09-16-2015, 01:56 PM | #401 |
Re: 72 K30 Build
Thanks! Any reason you didnt go with the 40 gal burb tank?
09-17-2015, 09:39 AM | #402 |
Re: 72 K30 Build
My initial thoughts were to run the 40 gallon tank. But when we got into it I was concerned it would end up too close to the differential (we are 1.5” further back). It also looked like we’d have to set the rear crossmember even further back in the frame than this tank. It could have fit but this one gives us more room for the exhaust, a little trim room (frame rail ends) for the bed I don’t have yet and is still a big a** tank.
Here’s how this has turned out so far. Still need to flip the frame to finish mounting a few things like the spring hanger L-brackets, rear bump stops and rear crossmember (lower) but the tank is done for now. And if your wondering is that angle strong enough, I did? A gallon of gas should weigh between 5.8 to 6.5 lbs. depending on its temp etc. so 31 x 6.5 = 201.5 lbs . Our test to simulate real world conditions consisted of a fat 250 pounder jumping up and down on it. The results are in the pics below, never budged good to go!
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
09-21-2015, 10:27 AM | #403 |
Re: 72 K30 Build
We started off last week by drilling out the front crossmember and steering box brace to 7/16”. Also installed the front bump stops (no pic) but still need to weld up some holes to mount the donor brake line brackets.
And that leads to surprise, surprise more holes to fill. We won’t be doing them all (skipping frame alignment holes, etc.) but if it’s near a new drilled hole or very large (needing a plug) we’ll be filling it.
09-22-2015, 01:47 AM | #404 |
Re: 72 K30 Build
It's a pain in the A** to weld up them hole. I must have welded in about 40+ holes in my frame and had to buy a new roll of wire for my welder and a bottle fo argon C02.
09-22-2015, 08:26 AM | #405 |
Re: 72 K30 Build
Yep ditto on the PITA! Almost outta wire and shielding gas, double ditto!
We did some minor bracket repair that needed doing. A little crack and a worn area on the k-member also welded a shim to the steering box brace. Started back on the frame and CRAPO our welder (Eastwood 175) biffed it! Cooked the circuit board and a replacement cannot be had until the end of year at the soonest. Oh and of course it’s 3 months out of warranty. So guess who’s getting a new welder and it ain't coming from Eastwood!
09-22-2015, 12:41 PM | #406 |
Re: 72 K30 Build
Hey Brett looking good! I have a question about your gas tank. I see that the tank is hanging low. Did you do that so the fill neck would not be to high so not to hit the bed? I raised my tank up but will have to cut the fill neck down to fit under the bed floor.
Keep it up my friend, as I don't have time to work on mine with coaching football and all. but I do get time at work to check out your build and others!!!
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
09-22-2015, 03:21 PM | #407 |
Re: 72 K30 Build
I hope I did not bring you bad luck with your welder breaking down. that sucks. what are you going to get.
09-23-2015, 08:21 AM | #408 |
Re: 72 K30 Build
sucks that the welder died, but at least its time for an upgrade! what machines are you looking at?
09-23-2015, 11:02 AM | #409 | |||
Re: 72 K30 Build
Thought it would be wise to install the tank low so installing a new flatbed would not require a lot if any mods as I’ll probably drive it to the vendor and have the bed installed there (todays plan uno). This setup could be raised really easily by replacing the upper cross braces with some bar stock or angle and bolting them on top of the frame rails. Also we could spin the tank 180 and have the fill on the left losing the clearance notch at the back? Didn’t want any tank mods as we have the pull it off the shelf and install the part mentality going on so last thought is that if it’s really low once done we can still add a skid plate from a donor Blazer or Burban which is still on the table. Quote:
While we figured out the welder situation got onto installing a few more things. Can't believe this HF 1/2" drill is still going strong bought it to punch holes in wood studs years ago when we wired the house and garage. Was sure this frame project would kill it but there it is!
09-23-2015, 04:51 PM | #410 |
Re: 72 K30 Build
I got my dads mig welder after he passed in 1998. he bought it in 1981 Miller 200. I have had to have it serviced several time over the years. that's good to hear about the HF drill is still going strong. I bought a 4" HF grinder when I started my frame off and it died 4 week later. my Millwakee grinder is about 10 year old and still going strong.
09-28-2015, 10:32 AM | #411 |
Re: 72 K30 Build
Amazing your HF grinder made it that far, last time we tried one about 3 years ago it lasted about an hour!
Decided it’s time to remove the rest of the factory rivets that are holding the rails together. From our earlier mockup we found this mid crossmember (carrier bearing mount) could be a problem for a one piece (very loooong) rear drive line and would have to be relocated, flipped over, removed or perhaps partially replaced with the lower dropped part (w/o the taller side brackets) of a later version we happen to have left over from our 72 RV 157” chassis.
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 Last edited by 7dee2; 09-28-2015 at 10:53 AM. |
09-29-2015, 09:37 AM | #412 |
Re: 72 K30 Build
Here is some more info, we are still planning for a GVOD their customer service dept. said they advise the customer to shorten the driveline by 14”. We won’t know for sure until we drop the cash get it here, bolt it up and see what’s what. Plan is to deal with this during the final assembly stage. Here is a pic I borrowed of an installed unit in a 67-72 my guess is a K20.
09-30-2015, 08:58 AM | #413 |
Re: 72 K30 Build
Before we separate the frame rails I thought I would take a pic of the front all welded/plugged up and with the rear of the frame still to go, holy moly! Sorry my camera was having a hard time focusing with the flash off. I can report our new little Lincoln welder is doing a great job. Making some 1” plugs..
10-05-2015, 11:19 AM | #414 |
Re: 72 K30 Build
I’ve wanted to add some 3/16” bar stock where the trans/tc mounts. Thinking this will help to distribute some weight a little along the lower frame flange when it’s all back together. Frame rails are now separated should make some of our work easier.
10-06-2015, 11:49 AM | #415 |
Re: 72 K30 Build
Here are some progress shots.
10-06-2015, 10:12 PM | #416 |
Re: 72 K30 Build
Awesome build. This buld thread is going to make my swap much easier Thanks !!!!
I am going to be doing the exact same swap. I have a 1968 longhorn frame and a 1981ish 1 ton militay frame to use as a doner. I am planning on using a 4L80 for overdrive because the gearvendors in my suburban has given me to many issues. Also parts availablity and cost is difficult to outrageous with the gearvendors in Canada.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
10-07-2015, 11:37 AM | #417 |
Re: 72 K30 Build
Thanks 72Mario that's part of the reason I decided to post it all, the good, the bad and the ugly! Sorry to hear your GVOD isn't working out the way you had hoped, at least they're a lot closer to us so if I have to I could pay them a visit.
Here's a link of the Roadkill guys installing one and discussing the issues they can have. https://www.youtube.com/watch?v=SywsCGnoXOU A little more progress, also gives me a chance to fuss over some earlier work as well as remove the grind marks.
10-15-2015, 10:02 AM | #418 |
Re: 72 K30 Build
We confiscated the grandkids sandbox last week to setup camp sand blast, o boy this should be lots of fun! My neighbors love me!
We usually farm out the chassis but since this one is in pieces decided to do it ourselves.
10-15-2015, 10:39 AM | #419 |
Re: 72 K30 Build
your yard is looking like mine. sand blaster set up I even have the same HD bucket and funnel to recycle the blasting media. looking good.
10-18-2015, 01:16 PM | #420 |
Re: 72 K30 Build
you are doing great work! subbed to see the rest of your build.
I have a GV unit in my 93. still running a 4:10 rear with 4L80. drops rpm by 500 but been so long since it ran, can't remember what the freeway rpm's were.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
10-19-2015, 10:46 AM | #421 |
Re: 72 K30 Build
Thanks you guys!
deejaaa1 a diesel and OD x2 for you, I can only imagine what the freeway rpm would be with a tall tire & 4.10 my guess is pretty darn low! So DWilbur you’re saying you’re a neighborhood favorite also LOL! Back at it day 2 and the pile of done parts is starting to grow. Clean parts we got from D&L Truck will go really fast, doing them all so they will look the same as the others when painted.
10-19-2015, 04:59 PM | #422 |
6>8 Plugless........
Re: 72 K30 Build
Great work on your frame! It's going to look awesome!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
10-20-2015, 10:15 AM | #423 |
Re: 72 K30 Build
Thanks DW!
OK day 3, one rail and all of the cross members are done. The best part of this is the manually sifting and reloading of the hopper a lot, good times!
10-21-2015, 11:47 AM | #424 |
Re: 72 K30 Build
Day 4, 5 & 6-ish still just living the dream! Second rail completed and the done parts pile is looking pretty good. Our bucket seat frames need a little attention but not too bad really.
10-21-2015, 02:25 PM | #425 |
Re: 72 K30 Build
That all looks really nice!
Tags |
72chevy, dually, flatbed, k30, motorhome |
