Old 01-01-2020, 03:00 AM   #376
cwcarpenter98
cwcarpenter98's Avatar
Re: Frankentruck
I've been bad at taking pics while I was working on them, but I've got the reverse light buckets repaired with some JB weld and painted with rust reformer and painted the inside of the bucket gloss white.
I got the holes drilled in the end caps, but couldn't complete the install because I'm waiting on the seals and such to show up, and I need to get the clips that hold the buckets to the body.
A NOS backup lamp switch is on it's way from California. I decided to go NOS for 2 reasons: one, Frankentruck deserves some NOS goodies and two, I don't have a whole lot of faith in the aftermarket switches especially when I could only find it from LMC. The NOS switch was about the same as the repop one from LMC after shipping.
Some other NOS goodie is a single speed wiper washer switch. I'm keeping my factory wiper motor, but wanted a proper switch in the dash to make the Ford washer pump work like the GM one would have. Also, I like keeping fluids out of the cab, so it made sense to use the Ford stuff with a pump in the bottom of the reservoir.
I also pulled some parts off the other core support I have so I can figure out what I want to do about getting it repaired. I need to sell the stuff I'm not using because I'll probably end up paying someone to fix the bottom of the support. It looks like it just needs corners as the center piece is surprisingly solid.
Happy New Year y'all!!
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-03-2020, 09:23 PM   #377
cwcarpenter98
Re: Frankentruck
All this rain has hampered my progress. I was also waiting on parts to show up, but our house is one of the last couple of stops for the UPS route, so they didn't arrive today until 20 minutes ago. Too dark and wet outside to do anything about it tonight.
The rain made progress slow, but I was able to finally fix my horn. Turns out the wire to the button had melted and split long before I got the truck. I replaced the wire and robbed a connector off my old wiring harness so everything would work as intended again. I got everything back together and honk honk, the horn works again!
First time everything has worked on the truck since I've owned it
Christian Carpenter
Old 01-03-2020, 10:51 PM   #378
flashed
Re: Frankentruck
At least you are making progress . I got the 65 Service Truck off the trailer at the Truck Farm and went yesterday after work to grab that free square body but it was falling a flood when I got there . Another time soon I hope . All this rain stinks but it beats Snow .
flashed is offline   Reply With Quote
Old 01-04-2020, 12:41 AM   #379
cwcarpenter98
Re: Frankentruck
Slow progress is still progress, and yes, snow would be worse
Christian Carpenter
Old 01-04-2020, 10:42 PM   #380
cwcarpenter98
Re: Frankentruck
The swap meet ended up being a bust. Probably no more than 30 vendors and not that many other people. I'm just glad I didn't bring anything to sell.
Once I got home, I started working on the reverse lights again. Got everything screwed together and then the bucket that I had to repair broke again. I guess I'm on the hunt for another bucket now. At least the driver's side went together nicely.
I also got my first NOS part for Frankentruck. New reverse light switch showed up today, but I don't know what size screws that I need to bolt it up.
I'm headed back to school tomorrow, so the truck will sit for a bit, but I'll get back to it eventually.
Thanks for following along y'all
Christian Carpenter
Old 01-05-2020, 02:40 AM   #381
Sevens
Sevens's Avatar
Re: Frankentruck
I'm new to the forum...part of the reason I joined was your thread. I spent a LOT of time reading every single post and I must say that I really enjoyed your entire thread. Thank you for sharing your story!
I look forward to seeing more of your journey.
Side note; I live in San Diego but I have a lot of family in Augusta, Athens, Cumming, Greensboro and also in Alabama.
Sevens is offline   Reply With Quote
Old 01-05-2020, 08:09 PM   #382
cwcarpenter98
Re: Frankentruck
Welcome to the forum! Thanks for following along, I appreciate the kind words. If you ever want to see the truck in person, let me know next time you are visiting family here in GA
Christian Carpenter
Old 01-18-2020, 12:08 AM   #383
cwcarpenter98
Re: Frankentruck
Reverse lights are working
I had to take the socket out of the bucket to work out the puncture in the socket, but it is fixed now and works great. Ran the wires today and zip tied the switch to the column since I dont know what size the screws are. It works, but not sure how long it will hold.
I also got a glove box light, but I haven't been able to figure out how the spring goes so that the door will pop open just by pressing the button.
Christian Carpenter
Old 01-18-2020, 06:21 PM   #384
cwcarpenter98
Re: Frankentruck
I picked up another 63 grille this morning. I didn't need it, but I got it for a decent deal and I got to see part of north Georgia that I've never seen before.
I also was able to pop in the new cancelling cam for the turn signals
Christian Carpenter
Old 01-23-2020, 04:15 PM   #385
cwcarpenter98
Re: Frankentruck
Just dropping in a pic that shows how the reverse lights look during the day. I guess I ought to polish the tail light trim to go along with the chrome on the reverse lights
Classes are about to be my main focus, so probably not going home any time soon to work on the truck some more. I'll still be hanging out here with y'all on my study breaks
Christian Carpenter
Old 02-03-2020, 10:03 PM   #386
cwcarpenter98
Re: Frankentruck
Swinter hit here in Milledgeville today. 73 degrees but no c10 to drive around in
It was nice to drive with the windows down and the music up though
Christian Carpenter
Old 02-08-2020, 11:09 PM   #387
cwcarpenter98
Re: Frankentruck
Hold on to your hats folks, I've got a pretty neat update for y'all
I went home yesterday to do an interview for a possible summer internship. Of course, since I was home, I went to meet my buddy for breakfast at a place called Martin's (better food and cheaper than Chick-fil-a breakfast). While we were eating, some white stuff started falling from the sky.
It snowed at least 2-3 inches in North Georgia today!!! I've never driven in the snow before until today. It's a lot like driving in mud, but sketchier. Thankfully, it was above freezing the entire time I was out driving, so the snow on the roads was more slush than snow, but still was kinda fun. I went real slow and kept plenty of space between myself and the people in front of me.
Anyways, Frankentruck did great on the trip to and from Cartersville in the snow to pick up some more parts that I found on Facebook. Originally went for the hood and grilles that the guy had for sale, but left with much more
I only had one thing go wrong today. The passenger side wiper arm broke at the mounting point. This was one of the junkyard arms that I pulled and I'm thinking that it might have been cracked and I just didn't notice it. At least it wasn't the driver's side that broke!
Here's some snow pics for ya
Christian Carpenter
Old 02-08-2020, 11:21 PM   #388
cwcarpenter98
Re: Frankentruck
Now on to the parts I scored!
A 60-61 GMC hood that is in nice shape with only a few, small issues of rust. It only has one dent that I noticed and that dent is smaller than a penny. The turn signal lenses are cracked badly, but they'll work for now.
I bought 2 more grilles that are both in great shape. One is a 60 with the headlight bezels and the other is a 62. Of course, I forgot to take a good pic of the grilles.
61 Chevy hood turn signal pods with light buckets that are in great shape. Definitely the nicest set of pods that I have seen myself.
A much nicer grille support panel to replace my dented and rusted out one.
A surprisingly straight fleetside bumper that had a trailer hitch cleanly installed through the middle of it. Not sure if it is 60-62 or 63-66. I didn't think to check the measurements of the bolt holes.
Another 60-63 radio delete plate that is in much nicer condition than the other one I have.
A passenger side 60-63 sail panel trim piece that isn't in the best of shape. Might end up becoming wall art.
Also, a nicer horn button that has fewer pitted spots and nice paint on the bowtie.
Christian Carpenter
Old 02-08-2020, 11:25 PM   #389
cwcarpenter98
Re: Frankentruck
This hood is almost too nice to put on my rust bucket
I would rather have a 60-61 Chevy hood, but this GMC hood was such a good deal that I couldn't pass it up, even if that meant driving in the snow for the first time.
The guy I bought it from saved the hood from a truck that was getting sent to the scrap yard after a tree had fallen on the cab.
Christian Carpenter
Old 02-16-2020, 02:56 PM   #390
rusty76
rusty76's Avatar
Re: Frankentruck
Nice score on the parts for sure.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 02-16-2020, 07:45 PM   #391
cwcarpenter98
Re: Frankentruck
Thanks! I went to look at the hood and the two grilles, but got all the other stuff in the deal as well. Did I need it? No, but I wanted it
Christian Carpenter
Old 02-17-2020, 12:02 AM   #392
flashed
Re: Frankentruck
Its better than Money in the bank right now Christian .
Old 02-17-2020, 03:58 PM   #393
cwcarpenter98
Re: Frankentruck
That's probably true. I didn't even have that money in the bank though. I keep my truck parts fund separate from my bank account at the moment
Christian Carpenter
Old 02-28-2020, 10:55 AM   #394
cwcarpenter98
Re: Frankentruck
Had a great time last night at the C10 Club Georgia wing night.
Lots of good trucks, but I only took this one pic
The six lug steelies I picked up a couple months ago came off of the red truck in the pic when he swapped over to 5 lug
Christian Carpenter
Old 02-28-2020, 08:41 PM   #395
cwcarpenter98
Re: Frankentruck
As a study break today, I finally replaced the parking brake cable that snapped.
I had replaced the two cables that run to the wheels back when I did the disc brake swap, but didn't have an issue with the frant cable at the time.
The new front cable was around 15 bucks or so after shipping because it shipped with the replacement Jeep wiper arm (junkyard arm broke at the hinge). The length is almost spot on to the original one, but the only issues I have with it is that the attachment piece at the handle isn't wide enough and the 2 adjustment nuts at the other end are 13mm. For the price though, I can't complain too much and my parking brake works again
Christian Carpenter
Old 02-29-2020, 11:57 PM   #396
cwcarpenter98
Re: Frankentruck
Some people probably think my truck should be in a junkyard, but instead, I drove it to the junkyard
Christian Carpenter
Old 03-06-2020, 11:09 PM   #397
cwcarpenter98
Re: Frankentruck
I took a 4 hour round trip today to pick up a trailer hitch for Frankentruck. It was a bit of a drive, but for the price, I couldn't pass it up. Looks like I've got a lot of stuff to do over spring break
Christian Carpenter
Old 03-13-2020, 03:41 PM   #398
cwcarpenter98
Re: Frankentruck
Just got back home for my Carona virus extended, 2 week spring break. Of course, I had to stop by the local junkyard and grab some parts.
Gonna go pull the old steering gear off
Christian Carpenter
Old 03-13-2020, 08:23 PM   #399
cwcarpenter98
Re: Frankentruck
Got some good progress done today. I'll say it, rivets suck. It got dark out, so I had to stop for the night, but I'll be back on it tomorrow morning.
After grinding the head off, I had to drill into the rivet so my punch would stay in place and actually knock the rivet out.
Hopefully I'll be able to finish it up tomorrow
Christian Carpenter
Old 03-15-2020, 11:13 AM   #400
cwcarpenter98
Re: Frankentruck
Progress from yesterday wasn't too much because of the rain and running into a question about if the bowtie piece on the rag joint should be replaced or not.
Hopefully some more progress will happen today!
Christian Carpenter
