04-07-2015, 09:14 PM | #376 |
I'm trying....
Re: 70 Blazer Frame Off
No pics...but a significant update. Fired her up tonight. We had a fuel leak last night that stymied us and delayed the big moment. But after regrouping and going through our preflight checklist tonight, she basically started on the first turn. A little fine tuning will of course be in order, but we didn't let her go long because the oil pressure never came up....which at this point I'm convinced is a problem in my gauge/line. But we're taking no chances. I totally should have put an electric gauge in there and I know it, but I'm going to swap out the oil line tomorrow. I was so zealous in not having a leak in that copper line, I'm thinking I might have overtightened the compression fittings. Please feel free to comment on my stupidity.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
04-07-2015, 09:35 PM | #377 |
Carpe manana
Having a celebratory beer - congrats! Fire it up w the line open at the gauge end to bleed and document flow?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
04-08-2015, 10:56 AM | #378 |
Milestone! It feels so good hearing it run for the first time, congrats!
04-08-2015, 02:42 PM | #379 | |
I'm trying....
Thanks, it did sound great...especially through the 20 odd feet of dryer vent serving as our one off custom exhaust.
04-08-2015, 08:06 PM | #380 |
I'm trying....
Good news-got plenty of oil pressure.
Bad news-cluster has to come out...gauge is bad.
04-08-2015, 08:08 PM | #381 |
I'm trying....
Jim...spring got here today. It's a perfect example and will clean up great...can't thank you enough.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 04-08-2015 at 09:25 PM. |
04-08-2015, 09:58 PM | #382 |
No stupidity"............stuff happens........ask me how I know!
Congrats on getting it fired up........give me a couple weeks to get past the spring rush at work and I want to come see it.....
1970 2WD Blazer 454 1972 C-10 Extended Cab 350 SBC |
04-08-2015, 10:04 PM | #383 |
I'm trying....
Thanks...I guess April is tough for you and accountants
04-09-2015, 08:17 AM | #384 |
Brad your welcome, glad I could help a little. Congrats on firing up the engine. Wish I was doing that, but I m working on brakes
Hope things continue to work out on your build, great build Lock Doc is selling oil lines in the classifieds, you might have a hard time finding those ferrules
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
04-10-2015, 06:58 PM | #385 |
I'm trying....
Here is a little of us two steppin' backwards today. Everything came off so we could fix the paint issues associated with our fuel line leak. Then all back together with a little Loctite thread sealer version 565 for fuel lines. Fingers crossed we've got it licked.
Took out the oil pressure gauge, couldn't see an obvious problem. Luckily they're just going to warranty that...for a minute they wanted me to take out and return the entire cluster.
04-10-2015, 07:08 PM | #386 |
I'm trying....
As an aside...I started taking apart the bucket seats that I got from another board member today for clean up. Here's the manufacturer date on the back...since I've been so consumed with build date stuff and looking for other build date clues under the dash, behind the cluster, on the rear axle and the transfer case...If my truck had it's original seats, this would have been another date to add to the stack.
04-11-2015, 02:18 AM | #387 |
Making progress, I see! Great job..
What plate is this on your T-case?
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
04-11-2015, 07:14 AM | #388 |
I'm trying....
Thanks...
...It's the build tag from New Process. Here's the only close up shot I've got of it. It came back from the transmission shop in full primer. We had to go back and detail it.
04-14-2015, 09:31 PM | #389 |
I'm trying....
The old girl got quarantined off so the hood, tailgate, and a bunch of other odds and ends could get worked and painted....
04-17-2015, 07:22 PM | #390 |
I'm trying....
Black on the hood ended up being a little flatter than we were going for, but it looks too good to change. Color on the inside of tailgate and other small bits. Painted an OE set of vents as well as the repro ones that came with the VA set up...since the repro ones fit kind of like repro ones do.
04-19-2015, 06:17 PM | #391 |
I'm trying....
Vents in and hood back on. A little bit of gapping and a lot of prepping for final paint this week.
...it's definitely time to trade in the old iPhone. My photo quality seems to have really degraded over the course of this build. Surely it's not me.
04-19-2015, 08:21 PM | #393 |
I'm trying....
04-19-2015, 11:06 PM | #394 |
Member
Looks Great!
Korey 1955 Bel Air 2 door hardtop 1971 Blazer 4x4 1973 Z-28 Prostreet |
04-20-2015, 12:48 AM | #395 | |
Cluster King
Your comment on an electric oil pressure gauge is prompting me to se if there is any market for a conversion. I did the volt gauge conversions for our trucks and they sell rather well. I am not sure if there would be a market for the oil pressure conversion to electric. I have some ideas. The hardest part would be modifying the stock gauge tin to accept the new style gauge. My idea would give you a electronic gauge that looks stock in the dash. If you need a factory oil pressure gauge let me know. I have them in 60 and 80 lb Keep up the good work, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C Last edited by TBONE1964; 04-20-2015 at 01:02 AM. |
04-20-2015, 07:23 AM | #396 | |
I'm trying....
Thanks.
Edit: To be clear, I think there would be a great market for electric oil pressure conversions. It just seems to make sense to me.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 04-20-2015 at 07:58 AM. |
04-21-2015, 06:39 PM | #397 |
This thing is looking fantastic.
04-21-2015, 07:46 PM | #398 |
I'm trying....
Thanks Jarrod...I appreciate that.
04-21-2015, 07:52 PM | #399 |
I'm trying....
Grille went back on for hood fitment...even if it's just temporary, couldn't help but take another pic.
...more wet sanding. Getting closer to spraying color.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 04-21-2015 at 08:05 PM. |
04-21-2015, 09:14 PM | #400 |
Brad, your work is impeccable....grille looks sweet on there, always enjoy reading your updates
Tags |
1970, blazer, k5 blazer, restoration, silver |
