Closed Thread
Old 03-20-2015, 01:39 PM   #351
57Sedan
Re: What did you do with your truck today, take 2
Originally Posted by 57chevyman View Post
Jake - I'm using the same mustang tank as you . Are you doing a flip down license plate for the filler?
Hey Chevyman, I was going to do that but couldn't get enough of a slope from the filler down to the tank. Plan B was to put a filler neck into the panel that will close the gap from the bottom of the original bed to the raised bed, where the red circle is in this pic:
BUT - I have my filler mocked up there right now and it was a royal pain in the arse to fuel up, so I am now thinking I will just put the filler in the bed floor. So much for being original eh?
Jake
57Sedan is offline
Old 03-20-2015, 02:37 PM   #352
57chevyman
57chevyman's Avatar
I mounted my tank on the bottom of the frame and I'm going to either drill thru,or notch out the bottom of the rear sill. Doesn't look there will be any issue with the angle of the filler.
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline
Old 03-22-2015, 05:04 PM   #353
rrenner
rrenner's Avatar
Installed steering wheel.
1958 Apache short bed
rrenner is offline
Old 03-22-2015, 06:08 PM   #354
Softpatch
Softpatch's Avatar
patch panels stuff not picture worthy
found this on the web
looks like a TF truck...Sp
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline
Old 03-30-2015, 05:52 PM   #355
Dan in Pasadena
Dan in Pasadena's Avatar
This post is a duplicate of what I just posted on my own thread. I do that to keep all my stuff together but posting here so if anyone is interested they'll find it:
Took the day off today. I think I caught a case of "anal glaucoma" - I couldn't see my a$$ going to work today!
Decided to do a little project I've been putting off.... painting the white on some nice original side badges I bought from a guy in NY. They were rechromed at some point and I n doing it they lost a lot of the lower edge of the smaller letters in "Chevrolet" but I don't mind.
Basically, I just masked the large details as well as I could, and used Duplicolor touch up paint, both primer/filler and bright white top coat. The small brush that comes with the paint is good enough to follow the edges of the small letters; though they've lost some definition.
Anyway, here's my progress so far:
And the other end:
Here's the mateirals I'm using. No prep - didn't want to scratch the good chrome. We'll see if this turns out to be a mistake or not.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline
Old 03-31-2015, 10:52 AM   #356
dubds10
Stalker Nate
Finally had its first bath since last summer lol Put a manual rack in it to drive it while I wait on the power rack. Not very easy to drive with manual lol The '46 is easier to drive as a manual.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline
Old 04-04-2015, 01:21 PM   #357
Dan in Pasadena
Just dropped mine off with a guy that's gonna rebuild the TH350. It had developed a bad leak and I know nothing about the history of the tranny so figured I may as well bite the bullet for a full rebuild. Also having him install a used Lokar floor shifter I found on Craigslist and hook up the speedometer cable.
I'd recently rebuilt the carb but hadn't adjusted anything, just plopped it on there and took it to the guy. Hopefully it'll idle down nicely and run better without leaving a big red stain the on the driveway anymore.
Old 04-04-2015, 01:38 PM   #358
FamilyBowTie
Brought home the donor S10 w/ 5.7L and 700r.
All body panels stripped down to bare metal and primed (except bed)
Have a buyer coming for the original chassis and once its gone I will pull the donor around back and strip the body off and begin the build.
49 5 window on s10
http://67-72chevytrucks.com/vboard/s...d.php?t=671706
FamilyBowTie is offline
Old 04-04-2015, 01:39 PM   #359
Tomb23
Finished making Dash Cluster Inserts
Tomb23 is offline
Old 04-04-2015, 02:09 PM   #360
yossarian19
Mounted the newly stained & urethane'd steering wheel.
A little darker / glossier than I'd hoped but hey, the Minwax was just sitting there on the shelf.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline
Old 04-04-2015, 02:20 PM   #361
crossfire84
crossfire84's Avatar
Nice job.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline
Old 04-05-2015, 02:08 PM   #362
FarmerSid
FarmerSid's Avatar
Finished the new frame C notches, rechecked level and checked again for square. It's bang on! Been a ton of work getting to this point as the frame was tweaked.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline
Old 04-05-2015, 05:00 PM   #363
Race.it
Race.it's Avatar
Took out the dash gauges, put a pair of new hinges on drivers door, still need to do passenger side.
Removed the wiring from the cab in anticipation to new wiring from American autowire.
1954 Chevy 3100 currently original.
Race.it is offline
Old 04-11-2015, 05:20 PM   #364
crossfire84
Working on making new door panels and then came the little brown truck with a package. It took 8 months to get these but it was worth it.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 04-11-2015, 07:28 PM   #365
FarmerSid
FarmerSid's Avatar
Pretty shiney crossfire! What's up with the 8 months?
C4 IFS & D44 IRS
5.3 HO L33
Old 04-11-2015, 07:30 PM   #366
FarmerSid
FarmerSid's Avatar
Redid my C notches today. Freak'in all day! I'm done! Now me and the boy's time. Hockey night in Canada and then off to the sack.
C4 IFS & D44 IRS
5.3 HO L33
Old 04-11-2015, 08:39 PM   #367
Richs'55
Not just what I have done today, but I thought it would be time for an update.
Picture of what the truck looked like when I bought it last August.
Now after finding a different frame to put under it, changing it from 4WD back to 2WD, changint the engine, transmission, all suspension and lowering 5 inches front and back. Just mocked up the cab and bed and setting the fenders and hood back in place. I am liking the look of this truck again.
Richs'55 is offline
Old 04-11-2015, 10:05 PM   #368
tbrown5079
installed new windshield.
tbrown's 56 Cameo Build
tbrown5079 is offline
Old 04-11-2015, 11:10 PM   #369
whitedog76
Vortec 4200 with AR5 trans.
whitedog76 is offline
Old 04-12-2015, 10:47 AM   #370
crossfire84
I bought these from Jim Carter last year, Since these are not a big seller he does not stock a big supply so he waits till there is demand then has the foundry cast up a dozen pair. Then off to the plater. (foundry and plater are in the USA). I knew this when I ordered these.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 04-12-2015, 10:49 AM   #371
crossfire84
You need a build thread in your signature.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 04-12-2015, 10:56 AM   #372
MARTINSR
MARTINSR's Avatar
Interesting!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline
Old 04-12-2015, 04:54 PM   #373
whitedog76
[QUOTE=MARTINSR;7129896]Interesting!
I was kind of convinced of this swap a couple years ago.
It's taken me awhile to get around to doing anything. Mainly I had to get rid of the 235.
Well the 235 left my garage about 2:30 Saturday and by 4:00 I wedged everything in there. (Literally, I wedged it in. I can show you the Gorilla bar later.)
I'm liking how it's fitting. I'm going to have to notch the front crossmember slightly. If I had a GMC, I don't think I would need to notch anything at all since the crossmember is lower.
The upper coolant outlet on the engine is going to have to be modified. Not to mention the oil pan is going to have to be notched and oil pickup modified to clear the solid axle. All in all, it's a pretty straight forward swap.
I'm going to cut out the old rear engine crossmember though. It doesn't really need to come out, but if I would ever need to work on the transmission, I would have to blow apart the frontend and remove the Engine/Trans. all in one. I think I'll weld some flanges on the crossmember so it can be reinstalled though, since it is a structural component to the frame.
I hate saying this, but the 5 cylinder from the Colorado/Canyon would be a much easier swap. Almost a direct drop in. Rear sump oil pan, and 4 inches shorter would make a world of difference.
Chris
Old 04-12-2015, 05:49 PM   #374
yossarian19
Chris
The 4200 is the correct choice. Don't second guess: the inline six is not only 700 cc more awesome than the five cylinder, it has poetry to it: Old Six ---> New Six. Long Live the Inline.
Forgodsake, though, please document this and make a build thread. It is just too cool to go unnoticed.
"Over my head"
Old 04-12-2015, 07:39 PM   #375
mdpaulson1
mdpaulson1's Avatar
Went to a local car show at a church today and had it blessed! I figured it couldn't hurt, just saying!
mdpaulson1 is offline
Closed Thread
