Old 01-10-2010, 11:57 PM   #376
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Project '86
Can you cut the stock side glass down the same amount as the chop?
(in effect,... allowing them to roll all the way up)
Old 01-11-2010, 12:01 AM   #377
dv8customs
dv8customs's Avatar
Re: Project '86
The side glass is tempered so you can't cut it.
dv8customs is offline   Reply With Quote
Old 01-11-2010, 12:06 AM   #378
lolife99
lolife99's Avatar
Re: Project '86
So what's the plan for the windshield?
Old 01-11-2010, 12:09 AM   #379
dv8customs
dv8customs's Avatar
Re: Project '86
The windshield is laminate so it can be cut.
Old 01-11-2010, 12:13 AM   #380
lolife99
lolife99's Avatar
Re: Project '86
Learn something every day. Thanks.
Old 01-11-2010, 06:06 PM   #381
Chlsnk
Chlsnk's Avatar
Re: Project '86
Score it and break out the belt sander! I have seen this done! Clean up and bevel the edge with a sharpening stone. I would suggest getting a spare set of windows from Pick and pull to do this on incase you get carried away and break it.
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 01-11-2010, 06:11 PM   #382
ratty 46
Re: Project '86
Use a wet or dry belt & keep some water on it ....... it'll do it!!
Ratty 46
ratty 46 is offline   Reply With Quote
Old 01-11-2010, 06:26 PM   #383
dv8customs
dv8customs's Avatar
Re: Project '86
Ratty 46
Sounds sketchy guys, I have seen that method used on laminate windshields before but never on tempered glass.
Old 01-11-2010, 06:34 PM   #384
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Project '86
ok, I'm with you on not wanting the wing window longer. How about a belt sander as already mentioned on the regular window? Glass is pretty easy to come by in the pick and pull so it might be worth doing some experimenting on some.
Also, I was just looking at Percy's website and the speed glass is made 1" oversize in all directions. I think for the amount of time you would be looking at modifing the doors (not to mention I think it will throw off the proportions by widening the door in that area)that the speed glass is a deal.
http://percyshp.com/store/index.php?_a=viewCat&catId=8
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 01-11-2010, 07:21 PM   #385
dv8customs
dv8customs's Avatar
Re: Project '86
From the speed glass website
Q. “Can I use Speedglass in my factory side window regulators as a functional side window?”
A. We do not recommend making Speedglass side windows functional. However, molded
Speedglass sides have proven very functional in many applications. Percy’s does not guarantee each side window application to install like the factory glass. Adaptors or brackets may have to be fabricated. If Speedglass sides are to be used functionally the user should make sure the wiper seals are very clean and free of dust and debris.
That sounds to me like there is a good chance that the windows will get scratched up from going up and down. All the research I have done about tempered glass says it can not be cut.
Old 01-11-2010, 07:33 PM   #386
smashingchuck
Re: Project '86
I hadn't seen that.... you've picked my brain for sure. I was planning on using the speed glass until I saw that.
Custom 1-piece windows are about $3k.
78 Build Thread
4Runner Build
Old 01-11-2010, 07:45 PM   #387
dv8customs
dv8customs's Avatar
Re: Project '86
Well, so far I only have about $3,000 in this build and that includes the purchase of the truck so custom windows arent going to make the list.
I just marked out the 1/2" that I need to widen the door frame and then used Photoshop to move it over that amount. The frame looks a bit odd at the top radius but that is because I didn't carry my cut over far enough when I made the lines.
As it is now
Moved over 1/2"
As it is now
Moved over 1/2"
Given that that part of the door is next to the wide portion of the cab, I don't think the end result will be very noticable.
Old 01-11-2010, 07:48 PM   #388
smashingchuck
Re: Project '86
it's not as noticable.... I say do it.
78 Build Thread
4Runner Build
Old 01-11-2010, 11:02 PM   #389
Chlsnk
Chlsnk's Avatar
Re: Project '86
I think you will be very pleased if you try it. I talked with my uncle (bodyman 35+ years) And asked him about what to do about glass in a chopped car and he said score the front windsheild and burn it at the line you scored (not quite sure what he ment by this)and for side windows he said have it ground down .
Old 01-11-2010, 11:54 PM   #390
dv8customs
dv8customs's Avatar
Re: Project '86
Tempered glass can not be cut without annealing it first and then re-tempering it. To cut tempered glass you need two tools, a belt sander and a broom.....
Old 01-12-2010, 01:35 AM   #391
begining87
begining87's Avatar
Re: Project '86
Hey guys, I need some help. I am trying to get my doors finished up but I need some info. Since my window doesn't roll all the way up I am left with a gap between the glass and door.
All I have to do is widen that portion of the pillar which is no problem but I don't know how far. Can someone measure how far their glass extends into the door channel? Remember I don't have any weather stripping so measurements need to be from the door edge. A picture would be awesome if possible. Thanks!
I tried to get my weather stripping out of the channel tonight, but that was not in the trucks plan. I took several photos not sure if they would help you. I can tell you my glass is 3/8 " in the weather stripping at the back of the door channel. I took photos of the outside of the door top middle bottom. If that does not give you what you need let me know and I will try to get the weather strip out.
begining87 is offline   Reply With Quote
Old 01-12-2010, 01:36 AM   #392
begining87
begining87's Avatar
Re: Project '86
here is the last image of the bottom
Old 01-12-2010, 08:53 AM   #393
dv8customs
dv8customs's Avatar
Re: Project '86
I was able to get what I needed from a buddies truck but thanks for the effort.
Old 01-12-2010, 09:32 PM   #394
dbmx66
Re: Project '86
meee likey so far
dbmx66 is offline   Reply With Quote
Old 01-14-2010, 02:18 AM   #395
Chevy623
Chevy623's Avatar
Re: Project '86
Awesome work dv8! That tailgate mod is fantastic. I'm new here but so far i love this website, especially this thread. And the progress pictures make it like watching a child grow. Keep up the good work.
Jesse.
Chevy623 is offline   Reply With Quote
Old 01-14-2010, 05:54 PM   #396
dv8customs
dv8customs's Avatar
Re: Project '86
Originally Posted by dbmx66 View Post
meee likey so far
Thanks guys, I am going to try cutting my windshield tonight if the rain holds off. It has a few rock dings in it already so it's really no loss if it breaks.
Old 01-14-2010, 08:04 PM   #397
menace121978
menace121978's Avatar
Re: Project '86
Good luck man!! keep the broom handy
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 01-14-2010, 08:22 PM   #398
dv8customs
dv8customs's Avatar
Re: Project '86
Guess I have more luck with metal than with glass...
It didn't work and I really didn't expect it to but you don't learn if you don't try. Like I said, I needed a new one anyway so nothing lost and some experience gained. I talked to a local glass place before I cut the top that can cut down the windshield for me because I wasn't going to bank on doing it myself.
Old 01-14-2010, 08:44 PM   #399
87 chevy silverado
Re: Project '86
i love this truck more pics please
87 chevy silverado is offline   Reply With Quote
Old 01-15-2010, 01:00 AM   #400
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Re: Project '86
Did you shatter it?
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
