10-22-2014, 09:45 PM | #351 |
Re: Project 30 years sitting
Wait...what? Why is there a chrome ring? It's not just a lens riveted on the reflector like the originals? Can you just ditch the ring? I just want a clear lens.
10-22-2014, 10:02 PM | #352 |
Oh, hmm sorry missed the sidetrack, I was reading and replying on the phone. Yea, front turn signal lenses is what I was referring to.
10-22-2014, 10:06 PM | #353 |
ok, we were both confused, lol. Yes front ones, LMC, drill/replace rivets.
10-24-2014, 07:58 AM | #354 |
Made the drive into work today, and it was the coldest ever!!! Transmission started slipping due to low fluid. Nobody hi-beamed me saying my lights were to much for them.
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half RIP 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
10-24-2014, 01:12 PM | #355 |
Nice work Dale, enjoy!
Any chance you could move your sirius antenna to the insde, and sit it on the dash, just curious if the reception would still be good Thanks
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
10-24-2014, 01:28 PM | #356 |
I will give it a try sometime.
Bad news, went to leave for lunch. Wont shift. I think 3/4 went out. I only feel first n second. Already called trans shop and plan to take it in monday. |
10-24-2014, 02:30 PM | #357 |
What trans?
10-24-2014, 03:36 PM | #358 |
4L60E with custom output shaft and speed sensor. It worked fine for about 5-6 miles, started slipping from 6-8miles.
10-24-2014, 03:46 PM | #359 |
Hmm, don't know about a 4l60 but I know on a 4l80 having no 3rd is a minor problem, having no 3rd and no reverse is a big problem. The first means either a bad solenoid or a bad electrical connection, no reverse too means rebuild time.
10-24-2014, 04:12 PM | #360 |
It should be under warranty. The guy that rebuilt it knows it was for a non-moving vehicle and would be a while before it moved again. On the phone he seemed to be ok with repairing it. Just this time Im going to have to pay for him removing and installing since my warranty only covered "bench job" not full labor.
11-04-2014, 09:24 PM | #361 |
Jimmy came back after a few days, simple fix.
I rummaged around to find all my hatch hardware. So the hatch I painted the day it got wrecked is now on with almost all factory hardware. Only 8 screws have been replaced. |
11-28-2014, 07:59 PM | #362 |
Alight. So I took a few weeks off and did some photoshoots since I have neglected my photography while fixing this.
But I have epoxy primed the left rear quarter, and the passenger door so to protect/cover all the new metal since my research showed that powder coating that comes on them isn't worth a crap. I also had some headlight issues. Turned out my aftermarket harness got damaged in the wreck. Removed it and back on stock one. The steering had been a bit squirly since the wreck. Took it in and they wouldn't align it since the centerlink was bent. I thought it was to be that way?? So tonight I pulled that out and replaced with the 73-76 style which makes for better mounting for the steering stabilizer. I don't have a new one of them yet. Next week it will get taken in to finish all this. |
12-07-2014, 07:12 PM | #363 |
Alright, onto the drivers door this weekend.
12-07-2014, 08:48 PM | #364 |
Nice save dale.....are you going to use a rust convertor on the inside of the door
12-07-2014, 09:09 PM | #365 |
Thanks. I wish I would have finished taking the box around like I did on the other side. Once I got in I found out how thin it was on the back side.
Yes, I put some rust stopper on it today when I called it a day. Then I will be undercoating the inside of this, and the skin. It should match the other side which I'm not sure I took/posted pics of that. |
12-24-2014, 08:27 PM | #366 |
Finally got back to this. Project has taken longer than planned due to other events going on in my life. But I have gotten out and done some photography. Just cant post them on here Anyway, got skin on today. Also working on finish repairing the a-post that I didn't have items for when I fixed the floor.
12-27-2014, 07:08 PM | #367 |
All back together. I am likely bringing a mazda 626 home tomm to fix for a friend. Hopefully that wont take to long.
12-28-2014, 12:48 PM | #368 |
2WD Jimmy
You did that door right. Good job.
12-31-2014, 06:57 PM | #369 |
GEARHEAD
Looks great!
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
02-15-2015, 09:02 PM | #370 |
Been a while. But its time to do one last body panel before spring. While I'm at it I plan to have all my rims media blasted and powder coated. A lot of the rims have some type of damage. Stripped center cap hole, bent or gouged lip. All fixed. Now ready for coaters.
02-17-2015, 09:28 PM | #371 |
Old one off, new one test fitted
02-26-2015, 10:49 PM | #372 |
Ready for primer hopefully saturday. Also fixed my spare tire carrier bolts. Also on tap is to fix my blower motor switch, and install a convex right mirror.
02-26-2015, 11:20 PM | #373 |
nice work
Chris Heinz |
02-28-2015, 05:46 PM | #374 |
How well did the quarters fit?
02-28-2015, 09:17 PM | #375 |
skorpio. I got both quarters at different times and had different issues with each one.
Left. Welded differently than stock in the rear(around tail light area). The roll above the body line was slightly different. Right. Welded like stock around the tail lights. The surface at the top was wider then stock. Very tight fit putting tail lights in. |
