Old 01-02-2019, 11:47 PM   #401
whitels1
whitels1's Avatar
Re: Daddyjeep Hauler - 85 K30 crew cab short bed
Do work brother! Looking good!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 01-03-2019, 09:11 AM   #402
daddyjeep
daddyjeep's Avatar
Originally Posted by MTCK View Post
Nice work. Glad to see you are operating with the requisite Safety Bud Light.
Hydration is important. It is a Blue Light though.
Thanks for the comments guys. It is certainly good to be back working on this again. I will still be bouncing around between projects. I finally got the Jeep out on a shake down run and have a few things to address there.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 01-11-2019, 02:16 PM   #403
daddyjeep
daddyjeep's Avatar
Well guys, it looks like i may be throwing in the towel. I think I am going to have to sell the truck. I have too much going on and I can sell this for more than enough to pick up a mid 00's truck that I can just drive. This will allow me to sell my DD Cobalt as well since the truck will get decent mileage. This is certainly a tough decision, but it is the right decision. This truck is and always will be my dream truck. Maybe some day I can start this whole thing over again. Any takers?
04 1500 crew cab
Old 01-11-2019, 05:37 PM   #404
joe231
joe231's Avatar
You should post it here
https://m.facebook.com/groups/1902842813275906
CHEVY ONLY
Old 01-11-2019, 05:58 PM   #405
daddyjeep
daddyjeep's Avatar
I am a member there.... I was planning on it.
04 1500 crew cab
Old 01-14-2019, 02:12 PM   #406
daddyjeep
daddyjeep's Avatar
More progress on the true short bed conversion. I finally cut the back half off to remove that 6" of material.
It is at least all tacked together now. A few thousand more tacks and we will be done.
04 1500 crew cab
Old 01-14-2019, 04:00 PM   #407
moregrip
moregrip's Avatar
great progress on the bed man!
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 01-17-2019, 02:42 PM   #408
daddyjeep
daddyjeep's Avatar
More welding...
More grinding...
I gotta tell you, a 40 grit flap disk knocks down weld in a hurry. Why have I not been using this for years?
I got the new panel tied into the old on the drivers' side at least.
Ok, for those that may be following that have been here before. What do you guys do here? When that 6" comes out the taper in the rear no longer lines up. I was thinking about just taking a pie cut out of the new panel and bending it up. That, or sectioning a piece and moving it all up to match. Thoughts???
04 1500 crew cab
Old 01-18-2019, 09:18 AM   #409
daddyjeep
daddyjeep's Avatar
Last night I cut out the rusty spots and filled in the spots with good metal and made fillers for all of the dually fender bolt holes. That took a little time filing them to size.
All cleaned up. I spent some time with the hammer and dolly. I still have a ways to go before it is ready for filler, but the metal is moving to my will.
04 1500 crew cab
Old 01-18-2019, 12:17 PM   #410
whitels1
whitels1's Avatar
Dang bruh, Get after it! Nice work dude, curious to see how you handle the misalignment in the back.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 02-11-2019, 06:31 AM   #411
noezpu
Good Morning,
What are the chances you would sell and ship those fenders to Maine? I have been looking for a set.
noezpu is offline   Reply With Quote
Old 02-11-2019, 02:02 PM   #412
daddyjeep
daddyjeep's Avatar
Well look at that... a true crew cab short bed finally. The bottom behind the wheel well still needs addressed, but I am going to finish up the bulk of the welding on the other side then put it up on the lift top clean up the lower stuff. No sense laying on the floor to weld since I have a lift.
neozpu, I will send you a PM.
04 1500 crew cab
Old 02-11-2019, 04:55 PM   #413
87max
87max's Avatar
It's got to be a good feeling, nice job!
87max is offline   Reply With Quote
Old 02-15-2019, 10:46 AM   #414
daddyjeep
daddyjeep's Avatar
More welding... more grinding. I need to spend some more time with the hammers and dollies, but we are getting there. I will get it up on the lift tomorrow and get the lower parts welded up.
04 1500 crew cab
Old 02-15-2019, 12:57 PM   #415
whitels1
whitels1's Avatar
Much respect with your skills, it's coming together nicely!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 02-15-2019, 01:51 PM   #416
daddyjeep
daddyjeep's Avatar
Thanks. I'm still learning and still having fun.
04 1500 crew cab
Old 02-17-2019, 01:39 PM   #417
COS399
COS399's Avatar
That's the two most important things. That hood makes it mean looking.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 02-18-2019, 10:45 AM   #418
daddyjeep
daddyjeep's Avatar
I got the truck up on the lift over the weekend so I could get all of the welding done on the lower part of the bed.
First order of business was figuring out the mismatch in the rear.
It turns out that there really wasn't a problem with the new panel after all. For some reason the original bed side had a piece cut out on both sides. I am not sure the reasoning behind this, but both sides were the same.
Then I had to clean up the cuts inside the bed. The 6" that I removed from the rear of the bed fell in a place where I would have to address the recess in the panel. I probably could have made some creative cuts so I could work around the recesses, but I chose to just cut them out and weld in a patch. This might have been a bit more welding and grinding. but it wasn't bad. The other side has holes where 5th wheel wiring once was so I would have had to patch that anyway. I will get some more pics of that side as I get it done.
04 1500 crew cab
Old 08-19-2019, 11:03 AM   #419
daddyjeep
daddyjeep's Avatar
Well, six months have passed and not a lot has happened to the old truck. It has been for sale and still is for some reason. Lots of tire kickers and still talk to someone else that is interested every week. No one has brought cash so i figured that I might as well get back to work on it. The Jeep has been running good so I have been just enjoying that instead of working on it. I had a little bit of bondo left in a can so I mixed it up and slathered it onto a bed side. There are still a couple high spots that will need some hammering and I will have to cut out a piece at the very back to fix the body line above the tail light. It is dented up a bit and will be easier to replace a piece than to hammer it back into shape. We will see how far this goes before someone brings me cash. It won't break my heart a whole lot if no one shows up. I might even send them away if they do.
04 1500 crew cab
Old 08-22-2019, 11:27 AM   #420
daddyjeep
daddyjeep's Avatar
Since I am leaning more and more towards not letting someone else buy my truck I thought it was time to update my rendering and maybe consider another color option. The first rendering was one that I found on the interwebs that I reworked to match my truck somewhat. I was never really happy with it and I have been doing some renderings of other vehicles and really just wanted a better one. This rendering was 100% done from scratch using a pic of my truck. I also added the ladder rack/cap that I am planning on building. It will have a steel structure and canvas covering.
So, here it is. Original colors with some flames added. My vehicles have had flames for almost 30 years. My first Squarebody had them back in '91... why stop now.
And a new color option. My first Squarebody was a very dark green and my Jeep that I will be towing is OD green.
04 1500 crew cab
Old 08-22-2019, 11:49 AM   #421
MTCK
MTCK's Avatar
Keep it! I like both the color combos.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 08-26-2019, 01:06 PM   #422
daddyjeep
daddyjeep's Avatar
Keep it!
All ads have been taken down.
04 1500 crew cab
Old 08-28-2019, 09:01 AM   #423
daddyjeep
daddyjeep's Avatar
Well, I decided to just cut out that wrinkly spot on the bed side and weld in some better metal. I did some hammer and dolly work along the edge and on the bottom back corners. It is shaping up pretty good. A bit more welding to do and back to body work.
Wrinkly
Cut out. I wire brushed and painted everything I could reach while I had the hole open.
New steel welded in and ground.
04 1500 crew cab
Old 08-29-2019, 12:12 PM   #424
daddyjeep
daddyjeep's Avatar
I finished welding and grinding the last piece on the bedside. I took my time and did some hammer and dolly work as I was welding so I got it a lot smoother than before. This will take very little filler to get smooth. I'm still learning.
And a coat of bondo. I won't get back to sanding it for a few days.
04 1500 crew cab
Old 09-05-2019, 09:29 AM   #425
daddyjeep
daddyjeep's Avatar
Another couple hours of sanding in the books. My shoulders feel it. Slowly but surely it is taking shape.
I had to rearrange the shop a little. It is time to move my kids Jeep to the front. He has his permit now so in a few months he will need his Jeep.
04 1500 crew cab
