Old 04-22-2013, 01:11 AM   #376
Mustard72
Mustard72's Avatar
Re: 69 GMC "Ol' Blue"
Far closer to perfect than what mine will be. I'll be tackling that in a week or two, as well.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 04-22-2013, 09:39 AM   #377
mjensen
mjensen's Avatar
Thanks guys! I'm pretty happy about how they turned out. Now I just need to figure out what I'm going to do next.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 04-22-2013, 11:25 AM   #378
7dee2
7dee2's Avatar
Looks really good MJ!
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 04-22-2013, 12:54 PM   #379
mcbassin
Still Learning
mcbassin's Avatar
very nice progress!
mcbassin is offline   Reply With Quote
Old 04-22-2013, 08:23 PM   #380
mjensen
mjensen's Avatar
Thanks Brett and Mike!
Mike
Old 04-27-2013, 10:56 AM   #381
mjensen
mjensen's Avatar
Last night I got one of the shock mounts tacked in. Of course this was after I was in a panic because I thought the shocks were too short. Turns out I just so happened to grab the boxes for the front instead of the rear
Here's the temporary fixture I made to hold the tab at the right angle
All tacked in!
Today, I need to finish grinding off the old mount on the driver's side (which I swear the po used an entire case of welding rods on). Then I should be able to tack the driver's side. From there, I think my next course of action will be to disassemble the frame for the top coat of chassis black. I will also use that opportunity to get the axles all cleaned up and painted.
Mike
Old 04-27-2013, 03:41 PM   #382
mjensen
mjensen's Avatar
I was able to grind all the gob welds off the old shock mount and tack the new one on. I think all frame mods are done, so it's now time to tear her down again so I can paint the frame!
If anyone sees anything wrong with this setup, please chime in before it's too late :-)
Mike
Old 05-02-2013, 08:48 PM   #383
mjensen
mjensen's Avatar
Last night I ran across a post by see ten that had a trick using a socket over the studs on the steering arm to "shock" the cone washers out so that you can get the arm off the knuckle. I honestly thought it was BS but I just had to try it. Guess what!?! It worked like a champ!!!! I had it off in about 10 minutes (after hours of heating and banging and cussing prior to that). Of course I destroyed my 1-1/8 deep Mac socket, but you know what that was a sacrifice I was willing to make.
Mike
Old 05-03-2013, 03:10 PM   #384
rgunlock
rgunlock's Avatar
Looking really good Mike! Should go back together pretty fast once you finish painting the frame.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 05-03-2013, 03:55 PM   #385
Mustard72
Mustard72's Avatar
So what did you do with the socket? I've got a 4x4 now, too, and may need to do that at some point.
Nick
Old 05-03-2013, 11:41 PM   #386
HeloCrewChief
HeloCrewChief's Avatar
Came over to check out your build. Very nice man!
1970 C10 to K20 conversion
1974 GMC Jimmy
1968 50th Anniversary Short Bed
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
HeloCrewChief is offline   Reply With Quote
Old 05-04-2013, 11:03 AM   #387
mjensen
mjensen's Avatar
Thanks Rick! That's what I'm hoping for
I'm not quite sure what you're asking here. How I used the socket or what I did with it after? It makes a great paper weight now
Thank you! I've been following your build as well. Coming along nicely!
Mike
Old 05-04-2013, 08:56 PM   #388
rgunlock
rgunlock's Avatar
Is the frame painted yet? At least disassembled?
Rick
Old 05-04-2013, 09:51 PM   #389
Mustard72
Mustard72's Avatar
I was more asking about the trick you talked about doing with the socket, not so much about what you are doing with the socket now that its toast...
Nick
Old 05-05-2013, 01:24 PM   #390
mjensen
mjensen's Avatar
Lol...no, I haven't even worked on it this weekend. I did bring the engine hoist home so I can pull the motor.
Got it I placed the socket over the studs and gave it a few good smacks with the BFH.
Mike
Old 05-06-2013, 08:02 PM   #391
mjensen
mjensen's Avatar
Well, the frame is all torn down. Should be able to paint the frame this weekend.
Mike
Old 05-06-2013, 09:15 PM   #392
rgunlock
rgunlock's Avatar
Dang! That was fast. I was only kidding in my last post
Rick
Old 05-06-2013, 09:50 PM   #393
mjensen
mjensen's Avatar
Well it's time for me to stop screwing around
Mike
Old 05-06-2013, 11:47 PM   #394
Mustard72
Mustard72's Avatar
Yeah! Somebody has to make some progress...
Nick
Old 05-06-2013, 11:54 PM   #395
mjensen
mjensen's Avatar
I was hoping it would be you!
Mike
Old 05-07-2013, 12:05 AM   #396
Mustard72
Mustard72's Avatar
Well, progress is being made, just not on Mustard. I've been getting Blue Bell (the 87 K20) up to snuff. I ended up replacing a stretch of brake line, and I gotta say that your's looks much better than the hodge podge job I did. I think I'll be getting a better bender (like yours) when I do Mustard. The one I have just can't bend a tight enough radius to look decent.
Nick
Old 05-07-2013, 09:32 AM   #397
mjensen
mjensen's Avatar
I actually really like the 87 you picked up. Those 6.2 diesels aren't real power houses, but last forever. Man, I would recommend that bender to anyone. It worked really well for me. Almost made it look like I knew what I was doing
Mike
Old 05-29-2013, 01:24 PM   #398
rgunlock
rgunlock's Avatar
Frame painted and chassis reassembled yet? No pressure at all here, but you've had a couple of weeks now
Rick
Old 05-29-2013, 10:41 PM   #399
mjensen
mjensen's Avatar
I haven't had a chance to work on the truck. I've spent the last few weekends trying to get our motorhome ready for Memorial weekend, then camping, and now next weekend I have to go to SK, Canada for work. So hopefully the weekend after I'll get something done. I should get out there and work on tearing my front axle down, but the motivation fairy hasn't spent a lot of time around here
Thanks for checking in though...I think it helps me lure that bugger in here.
Mike
Old 06-09-2013, 11:37 PM   #400
mjensen
mjensen's Avatar
Hottest day of the year so far here. Nothing like a light baking in the garage
Today my suspicions were confirmed. I tore the front axle apart and found a broken shaft. Damn...oh well, with the axle ripped down this far, it will be getting new seals, u joints, ball joints and a fresh coat of paint.
Missing something here
Mike
