06-11-2016, 04:21 PM | #4126 |
Post Whore
Re: Restoring Rusty
you know the drill, time for a stare and compare
old bearing and new bearing [mini rant] I don't know about you, but I struggle to view these things as bearings, to me a bearing has balls in it, you know what I'm saying, these there things are like shims to me, I just can't wrap my small mind around the concept thats all [/mini rant] |
06-11-2016, 04:44 PM | #4127 |
Re: Restoring Rusty
That really sucks. I hope replacing the bearing helps. Seems I've never heard my old truck not tick somewhere. Lol. My toaster(daily) is just too quiet. But it does have AC.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
06-11-2016, 06:57 PM | #4128 |
Post Whore
Re: Restoring Rusty
well, so I replaced the #4 con rod bearing, did that make the engine ticking noise go away?
NO my goodness, what is up with Rusty? so I parked it on the street and started drinkin' |
06-11-2016, 07:11 PM | #4129 |
Re: Restoring Rusty
Keep in mind the cam turns at half the speed as the crank so a piston or rod noise would be twice as fast as a valvetrain related noise.
06-11-2016, 07:30 PM | #4130 |
Re: Restoring Rusty
Yeah, but to get your zinc (ZDDP, actually) up to where it needs to be, you only need to use four ounces. ZDDPPlus is $10/bottle on Amazon, and you only use half a bottle per change. Too much is not good either.
Rich Weyand 1978 K10 RCSB DD. |
06-11-2016, 09:14 PM | #4131 |
Re: Restoring Rusty
Wrist pins maybe?
06-11-2016, 10:49 PM | #4132 |
Re: Restoring Rusty
Did you Plastigage #4? That would have been a quick way to rule out or condemn the rod bearing.
I still maintain it's a piston problem; I'm with peabobble.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
06-12-2016, 12:41 AM | #4133 |
Post Whore
Re: Restoring Rusty
06-12-2016, 12:43 AM | #4134 |
Post Whore
Re: Restoring Rusty
Gentlemen, could it still be the exhaust header even if the noise goes away when I unplug the spark plug wire on #4?
I am tempted to pull the headers off (at least on that side) and bolt up my old manifolds and see what that does, but if you think its a waste of time knowing that there is no noise with #4 plug disconnected than let me know. |
06-12-2016, 12:45 AM | #4135 |
Re: Restoring Rusty
You won't likely feel any up and down play - you need the piston out, and try to rock them.... um... like, rock the piston down while you rock the con rod up - kind of feeling if the wrist pin hole is elongated.
Assuming a piston skirt or ring isn't broken.
06-12-2016, 12:47 AM | #4136 |
Re: Restoring Rusty
Oh. Exhaust leak....... Interesting.
Can you give a listen with a stethoscope or long screwdriver, and see if the sound is coming from the BLOCK, or from the HEADER TUBE. Sometimes header tubes make a ticking sound, just the speed of the gasses hitting the corner of the tube or something.
06-12-2016, 01:29 AM | #4137 | |
Post Whore
Re: Restoring Rusty
The stethoscope and the long screw driver let us hear the internals of the engine but thats not the ticking sound, also there is no tapping sound from the distributor, no sound from the fuel pump, no sound from the starter, no sound from the exhaust manifold, its so bizarre actually drove the truck with #4 spark plug unplugged to show my buddy and man the truck sounds so smooth without it, I just wish I had a V8 and not a V7, lol |
06-12-2016, 01:37 AM | #4138 |
Post Whore
Re: Restoring Rusty
well seems like this dude on YouTube has the same problem, and of course the video is abandoned and we don't know what it was or how he fixed it
Piston Slap, Spun Bearings, Valve Lash, Engine Noise Diagnostics 02 Engine Noise Diagnostics |
06-12-2016, 01:54 AM | #4139 |
Post Whore
Re: Restoring Rusty
Man I wish I tested my pistons like this guy is doing in this video when I had my engine out and the cylinder heads out, check it out and tell me what you think
5.3 LM7 Piston Rock aka Piston Slap |
06-12-2016, 02:32 AM | #4140 |
Moderator
Re: Restoring Rusty
This isn't an LS motor or even a Vortec smallblock like you liberated the heads from. Tolerances were pretty loose on the earlier Gen I smallblocks.
Look in the 1974 service manual. The '70s GM engines were intended to be run on 10W40 and even 20W50 motor oil except at fairly low temperatures. The chart in the 1974 GM service manual says to run 5W30 if the outdoor temps range from less than -30°F to 60°F max. That same chart says to run 20W50 between 20°F to over 100°F. Sacramento averages 60°F year round... For Sacramento to get below 20°F would mean the apocalypse is fast approaching. Try swapping to a higher SAE weight oil... Running a good synthetic 20W50 should quiet her down and it will not hurt a thing to use year round. If it's a loose wrist pin it won't change a thing.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
06-12-2016, 09:07 AM | #4141 | |
Post Whore
Re: Restoring Rusty
yesterday we put brand new 20W-50 engine oil in with a brand new oil filter, the Lucas zinc additive and added the Lucas HEAVY DUTY oil stabilizer, our ratio is extreme for testing purposes of 2 quarts Lucas and 3 quarts oil, its really thick on purpose right now to see if it will quiet down the noise, and it does NOT |
06-12-2016, 12:34 PM | #4142 | |
Re: Restoring Rusty
06-12-2016, 06:34 PM | #4143 |
Post Whore
Re: Restoring Rusty
Well, well, well, what do we have here?
Could that be numero quatro? |
06-12-2016, 06:41 PM | #4144 |
Re: Restoring Rusty
You need some 1444 Felpro's
06-12-2016, 07:04 PM | #4145 |
Post Whore
Re: Restoring Rusty
06-12-2016, 07:04 PM | #4146 |
Post Whore
Re: Restoring Rusty
06-12-2016, 07:13 PM | #4147 |
Re: Restoring Rusty
06-12-2016, 07:59 PM | #4148 | |
Re: Restoring Rusty
They fit the Vortec exhaust ports perfectly. They are the only kind that I have used that I would recommend. They are great gaskets with metal reinforcement. |
06-12-2016, 08:10 PM | #4149 |
Re: Restoring Rusty
I've had great success with these:
06-12-2016, 09:22 PM | #4150 |
Re: Restoring Rusty
Just finished reading the whole thing. So glad it's just a gasket. You've done such wonderful work. I can't wait for my kids to get a little older to give me some more time to work on my stuff.
