Old 09-10-2015, 10:06 PM   #351
68c10airstream
68c10airstream's Avatar
Re: 67-72 Electric speedo
Shine up all of the exposed brass, especially the nail head terminal on the temp sender Any corrosion/green color/dark brass is additional resistance and will skew your dash gauge colder. Good luck
68c10airstream is offline   Reply With Quote
Old 10-03-2015, 11:13 AM   #352
drgeary
Interested in a set.
drgeary is offline   Reply With Quote
Old 10-03-2015, 04:34 PM   #353
ls1nova71
ls1nova71's Avatar
PM returned.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-24-2015, 07:31 AM   #354
hotrodsinner
hotrodsinner's Avatar
Hey Ls1nova, I'm interested and ready to purchase a faceplate set from you. Can you please PM me the details.
hotrodsinner is offline   Reply With Quote
Old 10-31-2015, 08:52 AM   #355
wannabefastcrf
does anyone covert these as a side business? I have the template from LS1NOVA and can get the parts from captianfab but not sure if i have the skills to make this happen myself.
wannabefastcrf is offline   Reply With Quote
Old 11-01-2015, 01:09 AM   #356
Captainfab
60-66 Nut
You might send a PM to member Tbone1964. He is in the business of rebuilding gauge clusters. Also member PGSigns has started rebuilding '64-'66 clusters, but I don't know if he does any other years.
Old 11-01-2015, 10:20 AM   #357
wannabefastcrf
i started by askeing TBONE1964. He said he doesn't convert them anymore. But thanks for the other name I will look into it.
Old 11-19-2015, 10:48 AM   #358
ms2335
ms2335's Avatar
Are you still doing the vinyl faces. Interested in getting a set
65 Chevy C10 Short Fleet BBW 6.0L/4l80E
68 Chevy C10 SWB 6.0L/4L80E
84 Chevy C10 SWB 5.3/4l60E QA1 Suspension
ms2335 is offline   Reply With Quote
Old 11-19-2015, 11:49 PM   #359
ls1nova71
ls1nova71's Avatar
Yes, I still have them. PM sent
Old 12-10-2015, 01:18 PM   #360
kehstr
kehstr's Avatar
sorry if i'm just not seeing this, but i can't find the socket ya'll are using for the dash lights, i just seeing lots of different ideas. Can someone who has done the conversion post a link to one that they know works? Thanks for your help in advance
kehstr is offline   Reply With Quote
Old 12-10-2015, 10:01 PM   #361
68c10airstream
Post number 321 gives the part number and how to slightly modify them to work. It's on page 13 of this posting
Old 12-10-2015, 10:26 PM   #362
kehstr
kehstr's Avatar
thank you for describing where it is
Old 12-15-2015, 04:33 PM   #363
kehstr
kehstr's Avatar
I cut it out with a cut off wheel and sanded the edges smooth with a DA sander. You're right, tin snips would probably be hard to use and would likely crack it.[/QUOTE]
I took the trip reset off then cut it out with a band saw, and then sanded the burs off with a piece of 120 grit sand paper. Could do the same think with a jig saw for those of you that don't have a band saw
Old 01-08-2016, 01:18 AM   #364
Ctinman
Are there still sets available? If so I would like to get one
Ctinman is offline   Reply With Quote
Old 01-08-2016, 02:48 PM   #365
ls1nova71
ls1nova71's Avatar
Yes, PM sent.
Old 01-15-2016, 12:35 PM   #366
kehstr
kehstr's Avatar
Originally Posted by ls1nova71 View Post
Then using some non-abrasive, silicone free polishing compound, start rubbing the numbers off the inside of the lens. It takes a little elbow grease, but it's not all that hard.
The paint for my numbers was so thick that the polishing compound wouldn't work, i wet sanded it with 2000 grit sand paper, then used some medium cut compound to get rid of the scratches.
Old 01-16-2016, 09:20 AM   #367
kikkegek
kikkegek's Avatar
Originally Posted by ChevyCruizer View Post
Just in case anyone was wondering why you cant use a speedo from a tach S10...
There is not an odometer attached to the speedo, it is in the tach.
The one you want is in the top of the picture.
I'd like to know this too...would be cool to also swap that tach
kikkegek is offline   Reply With Quote
Old 01-17-2016, 03:59 AM   #368
Curtb1971
Curtb1971's Avatar
Just wanted to give a shout out to LS1nova71, Captianfab, TBone and everyone else on this thread Finally got a chance to get in some work on the speedo swap and made some good progress in a timely matter thanks to everyones input/parts in on the forum. Next round is wiring this thing.
Curtb1971 is offline   Reply With Quote
Old 01-17-2016, 07:32 PM   #369
ls1nova71
ls1nova71's Avatar
^^^^^ Nice job, looking real good!
Old 01-17-2016, 07:42 PM   #370
kehstr
kehstr's Avatar
I'm a little confused on how we are supposed to set up the fake face plate screws, does anyone have pictures of how they set it up?
Old 01-17-2016, 07:51 PM   #371
ls1nova71
ls1nova71's Avatar
Basically, you just drill a small hole in the face and they just push in, and if the hole isn't too big, they will stay in there. You will have to mark and drill holes under the face with a bigger drill bit so that the screw part has somewhere to go. I found this to be easier than trying to cut the head off the little screw and gluing them on like I did the first time.
Old 01-17-2016, 07:54 PM   #372
kehstr
kehstr's Avatar
thanks that clarifies things a lot
Old 01-17-2016, 09:33 PM   #373
72longhornTX
PM Sent on getting a set of these.
Current:
2012 Ford F-250 4x4 6.7 Powerstroke
1971 C-20 2wd 350/TH400
Former:
1979 C-20 2wd 350/TH400, 300+hp. Rattle can paint job
1982 K-30 454/700R4. 4in lift with 37" Goodyear MT/R's Lots of goodies - Trail clean up truck
72longhornTX is offline   Reply With Quote
Old 01-23-2016, 08:31 PM   #374
Curtb1971
Curtb1971's Avatar
Hey Eric,
Any way I can get another speedo decal sent my way. Changing some things around. Thanks
Old 02-28-2016, 11:43 AM   #375
BustedTruck
BustedTruck's Avatar
Ok. I'm currently doing this right now. I've got a question, when the needle is straight up and down its at 50mph. The sticker I'm putting on straight up and down will be 60 mph. Is the speedometer correction in the tune?
BustedTruck is offline   Reply With Quote
