08-03-2016, 04:54 PM | #4426 |
Re: Restoring Rusty
I have the non-gas Flux core model, some thing I have done:
- Converted it over to DC with some big caps and a bridge rectifier. (Tutorials for this are everywhere) - Upgraded the wire to Hobart .030 - I do have an auto darkening helmet I'm getting better at not burning holes in stuff, the thinner wire might help. It still splatters a lot. Its only power settings are high/low. I'm usually running it on high. |
08-03-2016, 04:59 PM | #4427 |
Re: Restoring Rusty
Dupe post. Can't find delete!
08-03-2016, 05:14 PM | #4428 | |
Moderator
Re: Restoring Rusty
I have a 2 year old Lincoln Viking and a new Jackson BH3. They are both noticeably heavier than my old fiber helmet and you can get flashed if you don't set them right. They are also easier to use with the MIG for sheet metal work.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
08-03-2016, 06:14 PM | #4429 | |
Post Whore
Re: Restoring Rusty
I think there is some kind of spray you can get (look into it) to spray your piece before you weld it to make sure the splatter don't stick, I had a lot of splatter with my Harbor Freight Flux Core machine, little bits a bit bigger than pieces of crushed pepper all over the place, they would come off easy with a wire wheel or a grinder but still it meant an extra step |
08-03-2016, 06:17 PM | #4430 |
Post Whore
Re: Restoring Rusty
so with the Air Fuel Ratio adjusted to be way better way leaner into the high 13s range rather than the 10.6 range I started with, the truck is running great, idles around 550 RPM nice little rumble, not perfect yet, but better
I drove it in to work today, ran great, even the fuel gauge decided to work |
08-03-2016, 08:13 PM | #4431 |
Re: Restoring Rusty
I love how clean the new gauges look...mine aren't bad but not nearly as shiny. I am having some issues with high idle and have been told to get a wideband to get it figured out....I just can't afford to drop the cash...there has got to be a better (cheaper) way!
Flux core will always splatter. |
08-03-2016, 08:47 PM | #4432 | ||
Post Whore
Re: Restoring Rusty
INNOVATE DLG1 Wideband O2 Oxygen Sensor Tuning Diagnostics Logging Air Fuel Ratio etc starting at thread #42 (also not in the thread but my initial timing is set to 10°) True |
08-03-2016, 08:52 PM | #4433 |
Re: Restoring Rusty
Mine is a TBI, so there isn't much I can tune without changing out chips (as far as I know). I really have been thinking about changing over to a carb...a computer seemed like a great idea now I am beginning to hate it...
08-03-2016, 10:18 PM | #4434 | |
Post Whore
Re: Restoring Rusty
so if it is wigging out, it only does what it is being told, what I mean by that computer has it's field soldiers, the sensors, and they tell it what to do, the first thing I would do is replace your Oxygen sensor(s) with quality OEM spec ones what ever the engine you have came out of or is, then reset the error codes if any and drive around the next thing to replace is the MAF Mass Air Flow meter sensor thingie, check the error codes and drive around the next one after that could be the throttle position sensor |
08-03-2016, 10:31 PM | #4435 |
Re: Restoring Rusty
High idle on a TBI? Check the base gasket as well as for slop in the throttle.
08-03-2016, 11:16 PM | #4436 |
Re: Restoring Rusty
87 4wd with a 350 TBI and 700R4 tranny. The motor is not the original according to the guy I bought it from but he didn't say what it came out of, how many miles on it, or anything else that might have been useful. I was too blinded by the beauty of the truck to think at the time....let's call it truck goggles.
The O2 sensor is about a year old and I believe it is a house brand from somewhere. I have been trying to stick with AC Delco on everything, but that one I slipped up on. That will probably be remedied soon. The TPS, idle air control valve, and map sensor are all new (past year to six months) and AC Delco. Not getting any vacuum leaks at the throttle body base. The EGR was leaking on me but has been replaced....but I went with an off brand locally instead of waiting on an AC Delco to be delivered. I do have a vacuum leak toward the back of the intake manifold, so I am going to redo the intake gaskets in the next couple of weeks. No slop in the bushings either that I can tell. .....So the love affair with the truck goes on but the engine and I are barely on speaking terms! |
08-04-2016, 01:20 AM | #4437 | |
Post Whore
Re: Restoring Rusty
08-04-2016, 09:30 AM | #4438 |
Re: Restoring Rusty
Way to rub it in man! ha ha
Now....what have you done on Rusty lately....don't leave us hanging here! |
08-04-2016, 03:59 PM | #4439 |
Post Whore
Re: Restoring Rusty
Just a Truck doin' Truck Things!
08-04-2016, 05:34 PM | #4440 | |
Moderator
Re: Restoring Rusty
If you can find out what CAM, heads, and pistons you have you can probably find a tuned EEPROM image for that setup. You want to keep the TBI setup or move to MPFI if you can. Carbs are easier but don't extract the power that a properly setup EFI system can. Stock 1987 the L05 TBI 350 had 35 HP and 25 ft-lb on the Stock Carbureted 1986 LS9 350. The 1987 L03 TBI 305 had 10HP and 25ft-lb on the Carbureted 1986 LE9 305. The TBI system did this with better fuel mileage and without blowing out huge amounts of garbage from the tailpipe. USB ALDL interface cables are not expensive... $55 at most and you can build your own for less. Used enterprise class XP laptops are right around $100. WinALDL and TunerProRT are not difficult to use and are either free or donationware. You start running into real money when you get an emulator like the Ostrich and start building your own custom programs. http://support.moates.net/gm-86-95-obd1-guide-read-me/
08-04-2016, 10:17 PM | #4441 |
Re: Restoring Rusty
Boy you lost me on those words^^^^. lol
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
08-05-2016, 04:03 AM | #4442 |
Moderator
Re: Restoring Rusty
Sorry. Been hacking embedded hardware for over 40 years. It's like Tinker Toys and Legos now.
08-05-2016, 11:51 AM | #4443 |
Post Whore
Re: Restoring Rusty
08-05-2016, 02:10 PM | #4444 |
Moderator
Re: Restoring Rusty
I've been playing with or hacking on electronics (learning how they work and why and then building stuff with them) since the mid to late 1970's. Somehow hacking has morphed into vandalism and other criminal acts perpetrated over networked systems. I was not breaking into the Pentagon on ARPANET at 10 years of age.
Electronics were very embryonic in comparison to what we have now... I was playing with TTL and Transistor circuits among other things. It was closer to 37 or 38 years ago that I got my grubby paws on anything marginally resembling a modern computer. What we would call "real" computer hardware with a keyboard and tiny CRT was what I could get access to after hours and some weekends, if I was a good kid, at my fathers' place of work. He was a Chemical Engineer in ceramics and industrial coatings. His ceramics and coatings were used for discrete through hole and early surface mount components along with the metallized inks he was working on for making early high density integrated circuits... What they were calling high density in 1978 through the 80's is laughable now but it was really cool stuff then. Motor and servo controls fascinated me at that time. I had access to early multi-pen plotters, both working and horribly failed. They were controlled using GPIB from an HP85 with a whole 16K of ram and 8" floppy drives with abysmal data capacity. I also had intermittent access to an HP9845 but only for programming and playing with a working plotter... only when I was a very very very good kid. All of this was very very expensive computer hardware for a young teen to have access to. I made actual mechanical and electrical repairs to some of the HP plotters and I was allowed to play with one that was beyond repair. The real engineers thought my Frankenstein with wire wrap boards was amusing and it kinda worked. I guarantee a kid would never be allowed to play with hardware like that at their fathers' place of work in this day and age. Goodies like that were nowhere near as easy or as available as the truly serious robotics and electronic controls and sensors that youngsters presently have easy access to. The discrete hardware and Microchip PIC and Atmel or some of the canned development hardware like the Intel Galileo and Arduino boards among others are really cool. Modern hardware really is like Legos and it's cheap... but even the TTL chips and discretes could be compared to Lego sets if you were mildly careful of what you were doing. $1 for a component was a huge amount of money for a 10 year old kid that was getting $2 to mow the lawn so screwing up and smoking a $35 TTL chip was a really big deal. Pulling stuff from a dumpster for components was not off limits as long as it stayed in the barn or garage and got heaved when I was done with it. I'm lucky enough to still be playing. um... I mean working with electronics hardware in the field in a company I own more than a small part of. We make passenger counters for public transit buses, coaches, and rail. I am a field engineer because it's still fun to build this stuff.
And please let us know if and how your repairs were successful. Last edited by hatzie; 08-05-2016 at 03:55 PM. |
08-05-2016, 02:31 PM | #4445 |
Re: Restoring Rusty
Hatzie..as usual I have no freaking idea what you are talking about..lol. All I know is "try rebooting it if it doesn't work"
08-05-2016, 02:38 PM | #4446 | |
Moderator
Re: Restoring Rusty
Sorry. At least you aren't using a hammer...
08-05-2016, 02:43 PM | #4447 |
Re: Restoring Rusty
Hatzie I enjoy your interjections and in my time studying the GM 7427 PCM for my 4L80 after reading this I know about 1/10th of what your saying and that's good because now you are driving my to learn more and that is the #1 reason I come to this site is to find the drive and necessity to know more because if I never knew something existed then I would never know to know more if that all makes sense
"Orange Crush" |
08-05-2016, 06:01 PM | #4448 |
Re: Restoring Rusty
08-05-2016, 06:19 PM | #4449 |
Re: Restoring Rusty
YES!!! I have done that with a piece of plastic tubing on my 81 stepside, and the door has never been better!!! ☺
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
08-05-2016, 11:27 PM | #4450 |
Post Whore
Re: Restoring Rusty
~ partz ~
Wanted a digital fuel gauge but didn't want to pay shipping, so.... A double click here and a double click there later |
