Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-03-2015, 06:38 PM   #376
greywuuf
Re: 67-72 C/K/T-40's-90's!
Actually, if you check the upper edge of the windshield, and roof line you can see it has been crunched....hard to say how these old trucks may have been scabbed together
greywuuf is offline   Reply With Quote
Old 07-19-2015, 06:34 AM   #377
Stout
Old 09-20-2015, 11:28 PM   #378
greywuuf
Sorry in post #372 I should have said H/J series truck not MH, I am learning slowly but I am learning.
Old 11-15-2015, 05:25 PM   #379
ClassicTVMan1981X
https://www.youtube.com/watch?v=vYVhvywUW8I
The medium-duty truck I see that Justin Hayward (and then his lover) is driving appears to be either a 1967 or '68 (or from '69-'72 if the bow tie is blue) Chevy C40, 50 or 60.
What do you think?
~Ben
ClassicTVMan1981X is offline   Reply With Quote
Old 11-15-2015, 06:05 PM   #380
GM72K10
Next!
GM72K10's Avatar
68, I think I saw marker lights.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 12-07-2015, 02:53 AM   #381
jeff.d
heres a picture of the truck that got me looking for more info on these trucks, and what lead me to this forum!!
and some more i came across in a junkyard just outside of ottawa ontario
jeff.d is offline   Reply With Quote
Old 12-14-2015, 10:12 PM   #382
Thebeast72
Thebeast72's Avatar
here's a rendering of one of the projects I will be starting on soon, it's called The GreenMile.
Thebeast72 is offline   Reply With Quote
Old 12-29-2015, 05:54 AM   #383
Swiftshifter68
Swiftshifter68's Avatar
Awesome! I'll definitely be watchin' out for the build thread, that thing looks great! I'm tryin' to squint and imagine it down, closer to the ground, with a Hodges bed on it for pickin' up customer hotrods & musclecar projects. Hehe
Swiftshifter68 is offline   Reply With Quote
Old 01-17-2016, 11:09 PM   #384
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Here's my 1969 GMC 8500 fire truck, had it about two years now. I didn't need another project, but it was too good to pass up and risk it going to the crusher. I got it from a nearby fire department that was attempting to rebuild it, but decided to look for a newer truck and one that had a higher top speed than 55. It has the factory 478 Magnum V6, 5 speed Spicer transmission and a 7.17 single speed rear. It has about 14,000 miles on it, drives nice and straight and stops on a dime. I had planned on building a winch truck out of it, but decided to build it back into a fire truck. If anything it will be fun to drive in local parades and really handy to have in case a grass fire gets near the property it's stored on lol. I was able to get the original 1200 gallon water tank along with some other equipment, but the rear fenders, running boards, and storage box/monitor nozzle platform above the pump were scrapped years ago. It'll be a Johnny Cash fire truck, I'm building it one piece at a time!
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 01-18-2016, 01:32 AM   #385
C10 - C90 Bill
C10 - C90 Bill's Avatar
Looks good.
The 8500 is pretty rare.
What is the GVW on it ?
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 01-18-2016, 03:09 AM   #386
Hi Bill, it has a 31,000 lb GVW. It has the F090 front axle with 9,000lb springs, and it has auxiliary springs on the rear.
RJD
Old 01-18-2016, 08:58 AM   #387
C10 - C90 Bill
Nice. That means you most likely have 22 Rears. My '67 7500 had 22 Rears.
Does it have Air Brakes ?
GMC 9500 Fan
Detroit Diesel Fan
Old 01-18-2016, 05:38 PM   #388
junkmandan3
junkmandan3's Avatar
Pretty choice old fire truck with the usual low mileage . Only thing wrong with it is the butterfly hood. I think you have too much missing to reconstruct it back into a parade truck .
I just brought home a '83 Brigadier heavy rescue truck with now just over 23000 miles. The significant feature is a 15 KW hydraulically driven generator.
junkmandan3 is offline   Reply With Quote
Old 01-19-2016, 12:34 AM   #389
Yes the rear should be rated at 22K, although it's not stamped in the VIN plate and not listed on the option sheet. It does have air brakes, they're Stopmaster wedge brakes. It has some other neat options: engine alarm system, rapid air compressor, moisture ejector valve(for the brake system), two under-hood work lights, and a factory 62 amp alternator with two regulators. One is under the hood and the other is behind the instrument panel, weird setup but it still works like it's supposed to.
I actually like the butterfly hood, looks cool at night when it's open with the work lights on. I'm a welder by trade and I have plenty of material on hand I can use on this truck to build what is missing, not a problem there. These old refinery rigs weren't built like regular pumpers were as far as storage boxes, etc. It didn't carry much equipment other than hose on top of the tank and a few nozzles, valves, and adapters that were mounted to the side of the tank and the running boards. I also have the monitor nozzle, it looks exactly like the one in the picture below. I found this on yngfire.com, the truck is identical other than the vent behind the hood and the one piece windshield which means that truck is an early to mid 1970's model. That '83 sounds like an awesome truck, a hydraulic driven generator was fairly advanced for that time period.
RJD
Old 01-19-2016, 11:54 PM   #390
junkmandan3
For rear fenders, basement window wrap arounds are available in different heights , and make cheap fenders. Available at Home Depot or Lowes.
Old 01-25-2016, 01:24 PM   #391
Swiftshifter68
......so I'm sittin' on the couch the other night, watching my appx. 1hr. of T.V. for the week and " Ferris Beuller's Day Off " is on (one of the great movies of these modern times, in my humble opinion).
Right after the school principal sneaks into the family home, gets attacked by the dog and then eventually kicked in the face by by a startled Jennifer Grey, he staggers outside and his car is getting towed off. Check out the wrecker handling the tow ......
Old 01-26-2016, 01:39 AM   #392
mrolds88
It's a Ford.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 01-26-2016, 12:49 PM   #393
junkmandan3
Yeah------N model diesel, and could have a 6-71 in it !
Old 01-27-2016, 10:51 PM   #394
Yep, those old Fords had great running diesels, thanks to GM. That's a cool one, but I think some people need to read the thread title. We're not hatin' on other stuff, but this thread is for GM models. There is a thread right next to this one for all big trucks. Use that
Old 02-22-2016, 11:49 PM   #395
68chevycst
68chevycst's Avatar
Here is a picture of my 72 c50 with factory air conditioning.
68 Chevy CST Short Bed, 70 Chevy CST Short Bed, 70 Chevy Short Bed 4X4, 72 Chevy Cheyenne Super 4X4, 72 GMC 1/2 Ton 4x4 Sierra Grande, 72 Chevy 1/2 Ton Big Block Suburban Highlander, 72 Chevy 1/2 Ton 4x4 Suburban, 72 Chevy 1/2 Ton Cheyenne Super, 72 C50 Custom, 69 Chevy CST C30 tow truck, 71 Chevy Big Block C30
68chevycst is offline   Reply With Quote
Old 02-25-2016, 01:11 AM   #396
68chevycst
68chevycst's Avatar
Here are a couple other c50 trucks that I own. The white one is a one owner 1970 c50 that I bought off a ranch in eastern oregon. It has always been stored in a building. It is super clean with low miles. The green truck is a 68 c50 that I bought for parts.
Old 04-03-2016, 05:09 PM   #397
GM72K10
Next!
GM72K10's Avatar
http://montana.craigslist.org/hvo/5479640355.html
Not mine
74 C90 spray Truck
86 K30 CUCV M1028A1
Old 04-03-2016, 07:41 PM   #398
C10 - C90 Bill
Nice heavy truck.
Looks like it has a 13-Speed Road Ranger.
GMC 9500 Fan
Detroit Diesel Fan
Old 04-03-2016, 11:44 PM   #399
junkmandan3
Model is really a JH, not a C .
Old 04-03-2016, 11:51 PM   #400
I like the heavy Chevys.
