Old 03-14-2013, 09:50 PM   #351
rgunlock
rgunlock's Avatar
Re: 69 GMC "Ol' Blue"
Just went through your build, and gotta say I really like that you've kept your humor through this, but maybe that's just for us Coming along great! I've got the same Eastwood tube bender and it works great, but when you have to put multiple bends into the same line at different angles you're likely to get a good reminder of that Bud Lite Blue you are aiming to put on your truck
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 03-14-2013, 11:55 PM   #352
mjensen
mjensen's Avatar
Thanks Rick!
Yeah, I have to keep my sense of humor, because at the end of the day it's really me being my worst enemy. Learn and move on right?
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 03-15-2013, 11:38 PM   #353
mjensen
mjensen's Avatar
Well after a week of searching, I've finally found out that they don't make bulkheads for the front because they never existed the hoses actually go through the frame and connect directly to the hard lines. Now I feel better knowing that I didn't lose some uber rare option
I'm going to try and call my local hydraulic hose supplier and see how much it would cost me to have them make me up some 24" lines.
Mike
Old 03-16-2013, 03:41 PM   #354
mjensen
mjensen's Avatar
Ok, there will not be any update today other than the fact that the board set me straight in what my brake line setup should be. I went over to my local Evco House of Hose and they're going to make me up some new front and rear hoses. It was cheaper to have them make them than to buy the extended lines from various online suppliers (by well over 1/2). I still need to order Ts and elbows and such, then I hope to make progress next weekend.
Mike
Old 03-17-2013, 12:19 PM   #355
mjensen
mjensen's Avatar
Ok, I couldn't help myself. I HAD to bend up a line just to see how well I could do it. I'm pretty happy with how it turned out.
Mike
Old 03-17-2013, 02:40 PM   #356
Mustard72
Mustard72's Avatar
Looks good. Keep it up! I'm probably going to be redoing a bunch of mine once I find another frame, too. I don't have that Eastwood bender, though. Might have to consider an upgrade.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 03-17-2013, 02:44 PM   #357
mjensen
mjensen's Avatar
Thanks! Yeah, I'm really happy with both Eastwood benders. They work great. I'm still not sure about the flaring tool. If I was going to do more flares, I would spend the money on a flaring tool.
Mike
Old 03-20-2013, 07:05 PM   #358
mjensen
mjensen's Avatar
I picked up my hoses today from the local supply shop. First thing I notice is that I used the wrong hole to measure the length needed for the fronts. No biggie I guess if I just use the hole that I measured to. I am going to have to make sure their not too close to the exhaust (or my planned exhaust ). But something a little more serious that I didn't think about. Did you all know that the front wheels turn right and left? Yup, I don't think I put enough thought into this before I ordered the lengths, so I may be ordering again. The fronts I ended up making 24" long with the 4" lift, but they don't even seem to leave enough slack. On a good note, my measurements for the rear will work...
Mike
Old 03-20-2013, 07:46 PM   #359
mud.man.rj
mud.man.rj's Avatar
Don't turn the wheels or hit bumps and it will be good, sucks when something just isn't right, you will get it right next time.
mud.man.rj is offline   Reply With Quote
Old 03-20-2013, 08:29 PM   #360
mjensen
mjensen's Avatar
Ha...yeah it is really disappointing, but mistakes are going to be made. I'm just going to keep moving forward with these, and replace them at a later date.
Mike
Old 03-20-2013, 09:22 PM   #361
rgunlock
rgunlock's Avatar
Its kind of hard to tell from pictures, and mine is a different year than yours, but my brakeline from Rancho for my truck with 4" lift is about 23" from the frame to caliper best I can measure with a tape measure. Looks like mine has a little more slack than yours though (might be picture angle?)
Rick
Old 03-20-2013, 10:17 PM   #362
mjensen
mjensen's Avatar
Yeah, I've read a lot of posts on here and I was certain 24" was going to be too long, but I wanted to give myself room. A little of it is that they are just sitting in the holes not bolted up, but I definitely can't run them where I was thinking I wanted them. Oh well...who needs brakes right?
Mike
Old 03-26-2013, 11:52 PM   #363
rsmarr1982
rsmarr1982's Avatar
lookin good! i didnt know these trucks came with a transfer case like that . mine dont have a carrier bearing.
1969 chevy c10 lwb stepside 250 6 3 ott
1971 chevy c10 lwb 250 6 with power steering 3 ott
1972 chevy k20 4x4 350/TH350 automatic
1978 chevy Malibu 4dr 305 2bbl (all original)
1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver)
rsmarr1982 is offline   Reply With Quote
Old 03-27-2013, 10:16 AM   #364
mjensen
mjensen's Avatar
Thanks! Yeah, it's the T-221 Rockwell that was in the older trucks. I thought I read somewhere that they switched over to the NP205 sometime during '69. Not too sure on that though. I didn't know that there were any out there without a carrier bearing from the factory.
This weekend if I can get my brake line fittings figured out, I plan on bending like a mad man
Mike
Old 03-31-2013, 12:00 PM   #365
mjensen
mjensen's Avatar
Ok, I have a minor update. I was able to start on the rear brake line. I don't have it clipped in yet, but the bending turned out ok I think.
I know the line isn't perfectly straight, but as I work from back to front I straighten it as I go.
Mike
Old 03-31-2013, 05:05 PM   #366
mud.man.rj
mud.man.rj's Avatar
Some things like brake lines sure take a lot of time don't they, looks good though. I have been doing a bit of wiring today on dual elect fans, not fast either. I wired one to ign with a switch and the other to a sensor for backup when if it does get that hot idling.
Old 03-31-2013, 08:45 PM   #367
mjensen
mjensen's Avatar
Thank you! Yes, takes a lot of time and ambition Sounds like you made some good progress!
Today I finished up my brake lines! Flaring and all. I'm pretty happy with the results.
Mike
Old 04-01-2013, 08:05 AM   #368
rgunlock
rgunlock's Avatar
That bender got a real workout - looking good!
Rick
Old 04-01-2013, 09:49 AM   #369
mjensen
mjensen's Avatar
Why yes it did! I've been very pleased with the benders, they worked out nice. The flaring tool...eh still on the fence about that
Thanks Rick! I appreciate the kind words.
Mike
Old 04-01-2013, 10:01 PM   #370
Mustard72
Mustard72's Avatar
Looks dang good. Almost a shame to put the cab and box back on, eh? Thank God for pictures.
Nick
Old 04-01-2013, 11:59 PM   #371
mjensen
mjensen's Avatar
Thanks Nick! I'm sure I'll have a few more years to stare at it with the body off
Mike
Old 04-02-2013, 10:02 PM   #372
BobS
BobS's Avatar
Nice work!
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 04-02-2013, 11:26 PM   #373
mjensen
mjensen's Avatar
Thanks Bob!
Up next...fuel line. I hope to start on that this weekend.
Mike
Old 04-21-2013, 11:02 AM   #374
mjensen
mjensen's Avatar
Yesterday after helping my mom move, I was able to spend a little time on the old girl. I've finished all the hard lines, and while not perfect, I think they turned out pretty good.
Mike
Old 04-21-2013, 08:48 PM   #375
mud.man.rj
mud.man.rj's Avatar
very nice quality job on the lines. Looks like you do it for a living.
