#426 |
Re: Dropmember in a 69 C10
Is it possible to use Coil springs instead of bags with the Dropmember? Does the Dropmember itself lower the ride height of the truck or does the lower ride height come from the drop spindles?
#427 | |
Porterbuilt had mentioned the possibility of manufacturing a Dropmember for use w/stock coil springs but I don't thinks it's a 'sure-thing' yet.
#428 |
I am still looking into making the Dropmember with a coil spring option... only obstacle is the lower control arm... maybe I will have to start building tubular arms as well....
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#429 |
would be nice .... you could make them custom size too
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#430 |
Would the Dropmember still allow me to use the stock drum brakes?
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown '70 SWB Step-Side (More rust than metal) ![]() |
#431 |
you can mount stock spindles so i guess the drumbrakes will fit too
#432 |
Señor Member
They should be fairly easy to hunt down, either on the parts board or at a wrecking yard. I'd expect to pay $15-30 for one. If it comes out of a TH400 truck, it'll save you from having to deal with the holes that'll be in the middle of it if it's a 4-speed truck.
#433 |
If I were to use the stock control arms would I be able to use coils?
#434 | |
Your stock suspension components will work fine with the Dropmember (control arms, spindles and brakes). You will however, need to trim a little off the back of the lower control arm for clearance at the billet mounting block on the Dropmember. Feel free to ask any and all questions.
#435 |
Nathan, have you or any of your customers installed the dropmember with a big block in a 64-66? I am curious to see if this will work.
#436 |
Hammered 65-
The Dropmember will work with a Big Block... the fit is a little tighter, but is do-able. I should have the motor mounts for the Big Block done by the end of the week. I am not aware of any BBC/Dromember combos in a 64-66... yet. There have been several in the 67-72s. The Dropmember Back-half will be making its debue soon. Expect some pics in the next week or so.
#437 |
Nathan,
I wanted to order my power rack and all the stuff need to hook my steering shaft up to the rack tommorrow. Do you now how much? |
#438 |
I was wondering if the performance online upper and lower control arms will work on the dropmember.
#439 |
Also what would shippng cost roughly for the kit shipped to 21157.
#440 | |
It doesn't look like those arms would work. The reason that a steel coil spring will not work is because the Dropmember narrows the track width. It would be necessary to move the spring mount outboard. I will be building tubular control arms in the future, and intend to provide the Dropmember with a steel coil spring option.
#441 | |
Hey Nathan, just bundle up the Dropmember, Arms, and back half, I'll send you a frame to attach them to so it's easier to ship, ok? ![]()
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#442 |
Active Member
![]() Join Date: Oct 2006
I to am waiting to see the a-arms and back half so I can start my suspension drop. If it is like all of Nathan's other items it will be better then ART.
#443 | |
#444 |
think the next fase will be a complete bold under frame .....
#445 |
i can't wait to see the pics of the backhalve......i am purchasing both of them in the very near future!! and that camaro looks damn sexy too!
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife: 71 cab for sale in parts classifieds! 2004 black chevy 1500 "finish your beer, theres sober kids in india!" ![]() |
#446 | |
I will be cutting into a long bed frame to install a Dropmember Back-half (C4 version)... in the next couple of months. It will be a long to short conversion, but before I cut it off for the conversion, I will cut it off further back to keep the long wheel base... and see what needs to be done for guys like you!
#447 |
I am currently mocking up the big block so I can get the motor mounts done. I will throw a cab on the chassis Friday and snap some pics. The big block does have to move up a bit more than the small block (about 1/2 to 1"), to clear the rack and oil pan. I will be seeing if the trans tunnel will need to be modified... it will be close!
#448 | |
#449 | |
Keep up the good work and keep the pictures coming!
#450 | |
