Old 08-06-2014, 02:08 AM   #426
EightiesOnly
EightiesOnly's Avatar
Re: 86 Silverado Father and Son project
Very small update here...
I decided I had left my headlights on too many times.
I saw on this site that a headlight warning buzzer was cheap and easy to do, so I did it.
I found this pic from a factory service manual on another thread.
I picked up a buzzer from radio shack for $1.19 on clearance. Then added small ring terminals for plugging in to the fuse box terminals.
Added double sided tape.
And installed.
It works good. It's a little quieter than the key on buzzer, which is good.
In case you don't know how it works, the headlights feed gives it power and the ignition gives it ground through various circuits when the key is off.
So, key off + headlights on = BUZZ.
LC.
My Truck Build (1986 LS powered c10)
EightiesOnly is offline   Reply With Quote
Old 08-20-2014, 11:03 PM   #427
EightiesOnly
Time for an update.
I gave my instrument cluster a long overdue overhaul. I have been wanting to install an 82-89 Camaro tach/ oil pressure gauge. So, I bought one on ebay....
This meant that I had to find a small fuel gauge to put where the original oil pressure gauge went, so I pulled one at LKQ from a 70's pontiac car...
It required a small amount of Dremel work to clear the black cluster cover...
I was able to use both of the mounting posts...
It required switching the oil pressure sending wire and the fuel sending wire on the cluster connector.
Then I painted the needles (including the tach needles) with this...
This stuff works great on needles. Just use a bunch of thin coats.
From there I needed to put something where the old tach (clock spot) was, so I hacked a the SES and CRUISE lights out of this non-working cluster...
Painted over the markings.
Everything epoxied together the epoxied straight to the bezel.
LC.
Old 08-20-2014, 11:38 PM   #428
EightiesOnly
To install the tach I cutout an old fuel gauge to hold the tach. I bent the top tab over the fuel gauge face, the bottom right tab lined up with the original fuel gauge tab, and I used a couple of tiny screws and nuts to fasten them together...
Wiring: I bolted wires to the existing clips using ring terminals. I also used a connector to bring the other wires in (tach signal, SES, cruise light, SES feed, speedo signal).
Installed.
I also had to move my BRAKE light over to the speedo. This also required a re-pin of the cluster connector.
As of now the cruise light simply comes on when the cruise lever is switched to on. I plan on coming up with a circuit to turn the light on only when cruise is engaged.
The tach, oil pressure gauge, and fuel gauge were all plug and play and work great!
That's all for the time being.
LC.
Old 08-21-2014, 09:09 AM   #429
NastyBuzzard
NastyBuzzard's Avatar
The gauges turned out really nice!! I am going to attempt swapping in the 01 cluster into my 87 in my build...
NastyBuzzard is offline   Reply With Quote
Old 08-21-2014, 10:07 AM   #430
Low Elco
Nice!
Low Elco is offline   Reply With Quote
Old 08-21-2014, 10:26 AM   #431
mcbassin
Still Learning
mcbassin's Avatar
Skills brother....skills
mcbassin is offline   Reply With Quote
Old 08-21-2014, 09:15 PM   #432
EightiesOnly
Thanks. That will be awesome! I was going to try to install 99-07 tach, but it would have been too much trouble.
Originally Posted by Low Elco View Post
Nice!
Thank ya
Thanks it was just quick and dirty.
LC.
Old 08-21-2014, 09:26 PM   #433
Crash_OK
Crash_OK's Avatar
Great Job
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 08-22-2014, 09:00 AM   #434
EightiesOnly
Originally Posted by Crash_OK View Post
Great Job
Thanks Mark, it went real smoothly.
LC.
Old 08-22-2014, 09:34 PM   #435
rfmaster
rfmaster's Avatar
Nicely Done
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 08-22-2014, 10:19 PM   #436
EightiesOnly
Originally Posted by rfmaster View Post
Nicely Done
Thanks, I used some of your information from the thread over this install.
LC.
Old 08-23-2014, 02:46 PM   #437
Hankster
Hankster's Avatar
Originally Posted by EightiesOnly View Post
Dude that looks awesome!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 08-23-2014, 10:50 PM   #438
EightiesOnly
Thanks, it sure beats my old setup.
LC.
Old 12-12-2014, 01:44 AM   #439
P-DAWG'85
P-DAWG'85's Avatar
I might just have to steal a few of your ideas for my build! I especially like the small fuel gauge and tac swap. ROCK ARM!!!
P-DAWG'85 is offline   Reply With Quote
Old 12-12-2014, 09:10 AM   #440
mcbassin
Still Learning
mcbassin's Avatar
It's been almost a year, how's the 5.3 engine holding up?
Old 12-12-2014, 09:33 AM   #441
EightiesOnly
Thank You, that's one of my favorite additions!
It's held up awesome! I've daily driven for the year without any issues. The only thing I had to fix was the idler pulley which blew out a while back.
LC.
Old 03-27-2015, 06:29 PM   #442
joecool
I was referred to your build by a friend,Great reading ,Thanks so much for posting it.
I am starting a 5.7 -700r4 out of a wrecked 93 fFeetwood so all your sweat will save me ,at least thats the plan.
Early on in the project your dad mentioned flashing a chip? Is this chip something that plugs in the ECM? I assume it changes timing and injector settings to help the performance some. Thanks again. Nice build .
joecool is offline   Reply With Quote
Old 04-09-2015, 03:32 PM   #443
Justin@EntropyRad
Justin@EntropyRad's Avatar
pretty sweet build..like the cluster work!
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 04-09-2015, 04:09 PM   #444
mcbassin
Still Learning
mcbassin's Avatar
Yes there is a chip in the ECM and We did not have to reflash it.
Old 04-09-2015, 08:12 PM   #445
joecool
thanks
Old 05-10-2015, 11:38 PM   #446
EightiesOnly
Thanks, I appreciate it.
LC.
