#351 | |
The 60-66 GMC/Pontiac guy....
Re: Lost My 65
Sure glad he didn't have trouble with the lug nuts! ![]()
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#352 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Lost My 65
Bottom corner on the passenger side of the Radiator support was rusting out. It also had some other bad areas.
I took another Radiator support that also had some bad areas, and combining the two, I made one good one. . Here is the left-over bad portions: ![]() ![]() . Here is the patched and repaired support: ![]() Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#353 |
Re: Lost My 65
Nice... livin' the dream... too cool..
![]() Wish I could find my old ride.. you are one lucky dude... ![]()
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() Last edited by 66-PMD-GMC; 01-04-2013 at 06:36 AM. Reason: hit send too soon |
#354 |
Re: Lost My 65
Beings I patched and repaired my Radiator Support, and properly installed my Motor Stands which raised the front of the engine, I figured I'd mock up my new 62 Shroud.
Looks good. The fan is nicely centered. ![]() Posted via Mobile Device
#355 | |
Re: Lost My 65
![]() I have been waiting to see what you are going to do on this truck. Nice to see some progress. Haven't seen any posts on the service truck but I check from time to time. I am subscribed to both. ![]() I sure like that tire/wheel combo that you have. I like the stance of the truck with them too. ![]() I would love to find some rims similar to those for my tires that I am using on my 63. I have 18" M/T sportsman radials (6655) for the rear and 8" (6650)for the front. My biggest problem is finding any 15" wheels at 15" wide.. ![]() BTW how wide are the front tires on your truck?? ... Wish I could find a GMC grill as clean as yours... Keep on making those small steps my friend and before you know it you will be cruisin in that bad boy... ![]() ![]()
#356 |
Re: Lost My 65
I appreciate you always checking in on my threads.
I feel that I won't ever be really doing what we call a 'Build Thread', but I'm pretty settled now on a direction/theme. I see others build these classy beauties and I think of how I'd be afraid of every possible ding and chip. Also, with this truck there is so many layers of memories and experiences in the paint, the body, and even the chassis. Things that I want to keep. So, stripping down to metal and smoothing out every ding and ripple just doesn't seem right. The faint dents on the roof are from a canoe during a fishing trip with my friends Rick and Scott. The dent on the dash on the passenger side is from my friend Todd's chin when we got in an accident. The underlying layers of paint are layers of time. Under the blue; the bed is Red Oxide and then White. The Cab is Red Oxide and then dark blue with a white stripe down the passenger side. I like the idea of sanding down in kind of a faux-weathered look to expose portions of these layers. This allows me to see these layers of time and memories, but also allows me to not have to be worried about future dings and dents. The wheels and tires are the same size all around. The over-all width of the tires is 12" Posted via Mobile Device
#357 | |
Re: Lost My 65
![]() I get asked "WHY" about my choice of a power plant for my truck all the time... but it's what I want, so Pontiac motivation it is.. ... ![]() You can't beat a driver that you don't need to worry about when you are parked at the store.. ![]() Nuff said... As for tires, I was thinking of going with a 10" wide tire, section width that is for the front, but wasn't sure it would fit... If your tires are 12" then there is a god chance 10" will fit on mine... ![]() Keep posting progress .. ![]() I'm still searching for the right wheels for my 63.. ![]()
#358 |
Re: Lost My 65
Ok...........
![]() I have been thinking about this and I have to ask your opinion... ![]() I have a 62 GMC... The frame weighs a ton and I am thinking that it would be easier for me to roll this 62 over to a 63-66 frame ... ![]() You went the opposite way I know but my question is.. are the rear cab mounts in the same place? I have several frames and I built a frame jig and I will be shortening a frame to a short wheel base, grafting in the power steering section off a 67-72 frame and possibly fabricating a way to hang a C4 vette rear suspension off the rear. All of this could be done on the 62 frame too except I don't think shortening the 62 frame would be all that easy... You have seen a 62 frame.. got any opinions? ![]()
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() Last edited by 66-PMD-GMC; 01-20-2013 at 02:26 AM. Reason: s |
#359 |
Re: Lost My 65
I only went with the 62 frame because back in 84 I didn't know right off the differences.
My friend Todd's dad offered me the 62 gmc for a donor to rebuild my 65 after I totalled it. If I knew what I know now, I would have looked for a shortbed 66. But getting it back, I'll be keeping it on the 62 frame because of memories and nostalgic reasons. . With the upgrades you want to do to your truck, I would think the newer frames would be the better choice. . Now, I heard the reason they changed the cab in 64 was because more twisting of the 63+ frame was putting much strain on the wrap-around window style cab. So they redesigned the cab's front pillars to create more of an 'A-Frame' structure to the cab. . And yet, I haven't heard any complaints from those who have a 63 as this being an issue. . As to your other question; the rear cab mounts are the same. It's the front cab mounts that are different, but still easily works. . Shortening a 60-62 frame would probably be way too much work. Me, I wouldn't attempt it. . From reading these forums, Shortening a 63-66 frame doesn't seem to be that difficult at all. Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 11-27-2014 at 04:05 AM. |
#360 |
Re: Lost My 65
So, are the rear cab mounts/bolt holes in the same place between the two sets of year cabs?
Measuring on my 62, the best that I can alone says they are really really close or the same. ![]()
#361 | |
Re: Lost My 65
#362 |
Re: Lost My 65
My 62 is complete and on blocks and jack stands so measuring is an exercise in yoga... LOL
I wasn't sure if you remembered having to drill new holes or ?.......... Thanks for checking for me. ![]()
#363 |
Re: Lost My 65
They are the same
#364 |
Re: Lost My 65
Oops, I forgot. Sorry.
I've been working crazy hours lately.
#365 |
Re: Lost My 65
No big deal...
I got it and now I am making plans for C-4 vette rear suspension, Porterbuilt coil over front.... This next truck will be for the skid pad....... ![]() ![]()
#366 |
Re: Lost My 65
I had a leak in the cab.
I found it at a seam under the vent cowl cover. I dug into it yesterday. There's about forty spot welds. I wasn't looking forward to drilling all them out. It went a lot easier than I expected. Here are a few pics: ![]() ![]() ![]()
#367 |
![]() ![]() Join Date: Jul 2002
Re: Lost My 65
At least you are doing it better than the PO of my 69 parts truck did; beer can and tar.
#368 | |
Re: Lost My 65
Fortunately, I have a donor cab that has that portion in good shape that I've already cut out to repair that section right. Posted via Mobile Device
#369 |
Re: Lost My 65
A friend at work just gave me this:
![]() ![]() Posted via Mobile Device
#370 |
Re: Lost My 65
Got the patch piece from the donor cab cut to size.
Fits good. I'll probably try and get it cleaned up and tacked in tomorrow. ![]() ![]() Posted via Mobile Device
#371 |
Rollin' Old Skool
Re: Lost My 65
cool find on the protection plan, & the patch looks like a nice fit
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#372 |
Re: Lost My 65
You make it look easy lostmy65, Thanks for posting. Was wondering how that dang thing came off. I am going to work on this next winter. Wish I had a room for a donor.
#373 |
Re: Lost My 65
Finally got the patch for the cab welded in.
. I put the truck back together. I'll tinker here and there, but I'll wait until winter before I do anything major again. I really would like to get some concrete poured in my pole barn to make it easier to work on the truck. ![]() ![]() ![]() Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 06-16-2013 at 10:19 PM. |
#374 |
Re: Lost My 65
Nice job!
#375 |
Re: Lost My 65
The Shrinking Discs I ordered from Wray Schelin arrived today.
I'm going to keep the truck drivable for the summer, and just tinker with bodywork. ![]() Posted via Mobile Device
