#4376 |
Re: What did you do with your truck today, Part 3
As you may recall, I had some oil pressure sender issues with the Dolphin gauge in my panel truck, and Dolphin advised me to remove sealant from the threads so the sender could get a good ground. Nonetheless, just to reassure myself, today I verified my oil pressure with a manual tester: 28 lbs at idle, 50 lbs at 2500 rpm. So everything is just right.
1951 Chevy Panel Truck |
#4377 | |
![]() Join Date: Mar 2011
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#4378 |
ive had the same concerns. so I mounted an old style mechanical pressure gauge on the block just above the water pump. works great.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
#4379 |
Good idea. There's an unused port right there. Do you have a picture?
#4380 |
I still haven't figured out how to post pictures from my phone. sorry, im just old.
#4381 |
I'm old school; I take the picture, save it to my computer and then pull up the picture from an existing file to this forum.
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
#4382 |
Finally finished polishing the lower thermostat housing. This little thing kicked my butt. I'm going to estimate it at 20 hours. It took twice as long as my bellhousing. It looks nicer than the photo. I don't know why polished parts photograph so poorly up close. I'm calling it a win.
#4383 |
All of those little details work your tail feathers or fingers off.
I did the move all my stuff in the outer yard and mow and then put it all back in different places thing today. For those who drive up US 97 between Goldendale and Toppenish you will probably notice that the furniture has been moved around and you can maybe see more sailboat butt sticking out. There was a method to my madness as I drug the tear drop trailer frame that my frame for my 48 sits on out so I can get started on it as soon as I get the pop back though the carb thing fixed on the dualie.
#4384 |
Added a couple of chrome turn-down tips on my tailpipes.
#4385 | |
#4386 |
Finished smoothing the casting to my water pump. AN fittings done. Needs a final clean and ready for paint.
#4387 |
Ladies and gentlemen: this thread topic and other "stickies" can now be found under the heading "FAQ Thread Index"
#4388 |
My AN fittings came for my thermostat housing and I had to clearance part of the housing to get it in. And a little bit more polishing. I spent most of the day trying to make space for a new 12" X 36" lathe I ordered.
#4389 |
Swapped out the 64 2bbl carb and intake. For a "vintage" 3CBS edelbrock and 4bbl carb.
#4390 |
I final mounted my rear brake disk on the hub. They only have a torque setting of 155 inch/pounds with red loctite. I chased all the threads on the bolts and holes first to avoid the rundown screwing my torque settings up. The tape is so I don't lose my place and forget any. It is not going to be fun getting the safety wire on the bolts down around the e-brake drum. I guess I have never had any fun with safety wire.
#4391 |
Looks pretty whizzie.
#4392 |
I put the safety wire on my rear brake disks. I put the tape on so I didn't put one on backwards and have to do it over. Not that I have ever done that, as far as anyone knows. They took 20 to 30 minutes a piece. I think I had as much fun as you can have with safety wire.
#4393 |
![]() Join Date: Oct 2016
Well, I lost 3rd gear in the 700R4, the outfit I bought it from won't stand behind the 2 year unlimited mileage warranty, XP Performance out of Spokane, WA.
So Monday after I get off work, I'll find out how much this is going to cost me... oh well what's another $1500 down the toilet... I'm now stepping down of my soap box, my rant is done! |
#4394 | |
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
#4395 |
While installing my exhaust turndowns I noticed that my frame had been touching the rear shock absorbers when driving. The problem is my shocks are heavy-duty, over 2-1/2" diameter. So today I cut the dust covers off them, now giving them almost an inch of clearance.
#4396 |
Sweet looking motor.
#4397 | |
That is the name on the invoice they sent me, after I read your response I did some research and found them operating under this name and the same address and phone number. Hot Rod Company 4023 S Conklin Rd Greenacres, WA 99016 https://www.ebay.com/usr/hrc2002 Last edited by idbeast; 04-25-2020 at 09:54 PM. |
#4398 | |
https://www.bbb.org/us/wa/greenacres...296-1000008792 Their reputation is slightly tarnished, but it looks like they know how to play the game by resolving the issues that get exposed. The squeaky wheel gets the grease.
#4399 |
![]() Join Date: Oct 2011
Removed one front spring and started the install of the Western Chassis drop spring.
2020 has not been off to a good start for getting truck projects done.
#4400 | |
