Old 07-09-2016, 03:20 PM   #4301
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and a peak underneath
Gregski is online now   Reply With Quote
Old 07-09-2016, 03:23 PM   #4302
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ok so first we need to transfer the coil from the OEM dizzy to the DUI CrossFire
Old 07-09-2016, 03:26 PM   #4303
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
worth mentioning that I noticed the stock OEM distributor cap had the center hole bevled out a bit, seemed like an after the fact modification, where as the DUI CrossFire cap did not - I decided to leave the new one be, and try it the way it is
Old 07-09-2016, 03:27 PM   #4304
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and just to be thorough and since the new cap came with a new rotor, we decided to swap those as well
white - old
blue - new
Old 07-09-2016, 03:43 PM   #4305
Titomars
Titomars's Avatar
Re: Restoring Rusty
white - old
blue - new
Wait, hold up a sec. transferring coils and rotors is not normal of Davis dizzies. I have purchased 5 of them and they all came drop in. DUI's have their own coils which are not standard HEI coils. Their caps and rotors are brass contacts and matching colors too. Maybe I missed something.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 07-09-2016, 04:47 PM   #4306
MikeB
MikeB's Avatar
Re: Restoring Rusty
man I aint too impressed with this there CrossFire distributor cap, seems like all they done did was soldered some wire inside the cap to re route the contact points (except #1 and #4) and covered it up with black goop, ha ha
Stay away from gimmicks (spelled k-l-u-d-g-e in this case). Some future owner or mechanic will be pulling their hair out working with what they think is a stock cap.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 07-09-2016, 05:07 PM   #4307
RDrancher
RDrancher's Avatar
Re: Restoring Rusty
At least it's shiny black goop!
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 07-09-2016, 05:08 PM   #4308
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Whacha talkin' about Willis?
Old 07-09-2016, 05:11 PM   #4309
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Ha ha so true Mike, I volunteered at a buddies motorcycle shop for a number of years and we would git crazy stuff in every once in a while, this was during the Chopper craze and we once got a "custom" bike built by the owner, and he used a red colored wire for every single circuit on his bike, brought it to us cause the brake lights didn't work or something like that, my buddy yanked all that stuff out and we done it right
one day I asked our main mechanic what was his favorite bike to work on, and he looked me straight in the face and said "STOCK, anything stock, cause if I don't know it I can look it up in the book"
so right you is Mike, right you is
Old 07-09-2016, 06:35 PM   #4310
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
got some new MSD(ish) spark plug wires
SF Street Fire (so gotta be good, ha ha) An MSD Brand (what in the world does that mean)
USA MADE (not made in the USA mind you, but USA Made, I'm sure there's a difference)
spiral wound, silicone sleeve, all the right words
Old 07-09-2016, 06:41 PM   #4311
Titomars
Titomars's Avatar
Re: Restoring Rusty
my mistake I thought you were installing a DUI dizzy not just a cap and rotor. I'll shut up and just lurk
Old 07-09-2016, 06:42 PM   #4312
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
So what was in the box Homes?
a bunch of wires and a bunch of rubber booties and a crimper tool that you use in your vice (now that's awesome, and the big reason I chose these)
Old 07-09-2016, 06:48 PM   #4313
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ok lets get this stuff sorted and try to make some sense out of it all
it appears there is two kinds of rubber booties, I recon the slim ones be for an HEI style dizzy and the fatter ones seem to fit my old points distributor
not sure if the silver tips go with the skinny boots and the gold with the fat ones I just laid them out that way, though one fat bootie wire did have a gold tip already installed in it
the bottom boot is a bit different then the rest and is for the Coil
Old 07-09-2016, 06:52 PM   #4314
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I did not see the wire sizes on the box so I laid them out in matching pairs and measured them for us
2 x 55"
2 x 48"
2 x 41"
2 x 31"
1 x coil wire
Old 07-09-2016, 06:53 PM   #4315
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
alright so we put our Big Boy Pants on and gonna build us our first set of custom spark plug wires, here we go...
Old 07-09-2016, 06:56 PM   #4316
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
after we measure the right length (ie 26 1/2 inches for #1 and #2 wires) we cut the wire to length and strip about 1/2 inch off (hence the extra 1/2 in the total length) using their super duper crimping tool which has a side for stripping wire, I just used my box cutter knife
Old 07-09-2016, 06:59 PM   #4317
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
we used Vaseline to slip the boot on about 5" back before crimping the end on
Old 07-09-2016, 07:02 PM   #4318
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
It helps if you use needle nose pliers to bend the metal clip ends in a little bit to help the crimper before you shove it in the vice
Old 07-09-2016, 07:03 PM   #4319
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
there, not bad for the first one
Old 07-09-2016, 07:05 PM   #4320
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and one down and seven to go...
Old 07-09-2016, 07:23 PM   #4321
RDrancher
RDrancher's Avatar
Re: Restoring Rusty
Looks good! I remember the first set I did...more than a couple decades ago. No cool tools included back then, and I butchered a couple wires up pretty good. Those wires got a little short before I was done. lol
Old 07-09-2016, 07:25 PM   #4322
MikeB
MikeB's Avatar
Re: Restoring Rusty
Used those last year on my truck motor. Just as nice as the higher priced spread, IMO. I bought them because it was supposed to be a "budget build". But just bought some upgraded valve train parts, and am looking at replacing my $150 worth of cast iron manifolds with headers. With my luck the plug wires won't work with headers. But, hey, this thread is your rant.
That's pretty high tech. I use dielectric grease.
Mike
Old 07-09-2016, 08:23 PM   #4323
enaberif
Re: Restoring Rusty
That black "goop" is just non-conducting electrical paste. You can buy that stuff in jars/cans form most automotive stores.
I personally would veer away from those types of caps.. But hey whatever works for you.
enaberif is offline   Reply With Quote
Old 07-10-2016, 11:29 AM   #4324
rusty76
rusty76's Avatar
Re: Restoring Rusty
Looking good.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 07-10-2016, 11:39 AM   #4325
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I hear you brother, I was quite surprised my first few turned out as good as they did, and that's why two (#2 & #4) are a bit longer cause I built in some length in them just in case I messed up, ha ha
well here's one half done
