06-25-2018, 09:53 PM | #351 |
Carpe manana
Re: 1972 Medium Blue Highlander Blazer Resto
Thanks again for all the good words guys. Brad I think I'll follow in your foot steps on another build: father daughter tractor restoration I may be picking your brain on this once we are settled.
I'll shoot some more photos in the next coming weeks. Would be great to make it to WI in time to join a 4th of July parade.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
06-25-2018, 09:59 PM | #352 | |
Carpe manana
Rattle can - took eight cans - after seal and primer. Then painted GM 521 white. Robert who sprayed the top used the same nozzle for all cans. There was a subtle difference in texture with the second can so he used that from the first can for all.
06-25-2018, 11:31 PM | #353 |
Thats what I uses to blend my top when I patched the hard top when I yanked the original owners sunroof (who puts in a sunroof anyways??) I was surprised at how well the texture matches
06-26-2018, 01:13 AM | #354 |
I have a friend that just restored a blazer a couple years back for his in-laws and that is what he used . I didn't get to see it finished.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
07-04-2018, 02:53 AM | #355 |
WOW!!! Pete, this is an amazing build. Another one knocked out of the park! I remember when I first discovered this site and going through your K20 build and how much that one inspired me. Congrats!
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
07-08-2018, 11:06 PM | #356 | |
I really like the work you did on the pillar. How did you do the label? Any chance I could see a close up of that label? It looks excellent! |
07-09-2018, 02:01 PM | #357 |
Vintage 4x4s
Looks amazing Pete! I hope I get to check out your trucks in person sometime. It seems as though you will be closer than ever, just a couple hours or less away
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
07-12-2018, 03:11 PM | #358 |
Carpe manana
Arrived in WI without major issue and settling in. Very happy to be here - lots of surrounding agriculture and beautiful barns. Very enjoyable roads to drive.
Thanks again for the good words. I've not put too many miles on the Blazer yet but the ride is less stiff than my K20 to answer Hemi's earlier question. In fact, I plan to order Alcan springs for my K20 to be installed next spring. Also, the quick ratio in the steer box rebuilt by Red Head hasn't seemed squirrelly at speeds up to 65 mph and is less responsive than that in my 4Runner fwiw. Bugs so far: speedo works but not clocking miles so have another to swap in from Tom (tbone64); radiator fluid weeps out the vent hose more than expected but temp gauge reads wnl so need to located my infared thermometer and measure fluid temp heading into the radiator; the original carb rebuilt by Sean Murphy Induction wouldn't smoothly idle so that at a local shop now, Bigs Performance Products, to be re-jetted and have the metering valve and accelerator pump gone through; need to get correct reduction gear for 3.73 gears so the speedo is accurate. Also wrinkled the SPID Chipflyer made
07-12-2018, 03:14 PM | #359 | |
Carpe manana
Jud thanks - you bet! Would love to visit before the snow sets in. We will likely pop over to MSP often.
01-23-2019, 11:47 PM | #360 |
Hey Pete, you mentioned the door panels were originally green and painted parchment. Which paint/color code did you use for the match? Thanks! I've really enjoyed following the build.
01-23-2019, 11:54 PM | #361 |
Carpe manana
Thanks for following! SEM super white was used and it’s a very good match imo.
02-01-2019, 06:21 PM | #362 |
I'm trying....
Congrats on the well deserved TOTM. Seriously top shelf restoration. Dare I say it...could this be TOTY numero dos??!!!!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
02-01-2019, 09:21 PM | #363 |
Proprietor of Dale's Corner
I'll vote for it for sure.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
02-02-2019, 11:07 AM | #364 | |
Carpe manana
Dale I appreciate the support thank you.
02-02-2019, 11:28 AM | #365 |
Congratulations Pete! Such a dynamic restoration. Excellent blow by blow descriptives allowed all of us to follow along with your journey. You definitely have my vote for truck of the year! All the best for you and the family to enjoy bustin’ out of town in your fantastic K5!
08-16-2019, 11:34 PM | #366 |
Guest
Posts: n/a
Just read the thread--super nice build; make sure you keep it that way and stay off the Midwest salted roads!
08-18-2019, 04:58 PM | #367 |
Carpe manana
Thanks for the good words guys. I’ll post some updated photos soon. Since my last post I’ve had slider windows installed, added a correct cruise master cruise control, installed a working odometer, swapped the rally wheels for white steel 15x8 wheels, and installed a NOS coolant overflow tank.
08-18-2019, 07:21 PM | #368 |
I'm trying....
That's what I'm talking about. I can't wait to see that jewel rolling on pearls.
08-23-2019, 04:10 PM | #369 |
Carpe manana
Still have to add the hub caps.
08-23-2019, 04:20 PM | #370 |
I'm trying....
I love it. The ralleys are of course great...but this is how God intended it to be
...sliders look great too! Edit: ...and also, how many 76 balls have you got!?!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 08-23-2019 at 06:00 PM. |
08-23-2019, 05:51 PM | #371 |
Looks awesome 8” Steelees are the only way to go. Just looks right.
08-24-2019, 09:20 PM | #372 |
Carpe manana
Thanks guys. I’m really pleased with the wheels. These and the rallies I removed were powder coated but the inside of the hub holes were spared. I’ve had problems with wheel removal from the front hubs on prior trucks because of the powdercoat adhering to the hubs. The rallies were removed without difficulty.
I hope to enjoy several more drives before the snow flies.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 08-25-2019 at 09:55 AM. Reason: Bad grammar |
08-25-2019, 09:24 AM | #373 |
^ Been there done that with the powdercoat adhering. Not fun.
08-28-2019, 10:46 PM | #374 |
In those photos there it almost looks 507 light blue. Phenomenal restoration!!
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858 |
08-29-2019, 08:51 AM | #375 |
It looks great Pete. I see you figured out how to do the side sliders. Love them.
