09-22-2023, 08:38 PM | #4226 |
Active Member
Re: What did you do to your truck today.The 3rd chapter
09-22-2023, 09:09 PM | #4227 |
Got my studs cut down so I could finish putting the last pieces on the Schott wheels.
"If it ain't broken, fix it 'till it is!" |
09-23-2023, 08:40 PM | #4228 |
Bench seat out.
DynaMat down and inside door skins.
Sam 1972 C10 LWB 2020 Z71 Tahoe |
09-24-2023, 01:22 PM | #4229 | |
68 C10 Longbed
Attachment 2302096[ATTACH][/ATTACH]
Here you go another tow hook pic on the 68: |
09-24-2023, 04:45 PM | #4230 |
In the last week:
- replaced dog dish cap steel tires with Rallys - replaced front HL bulbs with Octane Bulbs - Added a Headliner - Maintenance, sanded and re-stained wood in bed. Too much work to not maintain. In next few weeks: - Tilt, 1.5 shorter, going from 17" to 15" steering wheel - Front disc brake conversion - window tint |
09-24-2023, 07:27 PM | #4231 | |
Too many guys get repainted and don't tell the shop about the design year trim feature -- contrasting color nose -- and just get the face body color, like a '67.
09-26-2023, 01:57 AM | #4232 |
I had a strong Gas Fume gripe inside my '68 C/10 Stepside.
Tonight, I changed out the rubber gasket and steel lockring on the In-Cab Gas Tank Fuel Sender, and also R & R'ed the 10.5'' - 5/16'' ID fuel hose under the cab, that goes from the Sender output to the steel fuel line. New hose clamps too. Hoping that gets rid of the gas fumes in the cab. It's the end of the month and time to hammer the accumulated 1000 VIP gas points from a supermarket chain. Every 1000 points equals a Dollar off the pump price at Kroger and Shell stations. [Circle K dropped out of the VIP program last month.] So I'll fill the tank and see if I still have a fume leak somewhere.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 09-26-2023 at 08:24 PM. |
09-26-2023, 02:59 AM | #4233 |
New tires!
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
09-26-2023, 03:35 PM | #4234 |
I mounted new tires as well. Plus I powder coated my center caps and installed new mirros to the end of the caps. Now to clean the truck
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
09-26-2023, 08:17 PM | #4235 |
Took it out today on the first annual Goodguys Texas Hot Rod Week tour… -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold Last edited by weq92f; 09-26-2023 at 10:13 PM. |
09-26-2023, 10:11 PM | #4236 |
Picked up the bench seat today.
Thanks to forum member t korinek for the houndstooth seat cover. Wish I had more room.
09-26-2023, 10:21 PM | #4237 |
Active Member
Finally got rusted out cab done, and first paint job ever, but with this site and YouTube went for it. And saved for new rebuilt instead
09-26-2023, 10:30 PM | #4238 |
Nice work.
Flipped your photos.
09-26-2023, 10:44 PM | #4239 |
Active Member
Thanks for the flip
09-30-2023, 06:04 PM | #4240 |
Finished installing a five speed manual transmission. Still have two shifters.
09-30-2023, 09:21 PM | #4241 | |
Did Rocky Raccoon always have a Black/Charcoal interior, or is that a mod? Mine is the same 516 Orange, with [once-upon-a-time] Silver Fawn contrasts. I've leaned toward Saddle as things gradually get replaced. Saddle dash pad cover, and Saddle Seat. Matches the Light Walnut stain on my plywood door panels. When the OE Fawn sunshades wore out, I replaced them with Light Blue ones, a union buddy gave me, off his '72 C/20. The idea was to trade out the Blue shades from the Stepside for the Black ones in the Jimmy [which got repainted Blue]. However, I could never get them loose. Also Blazers have a unique sunshade, different from production trucks. So that never flew.
09-30-2023, 09:33 PM | #4242 |
I'm working on rebuilding a floor shift steering column right now. Waiting on parts. Two owners back told me he painted the interior black. There are some spots that he missed, and it appears that the entire interior metal, including the dash and steering column, was painted a cream color. I am confused by that because your dash is orange. I don't know what paint scheme would have cream colored paint.
09-30-2023, 10:54 PM | #4243 |
Sure a lot of REAL nice trucks, good job.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-01-2023, 01:50 AM | #4244 | |
In '67 they just shot everything inside Fawn. Might have been running low by the 1968 model year. Is there any trace of Orange under the Cream? My whole cab interior was Orange. Orange Dash, Cab inside, Doors, Glove Box, Ceiling... Above the dash, it was Charcoal, I think. I've since shot it with Flat Black for better anti-glare. All the Fawn stuff was bolted on. Steering Wheel and Column, Sunvisors, lizard skin vinyl Seat, Seatbelts, Door Panels and Dash Pad.
10-01-2023, 01:55 AM | #4245 | |
10-01-2023, 02:16 AM | #4246 | |
I am pretty sure my rig was a Fleet Order. Totally Standard [base] Trim level. Was yours a fancier trim level?
10-01-2023, 02:20 AM | #4247 |
Mine was definitely a base model all around, other than having a powerglide transmission.
10-01-2023, 04:42 PM | #4248 | |
10-02-2023, 01:04 PM | #4249 |
Went back to stock KYB Gas-adjusts from the CPP lowering shocks that were put on for the drop. Rides like a dream now!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
10-02-2023, 02:47 PM | #4250 |
Got my 327 block back from the machine shop and now the actual process of putting it together will begin to start the winter project of pulling the 350 and 4 speed out of the truck for this 327 and a tkx 5 speed for more fun next spring.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
