#401 |
Re: 75 Dually build
#402 |
Re: 75 Dually build
I got the drivers side 4 link mount welded up last night. I also welded up the bars last night too. Now All I have to do is the mounts to the axle for the drivers side, and the new watts link assembly. I just need time to get the metal cut and get it mocked up. Maybe this weekend (if the wife let's me...)
#403 |
Member of the longbed union.
Re: 75 Dually build
With your wheels on, How much room is between the frame and the wheels. Just trying to get an idea because I'm gonna run stock inner wheel and then later go to semi wheel whenever I find 2 more.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#404 |
Re: 75 Dually build
I would say there is a good 5"-6" clearance between the inner wheel and the frame rail. As you can see by this old pic looking down on the bed as I was mocking up the rear there is a ton of room. Clearance is not a big issue on this truck. Thankfully there is enough room there to run bigger suspension components without any issues.
#405 |
Re: 75 Dually build
Oh yeah that is plenty of room. I'm gonna do a six link and was wondering for bag placement for rear links. It sucks never being near my truck.
#406 | |||
Squarebody guy
Re: 75 Dually build
Just a reminder for me and everyone who may have any questions on the specifics to your rearend setup lol
3/4 ton SRW 14B axle complete Semi wheels faced 3/8" per wheel on all 4 rears 285/xx/22 tire The magical combo per se.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress |
#407 | |
Re: 75 Dually build
#408 |
Re: 75 Dually build
Looks like it's coming together really well for you. How long did you end up making your bars?
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192 Instagram: lofab77 |
#409 |
Squarebody guy
Re: 75 Dually build
Haha I will lose track otherwise! I have been bouncing back and forth on whether I should use my 3/4 14B as delivered or make it C&C width with my dually hubs. My wheels haven't been faced and I am going lower than you so I will most likely have problems.
I had a local guy who in the same breath said he could face my wheels and that hes not sure he understands what I am talking about.
#410 |
Re: 75 Dually build
I probably wouldn't use that guy.
#411 |
Re: 75 Dually build
#412 |
Re: 75 Dually build
I got the drivers side tacked up tonight! I will finish welding everything up tomorrow. Then I can get started on the new watts link. Can't wait!
#413 |
Re: 75 Dually build
Got the sensors mounted up today. Now to get all this stuff painted up, and the watts link finished up tomorrow. I want this back on the road soon!
#414 |
Re: 75 Dually build
Looking good. How do you zero out the sensor when setting it up. I haven't messed with accuair yet.
#415 |
Re: 75 Dually build
It is right out of their instruction manual. They have the best instructions I have seen in a long time. Once you get a set you will see just how easy it is to set up. Then after you get them mounted you go through a calibration phase and if all is right with the world they work like magic!
#416 |
Re: 75 Dually build
The pic from above makes me think it would be possible to fab a notch that notches inward as well as up, like a pinch - notch, that would allow mounting the bags on top or behind the axle, yet still inboard of the link bars.
#417 |
Re: 75 Dually build
You can either draw one up or try and build that. That sounds like a really good idea.
#418 |
Re: 75 Dually build
Got the frame and the 4 link arms painted. So after they had a chance to dry overnight I installed them today. I like the grey against the black. I also started on the Watts Link today. This was as far as I got. Hope to get more done tomorrow.
#419 |
Re: 75 Dually build
Are you mounting the bar to the axle or frame? For the watts?
#420 |
Re: 75 Dually build
The bar you see above gets mounted to the rear end in my setup.
#421 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 75 Dually build
Very nice work!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#422 |
Re: 75 Dually build
#423 |
Re: 75 Dually build
I had to take back my hydro boost because it was sticking and I had to use my foot to pull it back up. It would make the brakes drag really badly. The new one came in today, so off the old one came, and now it is replaced. I figured while I was under the hood I would replace the upper radiator hose too. The old one failed during our trip home from LST, so it got a trip to the trash can, and the new one is now in it's new home. It's the little things that can drive you up a wall... Now on to the Watts Link. Gotta get it done because we have a local show next weekend and I want this big girl buttoned back up so I can slam it on the ground. That just sounds wrong doesn't it...
#424 | |
Re: 75 Dually build
Did you buy an aftermarket hydroboost or did the truck come stock with one?
#425 |
Re: 75 Dually build
It is the OEM hydro boost. The truck came with one, but I did a vacuum booster at first and that was not going to stop this beast! So back to the OEM version...
Tags |
air bags, alcoas, chevy, dually, lowered |
