig, just by moving the locating slug and bolt to a different hole. I need to change the upper mounts just a bit for caster/camber and ball joint accommodation, but overall im very happy with how its coming together.
Once the front is done ill get it all up on a frame table and connect it to the rest of the frame
Old 07-18-2014, 11:32 AM   #366
1963c-10
1963c-10's Avatar
Re: my build thread
Front end and cab looking great!!!
I'm interested to see the drip rail conversion done.
Old 07-19-2014, 04:17 AM   #367
coulter
coulter's Avatar
Re: my build thread
awesome work man!!! really make me want to try to build some tubular control arms!!
Old 07-20-2014, 10:57 AM   #368
creep
Registered Loser
creep's Avatar
Re: my build thread
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 07-20-2014, 11:11 AM   #369
Bomp
Bomp's Avatar
Re: my build thread
Excellent work !
Old 07-20-2014, 09:11 PM   #370
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: my build thread
Very nice work.
I have often thought about building my own control arms.
Yours look sweet!
Modges'66 is offline   Reply With Quote
Old 03-13-2016, 09:50 PM   #371
sams60gmc
sams60gmc's Avatar
Re: my build thread
Well no updates on this thing. I decided to make some serious life changes and take my career somewhere new where I hope to go further. The truck was un able to make the trip. The frame cab and bed were sold. I decided to keep all my front end stuff and keep my 66 in hopes of bringing it to southern Washington one day to finish it.
Old 06-20-2022, 11:04 AM   #372
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: my build thread
Do you have a new build thread on the new truck?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
