Old 07-28-2009, 11:33 AM   #376
tommys66
Re: 198Plus build by Alan's Classic
Those blasters work pretty good. I also use an old welding helmet with a clear lens. I would not use it inside the shop though. If you lay down a tarp outside its a good way to reclaim the sand used. I buy the fine sand from the local hardware store about $4 a 50lb bag.
tommys66 is offline   Reply With Quote
Old 07-28-2009, 12:57 PM   #377
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Strodder where did you get the spray nozzel on yours? mine is just a ball valve with a tip. I used welding gloves and the hood that came with my blaster but it sucks.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 07-28-2009, 02:56 PM   #378
Strodder
Daring to be Different
Strodder's Avatar
It came with it.
CLOSED
OPEN
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 07-28-2009, 03:33 PM   #379
70 Suburban
Rods
Mine is also a ball valve
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 07-28-2009, 03:37 PM   #380
Strodder
Strodder's Avatar
Notice how I snuck the girlie picture in the back ground.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 07-28-2009, 03:55 PM   #381
MacAttack
283 Drama Queen
MacAttack's Avatar
Yeah, we all saw it.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 07-28-2009, 05:38 PM   #382
4dranch
Shloooooong bed member #2
4dranch's Avatar
I can see this going so far of topic...
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 07-28-2009, 06:56 PM   #383
protrash64
Resistance is Futile
protrash64's Avatar
I was looking at that before I saw the AR-15......maybe I need to go back and read.....
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-28-2009, 08:47 PM   #384
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Thanks for all of the feedback fellars on the blaster. I did pick it up today.
I've never messed with one of these. I put some pressure on it and it works. Don't have a manual, but this looks like it's an adjustable bleed off. I didn't mess with it yet. It starts bleeding pressure at 70 psi. It is adjustable right?
Going to look for a dead man valve. I called tractor supply and was put on eternal hold. Never found out what they had in the store. It needs a new tip. A piece of the ceramic is broken off (not visible in pic).
Got the outside of the tailgate nearly ready for primer. This is what it looks like on the inside. Still in process of sanding.
Also called to get a price on color and clear. I'm going to mix a little at work and spray a panel to make sure it is what he wants.
Alan's Classic is offline   Reply With Quote
Old 07-29-2009, 10:25 AM   #385
Strodder
Strodder's Avatar
I get 125 psi from mine, and it looks like yours. Mine isn't adjustable. Why don't you call the company or look them up on the web and ask what the pressure should be? You want to be save. Maybe it's supposed to be at 70 psi.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 07-29-2009, 12:44 PM   #386
70 Suburban
Rods
That looks to me like a high pressure relief valve.
Old 07-29-2009, 02:41 PM   #387
Strodder
Strodder's Avatar
Pressure relief valves usually have a ring attached to a shaft. ????
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 07-29-2009, 03:22 PM   #388
70 Suburban
Rods
Pressure pop off sorry
Old 07-29-2009, 05:00 PM   #389
198plus
198plus's Avatar
198plus is offline   Reply With Quote
Old 07-29-2009, 08:46 PM   #390
Alan's Classic
The pressure relief is actually like a regulator. I cracked the jam nut loose and adjusted it to 100 psi. I called the manufacturer up in Grand Rapids, but never got a call back.
Old 07-29-2009, 08:50 PM   #391
Strodder
Strodder's Avatar
Typical !!! Call Eastwood. It looks like a Clark, that's what they sell.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 07-29-2009, 11:56 PM   #392
ruffrida2005
Alan you should look into getting a nozzel like Strodders. The ones that we have a cheap and clog up real easy. They do have diffrent size tips though at Harbor Freight. I know on mine I was putting 90psi and it never let air out. I think mine said between 70-125psi.
Paul
Old 07-30-2009, 05:52 AM   #393
Alan's Classic
Going to HF today.
Old 07-30-2009, 10:37 AM   #394
Strodder
Strodder's Avatar
Do they have them at the store or do you have to order them on line?
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 07-30-2009, 12:44 PM   #395
Alan's Classic
They had the stuff at the store. What a cluster that was. I get the employee with a bad attitude. This is what I picked up today. The hood I got for $8 cause it was missing the lense. The deadman was on sale for $15.99.
This came from Ace I told them what I wanted and this is what I got for $3.29. Then got it home and read the back.
This came from Tractor Supply for $7.99
Old 07-30-2009, 03:19 PM   #396
70 Suburban
Rods
BLACK DIAMOND IS GLASS OR GUNNINTE (I THINK) THEY DO SELL BLASTING SAND BUT IT IS ALSO SILICA. i RAN A HOSE INSIDE MY HELMET FOR POSITIVE AIR FLOW TO KEEP THE HAZARD DOWN
Old 07-30-2009, 04:01 PM   #397
Strodder
Strodder's Avatar
So what are going to concrete. Nice hood are you going to put a pompom on the top?
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 07-30-2009, 04:25 PM   #398
Alan's Classic
I'll see what I can rig up for fresh air. I've got the HEPA body man mask, fresh air would make it better. I could Get a race car helmet that has the fresh air duct on top of it.
That's a hard hat in there. I might make it into a halloween mask.
I got to work on Ronnies for about an hour today and I looked up at my shelf along the back wall and it was about ready to come crashing down. Just something else I gotta fix damn it!! The wife helped me get everything off of it after I put a brace under it. That would have been a real big mess. It would have fell on my truck if it came down. I'll get some pics later. I'm just glad I saw it.
Old 07-30-2009, 04:39 PM   #399
Strodder
Strodder's Avatar
Glad you caught it in time. My son just moved to a different house, and he put a lot of his garage stuff up in the garage attic. Next day he went in there and the sealing was bowed down and about to fall down. At the time he still had furniture in there that he hasn't moved into the house yet. He wedged in some 2X4's to hold it up. What a mess that would have been.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 07-30-2009, 08:27 PM   #400
ruffrida2005
Alan I have some of that Black Diamond too, what numbers is your? Mine was the fine grit. Let me know how is sprays with that deadman valve. Glad you caught the self from fallon down.
Paul
