#3901 |
Re: What did you do to your truck today.The 3rd chapter
Think I caused the failure of the ujoint. The only bad ones were where the u bolts hold it onto the pinion . I must have been over zealous in tightening them down . And I highly recommend the Tiger tool for u joint removal makes it super easy I don’t even use the 20 ton press any longer.
#3902 | |
![]() Join Date: Jan 2009
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
#3903 | |
#3904 | |
Super easy . Another must have tool I bought it to remove the u joints on the front axles on my Dodge . Even though it said it was for that application it seemed a little too small . It still worked but the next size up would have worked better they make three sizes . This is the medium one
#3905 |
Some of the "super" u-joints don't have a grease zerk and are not cross drilled for grease channels. This is supposed to aid in strength. That probably matters more for the hardcore offroaders. I just generally try to buy spicer or moog because the seals and grease used seem to be higher quality than the cheaper parts store ones.
#3906 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Got mine back on the road after been down for 20 months, I know not a long time in the rebuild scheme of things, so was out cruising the last 2 days.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#3907 | |
#3908 | |
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#3909 |
Put the driveshaft back in the 72 . Drives like a new truck nice and smooth . Then I put the front bumper back on the 68 what biatch of a job . No matter how much monkeying around with it it’s still not to my liking . I think it’s a little twisted as I get one side in and the other upper bracket didn’t line up . It’s an aftermarket so I would doubt the twist
#3910 |
I'm getting ready to put a much healthier engine back in the 72!
#3911 |
I just wanted to change out my idiot light gauges with a cluster that had guages and I wound up here!
#3912 |
Finished putting her back together today complete with in bed spare tire carrier, tach, dome light with door switches, front side marker lights that work, and windshield washer pump!
#3913 |
More. 😁
#3914 |
![]() Join Date: Mar 2011
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#3915 |
![]() Join Date: Mar 2021
Well done Penka, what a nice change.
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
#3916 |
Started laying out the possible wiring paths for the AAW, FI and air ride harnesses on my ‘70.
#3917 |
Won a trophy asked that it not be judged by t they gave me one anyway . About 75 cars and it’s a top 40 trophy so step above a participation trophy
#3918 |
68 C10 Longbed
![]() Join Date: Sep 2006
Did my first oil change after 500 mile break in! Big step. So far so good on the Blueprint 355/390hp!
#3919 |
![]() Join Date: Feb 2002
I like how you Two-Toned the interior. Not Factory, I don't think, but it sure looks cool.
#3920 |
nothing to my truck today ...but I went to a local car show and saw this 69 owner did the LS swap nice truck ...oh
#3921 |
![]() Join Date: Nov 2018
Nice!!...Pretty Slick Old Tin Indian!
#3922 |
Do the old Poncho's spotlights work?
#3923 |
![]() Join Date: Jun 2022
Replaced some scrungy rear wheel cylinders, but still failed to bleed the back system.
#3924 |
#3925 |
