Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 08-21-2013, 12:36 PM   #351
Swright
Re: Power Steering Adapter Plates
Are these Power Steering Adapter Plates still available?? Is so, please help with how and where to order, costs, etc. I believe this is what I need to mount power steering box to my 1967 GMC frame.
Thanks.
Swright is offline   Reply With Quote
Old 08-21-2013, 11:40 PM   #352
Captainfab
60-66 Nut
I replied to your PM
Thanks.
Old 08-22-2013, 12:37 AM   #353
Swright
Thank you, Captain. I have sent you another PM.
Steve
Old 08-22-2013, 01:04 AM   #354
Captainfab
60-66 Nut
I have not received a 2nd PM.........
Steve
Old 08-24-2013, 01:14 AM   #355
Swright
Captain, did you receive a PM from me today?
Steve
Old 08-24-2013, 01:21 AM   #356
Captainfab
60-66 Nut
Yes I received 2 PM's from you today. I did receive your payment and I'll send you a PM Monday night, as requested, after I ship your spacers
Steve
Old 08-28-2013, 08:40 PM   #357
Snailed
Snailed's Avatar
My '66 needs power steering...PM'd
Snailed is offline   Reply With Quote
Old 08-29-2013, 12:01 AM   #358
Captainfab
60-66 Nut
Old 08-31-2013, 03:33 PM   #359
Snailed
Snailed's Avatar
I got my plate today. I'm happy with the extra fast shipping and the plate looks nice and neat. Thanks!
Old 08-31-2013, 11:53 PM   #360
Captainfab
60-66 Nut
I'm glad you are happy and thanks for the compliment
Old 09-16-2013, 04:27 PM   #361
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Sending pm for adapter bracket 67k10
Thanks in advance.
Drew
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 09-16-2013, 10:57 PM   #362
Captainfab
60-66 Nut
Reply sent
Thanks in advance.
Drew
Old 10-17-2013, 03:54 PM   #363
62 short step
62 short step's Avatar
Got them today Captain, very nice quality! Fast shipping.
Thanks!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 10-17-2013, 10:47 PM   #364
Captainfab
60-66 Nut
Thanks for the compliments
Thanks!
Old 10-20-2013, 12:48 PM   #365
67ChevNut
Active Member
I will be getting a 66 swb frame to convert my long 72 Chevy to short bed. I believe I will be needing one of this plates soon. I will pm you when I am ready.
I am wondering if there may be other things I may need to consider to make this frame fit my conversion.
67ChevNut is offline   Reply With Quote
Old 10-21-2013, 12:56 AM   #366
Captainfab
60-66 Nut
That is correct. You will need an adapter plate to install power steering on that '66 frame.
To install your '72 body onto that '66 frame, the rear cab mounts will need to be moved, down I believe. The radiator support brackets on the frame will need to be moved. The front frame horns are different for the different bumper. And the '66 frame will have the radiator support crossmember, whereas your '72 has just a crossmember at an angle. Those are the only things that I can think of that will need changed
Old 11-03-2013, 02:53 PM   #367
Mack B
Mack B's Avatar
Cap'n can you pm me the details of getting you some money for one of your brackets? Thanks!
Mack B is offline   Reply With Quote
Old 11-04-2013, 01:18 AM   #368
Captainfab
60-66 Nut
PM sent
Old 11-04-2013, 03:11 AM   #369
Bart Savage
Bart Savage's Avatar
will be needing ps for a 66 2wd suburban 230ci...once i source the pump and box what/where do i get the bracket to mount the pump to my engine? also when i convert to disc brakes and dropped spindles at a later date what if anything will i need to change from a steering aspect/relation to this 1st mod??
Bart Savage is offline   Reply With Quote
Old 11-04-2013, 11:01 PM   #370
Captainfab
60-66 Nut
If you can't find an original power steering pump bracket assembly from a 250, there is a guy on ebay selling nice fabricated brackets.
Upgrading to disc brakes has no effect on the steering box or pitman arm. When you do convert to disc brakes, I always recommend changing the entire steering linkage to the later model components. You will have to drill the holes to bolt up the later model idler arm, but this way all the steering components are of the same vintage, and there is no need for the expensive tierod adapters.
Old 11-06-2013, 10:10 PM   #371
Mack B
Mack B's Avatar
Got it today, Looks awesome captain!
Old 11-11-2013, 03:32 PM   #372
Mike1984
Captain, it's Mike from Colorado, we talked last week about fixing power steering on my 65 K10. I need your bracket. I am sending you a pm.
Mike1984 is offline   Reply With Quote
Old 11-12-2013, 01:42 AM   #373
Captainfab
60-66 Nut
I replied to your PM Mike
Old 11-17-2013, 12:30 AM   #374
tenni126
I finally got around to getting this swap done...awesome product, and the template makes the whole thing easy. Lined up with no issues at all. Actually, I had more trouble tracking down a set of brackets to mount the pump than anything else. So thanks again!
tenni126 is offline   Reply With Quote
Old 11-17-2013, 01:22 AM   #375
Captainfab
60-66 Nut
Looks good
I appreciate the purchase and thanks for the compliment
