Old 06-08-2014, 11:47 PM   #401
KroAutomotiveInc
KroAutomotiveInc's Avatar
Re: 1960 GMC K1000 4x4
This has got to be the best modification I've done for actual improvement from before. This thing is so quite now the silence was almost numbing lol. It also takes off much faster i'm also impressed with the clearance!
Best safety glasses ever!
What do you guys think?
KroAutomotiveInc is offline   Reply With Quote
Old 06-09-2014, 01:41 PM   #402
mud.man.rj
mud.man.rj's Avatar
Nice job, how does it work, any vibration or all good.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 06-09-2014, 02:12 PM   #403
KroAutomotiveInc
was smooth as could be at 40-45 haven't hit the freeway yet tho.
Old 06-09-2014, 03:23 PM   #404
61K10
61K10's Avatar
just shows what you can do when you put your mind to it!!!! good job!!!
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-10-2014, 01:44 AM   #405
KroAutomotiveInc
Thanks guys it drives so nice now i'm amazed at the difference its a different truck. No problems on the freeway could keep a steady speed much easier and could just cruise at 80 like a dream. The power it puts to the wheels now is impressive its never tested until you do a burn out and it past with flying colors lol! Its also lighting the tires up for a second in 3rd at 35 if you punch it
All in all this really made the truck more usable to me at the moment and it only cost me 2 holes in my frame nothing else was changed other then removing the t case. Pondering a break booster as well this thing is not fun to stop at high speeds its almost terrifying...
Old 06-10-2014, 09:47 PM   #406
Zane M
Good job!
Zane M is offline   Reply With Quote
Old 06-11-2014, 04:42 PM   #407
KroAutomotiveInc
joy ride in the 60.
http://youtu.be/TWguSesfJy0
why half the time the video appears and others just the link i have no idea.
Old 06-12-2014, 08:31 AM   #408
piratexpress1369a
piratexpress1369a's Avatar
cool vid ...sounds like it is working just fine now
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 06-12-2014, 10:14 AM   #409
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Awesome Kro!!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 06-12-2014, 11:05 AM   #410
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
DUDE! That thing is running nice! Now you can come an visit! LOL!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 06-16-2014, 03:18 AM   #411
KroAutomotiveInc
http://youtu.be/7GMfwvSkkEE
Checking out the ol 64 I6!
Old 06-16-2014, 03:22 AM   #412
KroAutomotiveInc
http://youtu.be/YfZ4hk1IpkQ
Do you guys agree that the coolant in the oil is just from leaking past the rings?
It only started getting water into the oil once it was running it was also pushing exhaust pressure into the cooling system.
Old 06-16-2014, 03:23 AM   #413
KroAutomotiveInc
So frustrating that the videos will not create a thumbnail not sure who has the problem me or the site but its annoying!
Old 06-16-2014, 10:54 AM   #414
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Probably gonna want the head surfaced, magnafluxed, and checked for cracks...and new pistons and rings would be good to..Dude..Why not do a full rebuild on the engine? There are stock engine kits on ebay for as low as $300...If I was you I'd get me some flat top pistons, a 194 head, little more cam, and some headers an a 4 barrel...You should see about 160 hp with that...maybe even slightly bigger intake valves 1.84 over the stock 1.72...then have lumps installed...15% more airflow...I've heard great stories about the lumps.
Old 06-17-2014, 01:06 AM   #415
KroAutomotiveInc
I think your right TJ me and my old man were talking it over about the band aid so to speak with just getting her running again. I really love and miss this motor so i want to do her right. I want to do some custom stuff with the intake and build a split manifold as well.
As for getting the 4x4 on the road again i just happen to come along a 400 sbc for trade what do you guys think?
Old 06-17-2014, 07:31 AM   #416
piratexpress1369a
what will the trade be ..400 sbc is cool ,but how good is it ..does it run ,will it need a rebuild to
63
Old 06-17-2014, 10:35 AM   #417
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Header look good to by the way. lol Nice! 400 sbc is a nice engine! They run hot, but give some good power...does it run?
Old 06-17-2014, 03:10 PM   #418
KroAutomotiveInc
The trade is for labor so really not losing anything out of pocket atm. yes its rebuild would be ready to drop in. Why do they run hot T.J i don't no anything about them i didn't even know it was a Chevy motor at first when he said he had a 400. It came out of a late 70's or early 80's 2wd short bed he said it would just boil the tires off the truck! He pulled and rebuild he was going to stick in a boat but ended up in his garage.
Old 06-17-2014, 10:54 PM   #419
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Not sure why they run hot...they were made that way I guess...but...nothing to worry about...yr heater will work better.
Old 06-19-2014, 12:42 PM   #420
61K10
61K10's Avatar
Kro--they do run hotter than a 350 but with a good rad it should be fine. on the 400 the center cyl's are like Siamesed so no water flows between them, something like that. I ran one 406 in my Nomad for a few years before i went big block. I liked that eng 406 better than my BB 468.
1961 chevy K10
Old 06-19-2014, 09:16 PM   #421
mud.man.rj
mud.man.rj's Avatar
Nice part about a 400 is they Rev like a small block but have a lot of torque.
5.0 4spd std.
7" lift w 35's.
Old 07-05-2014, 02:57 AM   #422
KroAutomotiveInc
Well guys i ended up finely pulling off a full time job to coincide with my part time job been looking for almost a year... So I've decided on a full rebuild of the 230. Also decided I'm going to get a newer car so i stop running into problems with getting to work in these old beasts. I'm half way tempted to go get a 2014 impala Started on the split manifold tonight here's what i got so far!
Tomorrow with the mig welder my BBQ and a bit of patience i hope to have her finished.
Old 07-05-2014, 08:07 AM   #423
RANDY COX
RANDY COX's Avatar
Cool that's where's it's split on my ole car it's a stovebolt 216 it has a flowmaster with dual inlet and dual outlet. They sound great..
Click the pix it should take you there to here it...
I was debating to do this on my truck with the 292.. Maybe later...
good luck with yours...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 08-31-2014, 06:17 PM   #424
KroAutomotiveInc
So i'm finely getting back around to the truck. I've been missing her lately i want to run the I6 in it but at the same time i just cant discard the v8 if it would take less money to get running again. I'm looking at atleast 800 to rebuild the I6. So i took the time last night to figure out whats up with the v8. Looks like i can get a pair of rebuild heads and she would be ready to run again its got a gouge in the piston but its still ok its not very deep. Was looking on the local classifieds last night and it looks like i can just buy another set of machined heads for close or less then rebuilding mine.
What do you guys think happen to cause this to happen, do you guys think the lifters are ok? me and my old man are thinking the value spring is what caused the value not to close fast enough allowing the piston to hit it. it over headed when it happen.
Old 08-31-2014, 07:41 PM   #425
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Weak valve springs may have been an issue..or a possibility of a sticky valve? To much lift on the cam can cause the spring to sprong. lol
1960 gmc, 4x4, 60-66, gmc, k1000
