#401 |
Post Whore
![]() Join Date: Aug 2014
Re: A '54 named Busty
but I pressed on and went to the other side, here I did two things that made a world of difference:
1. I cleaned multiple spots to put my ground clamp on, maybe 3 or 4 spots on this angle iron, where I only had one on the other side, this allowed me to move the ground as close to where I was welding as possible 2. I twisted the other knob (despite of what the recommendation chart told me) so in other words I increased my wire speed, just by a notch as your spark box may differ, and oh lordy now we was cooking with propane, and it sounded like bacon frying on steroids LESSON LEARNED:yes the close ups are the good ones, ha ha, hey I'm learning and I am honestly proud(ish) of those welds Last edited by Gregski; 05-03-2020 at 09:51 AM. |
#402 |
Post Whore
I'm not sure I am going to fill in all the gaps but I did the ones closest to the tailgate (one on each side) using scrap metal
and keep in mind all of this still needs to be ground down and sanded flat, I hope to put a nice rounded edge all around that angle iron |
#403 |
![]() Join Date: Sep 2017
Bed looks good. Good luck on welding through the angle.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
#404 |
Post Whore
#405 |
Post Whore
I was hoping to finish the exhaust today but after a little touch up welding on the angle iron bed sides I was completely out of welding gas, so after hours of welding flush the spot welds and making the other beads look decent here's what I did instead
#406 |
Post Whore
with the bed sides masked off I shot some primer on the angle iron and on the bed sides below it
Fun Fact: Did you know that this RUST-OlEUM primer is the exact same formula as the automotive one you buy at AutoZone and other car parts places, yet costs half as much? |
#407 |
Post Whore
so sprayed the bed side rails with some RUST-OLEUM Satin black today, honestly as you will see later when I paint other bits that there's nothing Satin about it, it comes out Semi Gloss, so rather disappointing, but on here I don't care
#408 |
Post Whore
then I made the other sides of the grille and headlight bits black, not happy at all with this so called "Satin" paint from RUST-OLEUM it is more like their Semi-Gloss than satin, that's for sure, luckily a lot of this stuff won't be seen so it's just there for protection and I have an idea for the headlight bezels and grill pieces
#409 | |
Post Whore
and to be fair to the walnut shell and the blue moon rocks, I only ran this for a fraction of the time so like 3 or 4 hours |
#410 |
Gregski, that "satin" coating looks just fine to me. As for the new tumbler media, nice try!!! Eventually we will find something that makes those overprised gizmos actually work. As much as I love the results from the hillbilly tumbler, it's horribly loud. I'm looking forward to seeing what you come up with next!
Stephan |
#411 | |
Post Whore
#412 |
Hey, isn't this paint for your other truck? That's what it says anyway.
#413 |
#414 | |
Hey Stephan, maybe you can figure out a way to mount that paint can inside the housing for the shaker that didn't work very well. Stuff some batt insulation in there around the can and let 'er rip. Should cut down on the noise somewhat. |
#415 |
Post Whore
#416 |
Post Whore
more painting, but i finally think I made everything black that I intended on making black on the front clip
#417 |
Post Whore
so as I move through these projects I go from wanting to do mechanical work and then growing tired of it and wanting to do something else like fab and weld, so I do that for a while and then I want to paint and then I get sick of that, as I am at the moment so I look forward to doing something else, well its sorta back to fabricating (and I use that term loosely) and welding the dual exhaust
I am quite please with the way the passenger side turned out granted that i made it all out of remnants I had lying around (looking at your Corona) no pie cuts here - ha ha started out by using zip ties as a third hand |
#418 |
Post Whore
i am a bit concerned about the close proximity to the fuel tank may need to cobable some heat shields
#419 |
Post Whore
but I'm pleased with the result and the rear exit
#420 |
#421 |
#422 |
Post Whore
#423 |
Post Whore
So I decided to put a self imposed Deadline on myself to have Busty ronnin' and drivin' by my Birthday - May 25th! keep your fingers crossed
Left Ta Do: (as of Monday May 11th, 2020 Anno Domini)
#424 |
![]() Join Date: Mar 2011
Greg, good luck with the deadline, hope it all works out, I'm rooting for you...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#425 |
Post Whore
Thanks Jim, every morning I have some coffee and turn more pages of you Roadster build, it's superb craftsmanship.
