#351 |
Re: 58 TRUK intro
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#352 | ||
Re: 58 TRUK intro
there is a lot more information on that site about the frame work, bucks and forms i used in building my fg parts. glad to see it back up ![]() i've reinstated the interior build link in my signature if you want to view the site or my interior build.
#353 |
Re: 58 TRUK intro
Hey Ogre can you tell me the size rims and tires you have? and if you know what the backspacing is that would be great. Thanks
#354 |
Re: 58 TRUK intro
i'm a little old school when it comes to wheels and tires; lots of sidewall for trucks
![]() wheels vintique steel wheels 7x15 up front, 8x15 out back, both have 4'' backspace and P235/70R15 rubber i'd use 4.5 back space on the rear rims, it's a little tight to the fenders when pulling the tires off ![]()
#355 | |
Re: 58 TRUK intro
#356 |
Re: 58 TRUK intro
i hear something when i'm locked to the right backing out, but not to the left.
definitely not on sheet metal, frame or a-arm, i can't see what it's been hitting. been that way for 20,000 miles and i can't tell where it rubs, it's very minor. back off a smidge and the sound goes away, only happens backing locked to the right. it's a custom ![]()
#357 |
Re: 58 TRUK intro
Awesome truck. Too bad FGF is down again. Would have loved to see more of your work as you were doing it.
#358 |
Re: 58 TRUK intro
thanks garmar, click on any of my pictures and it will take you to lots of photos on photobucket
i'm afraid fiberglassforums.com is down for good ![]() i should have copied my thread into this one when it was up again...
#359 |
Re: 58 TRUK intro
Ogre your fiberglass work is really nice. I have tried it before and there was a lot of sanding. I was doing something wrong. I looked and I couldn't find any pictures of your headliner. Did you insulate the roof before covering it ? do you have any pic of the work you done on the headliner? Thanks Rich
#360 |
Re: 58 TRUK intro
Fiberglass involves a lot of sanding like any body work
less sanding when wrapping in vinyl My headliner is the same material as my seat covers i did glue thin foam to the material first no pictures of the headliner yet, need to take some
#361 |
Re: 58 TRUK intro
Thanks Rich
#362 |
Re: 58 TRUK intro
Wow great looking build Ogre, that yellow will be easy to find in the parking lot, just look for the glow in the air, Nice!!
#363 |
![]() Join Date: Jan 2014
Re: 58 TRUK intro
Great build thread and truck, how many hours are tied up with the project?
#364 |
Re: 58 TRUK intro
thanks for the kudos guys.
![]() when i park in front of my local breakfeast joint, the cook puts his sunglasses on. hours? years... roughly 8 years in my build, but life gets in the way sometimes.
#365 |
Re: 58 TRUK intro
On page 4 (a long time ago) you posted about your powder coating setup. I now have a brand new oven ( for free) and am about to order the eastwood gun. Do the supplied 8 oz bottles really cover much or should a person buy the 1 lb containers? I guess it depends on thickness and part size but how much would it take to do a wheel, or a couple of small parts like brake calipers? Thanks for any info. I just started a 69' project (for free) and would like to add powder coating to the tool assortment.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
#366 |
Re: 58 TRUK intro
I'm curious where you came up with the idea for that brake setup? Looks like a good alternative to the $300 cpp option. I saw some pointers on pg.8 of your build. Could you give me some more specifics on what all it involves? Did you just have to fab up the bracket to hold it to the frame? You've got drums on the rear correct?
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold |
#367 |
Re: 58 TRUK intro
okgmc: i believe i bought 2 - 2lb containers of powder and have a lb left over after powder coating everything i did.
i had ordered the 8 oz containers of black, red and yellow for other stuff. nice thing is those 8oz screw right on the gun. i had to mix 1/2 teaspoon of red into 8oz of bright yellow to get the finished color right groyd: i saw the hydroboost on a mustang in the shop and said ''i'll use that''. that was my total thought process ![]() the bracket cost me some steel i had laying around, i believe i gave $125 for the mc and hydroboost. i cut off the stock mount and made a weld on plate for the frame with threaded holes to mount my bracket. the bracket needs a mounting plate for the hydro and a hookup to the pedal, that's the way i think when i fabricate. i do have 4 wheel disc brakes as did the mustang donor. i believe the astro vans have hydroboost and front disc, rear drum.
#368 |
Re: 58 TRUK intro
What an awesome build. Just love the fiberglass work and attention to detail.
Very inspiring. |
#369 |
Re: 58 TRUK intro
Sir, you have a REALLY nice truck! Congratulations.
#370 | |
Re: Amp gauge to volt gauge conversion
It helps me sort out what I need to add a voltmeter ![]()
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=595909 |
#371 |
Re: 58 TRUK intro
it was a fairly simple conversion once you have the 2 gauges apart, the rest is... easy peasy
![]() as i remember the stock face plate is riveted on and the new gauge had screws, screws made it easy to attach the old to new. glad you liked it.
#372 |
Re: 58 TRUK intro
Do you remember if you used a 2 1/8" gauge as the donor and was the sweep 70 or 90 degrees?
#373 |
Re: 58 TRUK intro
i thought it was a 2'' 90* sweep gauge. i believe a 2 1/8'' 70* or 90* would work fine. much bigger, no.
i cut the stock needle off and used jbweld to stick it on the new gauge, that was actually the trickiest part of the mod ![]()
#374 |
Re: 58 TRUK intro
Thanks for the info.
It might be a while until I get to it but now I know it can be done.
#375 |
58 TRUK headliner
been meaning to post headliner pics up for a while.
i glued 1/4'' foam to grey ultra-suede fabric that matched my seats using contact cement then sprayed contact cement on the roof and foam and with my wife stuck it to the roof ![]() ![]() with the foam and previous work on my roof skin i ended up destroying a new headliner rubber trying to install it i ended up using black door edging trim on the exposed edge. ![]() note in the top pic i have my headrests... first time i sat in my new seats i leaned back and cracked my head on the corner of the rear window frame most people will never experience this problem, but at 6'4'' i did. i smacked it hard, brought tears to my eyes ![]() 3/8'' hard foam wrapped in the same fabric and double sided taped to the window frame spraying contact cement in a finished paint cab was interesting to say the least. 2 hrs of masking and 20 yards of paper for a 1 minute spray of the glue
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer Last edited by _Ogre; 05-25-2014 at 11:58 AM. |
